Weight limits on the Yakima Racks
Discussion in '2nd Gen. Tacomas (2005-2015)' started by kvnhlstd, May 20, 2009.
  1. May 20, 2009 at 12:10 AM
    kvnhlstd
    kvnhlstd [OP] Well-Known Member
    Valley of the Sun (Hot Sun)
    05 SR5 4X4
    OK... Background info first then
    Questions of the day.
    My Yakima roof rack specs state that on a Toyota Tacoma Double cab the max allowable weight that I can load is 100 pounds. According to Yakima reps, the rack is about 23 pounds, each set of bow downs are 25 pounds, so that leaves me with 27 pounds for two kayaks. Not happening in my world, even with fuzzy math. S
    o the question is "Are the allowable weights that Toyota has expressed to Yakima low balled??? How much do TW members load on their trucks??? Has anyone ever bent a door frame by overloading the rack???
  2. May 20, 2009 at 5:10 AM
    wing103
    wing103 Well-Known Member
    Boston
    Tacoma TRD Sport / Dark Gray
    Grill Craft upper & Lower Grill WetOK Seat Cover, Devil Horn, Bug, Windows Deflector, Side step Bar, HID 55W 8000K Headlight, HID 35W 4000K Foglight, Fog Light Mod, Interior LED Map Light Mod, Electric Tail Gate Lock, Leer Cab, Key ring light, Bed LED lights Mod, Kenwood DNX5120, Signal Mirror with Heat
    I want to find out too, Since I have the same brand name roof rack , I almost want to put a extension leader on it, but i have not do it, since i do not want to break it.
    Anyone have any idea or info?
  3. May 20, 2009 at 5:19 AM
    JDCPA
    JDCPA Well-Known Member
    Jim
    SW FL
    09 5 Lug Access Cab SR5
    Curt Hitch and etrailer.com wiring harness.
    "Load weights" typically refers to the load, not the rack. I load my old 75 lb Mohawk canoe on my Access Cab using one set of Yakima racks in the front. The rear is supported by a canoe loader mounted to the drawbar of the trailer hitch.
  4. May 20, 2009 at 5:45 AM
    Simon's Mom
    Judy or Jude :)
    NEK Island Pond VT
    24 Tundra Trd Sport former 13 TRD OR
    Stock for now
    I've carried 2 50# kayaks almost everyday in season (May-Oct) on my aftermarket thule system. Also have shoved a 3rd up there on occasion b/w the J-Hulls. Load bars and rack stayed level and handles load fine. Its been on the truck for two years & works great :thumbsup:
  5. May 20, 2009 at 7:53 AM
    Uhaul-n-azz
    Uhaul-n-azz Well-Known Member
    fayetteville,AR
    4Runner Stock
    I fit my dagger Nomad 8.1 an Blackwater 10.5 at the same time with no weight problems I would say you are fine.
  6. May 20, 2009 at 4:19 PM
    kvnhlstd
    05 SR5 4X4
    Bump for additional comments please... Also Yakima related that Toyota is advising them that the total load on the roof/door frame should be 100 pounds or less. This seems very low...
