Weight of the 3-gen taco front part?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Dacon, Feb 9, 2017.
  1. Feb 9, 2017 at 8:26 PM
    Dacon
    Dacon [OP] 2017 Tacoma TRD PRO Quikrete
    Danny
    Gilbert, Arizona.
    2017 TRD PRO DCSB. DOP 02.20.2017
    TRD PRO Cement 2017 TRD CAI and AFE Magnum Flow Dry Air Filter Camburg KINETIK Series Billet UCA Icon LCA skid plates Icon Coilover extended travel shocks with 700# springs Icon 2" rear shocks Icon RXT leaf springs full pack (new rims and tires soon)
    I have seen a post before on the same subject but no answer, so I ask the same basic question done before.
    - has anybody done it or has info of the weight of the 2-gen vs. of the 3-gen tacos nose part? As in drive the taco on a scale up to the end of door and check the nose/engine weight. At work next to me is a 2-gen taco and his front coils are thinner compared to mine which means the nose of the 3-gen taco is heavier. I have been informed that the weight difference is about 182lb between them. I know somebody can find the weights of the engines but need to know the whole nose stock build weight.
  2. Feb 9, 2017 at 8:30 PM
    Tunngavik
    Tunngavik Well-Known Member
    Alberta, Canada
    2018 TRD Off-Road Access Cab 6 speed manual
    KC-HiLites Fog Lamps, Kicker speaker and tweeter upgrade, USB in center console, Power tailgate lock, Soundproofing, 32" lightbar
    Well, considering the size of that front grill and lower bumper extension, I'm thinking at least 500 lbs.....maybe more.
  3. Feb 9, 2017 at 8:42 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    I would have figured the old 4.0 would be heavier than the 3.5 thus making it lighter up front.
  4. Feb 10, 2017 at 3:44 AM
    Paul631
    Paul631 Well-Known Member
    2016 4x4 5-spd Utility Package
    Bilstein 6112/5160 Grabber X3's
  5. Feb 10, 2017 at 3:57 AM
    desmodue
    desmodue Unsprung member
    2016 TRD OR AC
    While the weight of a 2nd gen Tacoma varies depending on the driver, generally they wear much lighter loafers therefore need lighter springs.
    You really should have known.
  6. Feb 10, 2017 at 3:58 AM
    MQQSE
    MQQSE I take naps
    MooseMan
    Palmer, Alaska
    "Stitch" & "Sumbitch"
    tacotoe and bobrown14 like this.
  7. Feb 10, 2017 at 4:31 AM
    TacoRD16
    TacoRD16 Well-Known Member
    Houston, TX
    2016 Tacoma TRD Off Road 4x4
    Fox 2.5 RR C/O Fox 2.0 RR Rear Dakar leaf Pack Headstong Brakeline Extension Bracket 16"Konig Countersteer wheels BFG's KO2 285/75r16 All-Pro UCA 1.25" All-Pro APEX Slidders Unided CB w/ Firestick II Lamin-X fog Lens 1" Diff Drop OME 1/2" CB Drip OME Mobtown 3/16" Skid plates: Front, Trans and Transfer case Relentless Hood Brackets AuxBeam Ditch Lights DBCustons Grill "Recolored" Matt Black Relentless High Lift Mount Softopper Diff Breather Mod Tail Gate Inserts HondoGarage Tablet Vent Mount Weather Tech Floor Liner
    After market suspension parts are all marketed and sold the same for Tacomas 05+. Shouldn't be much of any weight difference. Things to think about that adds weight; tow package (Oil cooler, bigger alternator, bigger oil pan?), accessories (moon roof, heated seats components, buttons wires, sensors, fake hood scoop).
    Bigger springs do not always mean they have a higher K coefficient. Having narrower coils width you can reduce spring cross sectional area since the moment from one coil to the next is smaller if the K coefficient is the same.
    shakerhood and 1bad2k like this.
  8. Feb 10, 2017 at 7:00 AM
    Dacon
    Danny
    Gilbert, Arizona.
    Thank you, good response.
  9. Jun 23, 2017 at 10:46 PM
    daohaus
    daohaus Well-Known Member
    Duan
    33.960892 -117.575824
    18 TRD Off Road Premium 4runner
    Rotiform SIX OR Toyo Open Country RT
    I think most of that is in the damn hood alone. I opened the hood of my truck today and that is one huge slab of steel. I'm hoping Toyota will start including aluminum into their car/truck lineup.
  10. Jun 24, 2017 at 12:03 AM
    Broccoli
    Broccoli Well-Known Member
    Airdrie Alberta
    2016 trd sport blazing blue,
    So prices can get even more jacked up?
  11. Jun 24, 2017 at 12:07 AM
    daohaus
    Duan
    Economy of scale, use it more in your product line the code will get spread out
    More and more car companies are mixing metals to reduce weight and improve performance and mileage.
  12. Jun 24, 2017 at 12:34 AM
    erok81
    erok81 Well-Known Member
    Imposter
    Ha! When I first opened my hood I thought something was wrong because it was so heavy!
    daohaus[QUOTED] likes this.
  13. Mar 17, 2021 at 3:25 PM
    hoarder23
    hoarder23 Truck fell over
    Shay
    NJ
    15 Pyrite Mica DCSB Sport
    Scratches
    @Naveronski maybe this one? Not real life numbers but from literature
  14. Mar 17, 2021 at 3:30 PM
    Itchyfeet
    Itchyfeet Well-Known Member
    The OP is dead guys, I heard he died in a horrible marijuana combining accident in Happy Camp, CA.
  15. Mar 17, 2021 at 3:37 PM
    hoarder23
    Shay
    NJ
    Scratches
    We don’t want the OP, just the info
    Tacoma’20 likes this.
