Weight on the TailGate?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tacomtn, Nov 8, 2014.
  1. Nov 8, 2014 at 8:11 PM
    tacomtn
    tacomtn [OP] Well-Known Member
    TRD OR,OME,Deaver AAL
    I've been packing two dirt bikes with the rear tires on the gate of my SB TRD 4x4. I believe the gate has a 200lb cap. The two bikes weigh 150lbs and 250lbs. But only the rear wheel is on the gate.
    Should I be concerned?
  2. Nov 8, 2014 at 8:37 PM
    TCprerunner
    TCprerunner Well-Known Member
    I have had a sb350 long block sitting on the edge with no issue and my 1600cc bobber loaded and unloaded several times with all the rear tire weight on the tail gate.
    You should be fine just be easy on it and use common sense
  3. Nov 8, 2014 at 10:07 PM
    TacomaTruckParts
    TacomaTruckParts Well-Known Member
    Jesse
    San Gabriel
    [​IMG] Disaster is about to strike......
    I have an 05' LB that I have beem hauling dirtbikes in since new (reason I bought it - new bike). Stock tailgate has held up just fine, but I also dont abuse my truck either.
    Some people have creased/bent their tailgates loading bikes or other stuff. So naturally a "Weak tailgate reinforcement solution" has been found....
    Roll the dice.
  4. Nov 8, 2014 at 10:15 PM
    DylansBase
    DylansBase Well-Known Member
    Dylan
    Murfreesboro TN
    2007 DCSB Taco TRD Off-road
    Bilstein 5100 w/OME 886 All pro expo leafs w/icon 2.0 Relentless Fab plate bumper BFG KO2
    I'm 205lbs and I've jumped up and down on mine. That's probably recommended. But it can withstand more of that. Had a few friends sit on it as well at once, probable upwards of 400lbs. You should be just fine
  5. Nov 8, 2014 at 10:48 PM
    Thegenerik1
    Thegenerik1 Well-Known Member
    Erik
    NorCal
    18 DCLB OR
    You should be careful, they are weak tailgates. I would be more worried when loading them. Once they are in and tied down there isn't much weight on the rear wheels.
  6. Nov 9, 2014 at 12:38 AM
    tacomtn
    That's a good point. With only the rear wheel, static weight and really only half the weight. It's fine. But the chance is when I'm loading as the whole weight of the bike is on the edge of the gate. As I'm rolling the bike up the ramp, that could be an issue.
    I've seen that aftermarket tailgate reinforcement plate. But doesn't that only reinforce the mid section, not really the edge, which is where the weight is with the loading ramp resting there as I roll up the 250lb bike? But I guess the plate reinforces as it spreads the load out over the whole gate.
    I also wonder about the cables holding the weight of the gate AND the bike while loading on the ramp.
  7. Nov 9, 2014 at 6:22 AM
    dilligaff82
    dilligaff82 Well-Known Member
    New Hampshire
    2014 TRD Off Road DCSB
    I regularly load and unload my 800+lb 4 wheeler with my 240lb self and I haven't had a problem with the tailgate yet.
  8. Nov 9, 2014 at 6:22 AM
    Thegenerik1
    Erik
    NorCal
    18 DCLB OR
    The Relentless tailgate reinforcement adds strength to the entire tailgate. I just bought one on his group buy because I too ride dirt bikes and don't want to bend my tailgate loading or unloading.
  9. Nov 9, 2014 at 6:12 PM
    ThomasMore66
    Dallas/Fort Worth & Durango
    Lots of examples of bent tailgates out there. Just got in on the Relentless Fab tailgate group buy. Seems worth the money to me.
  10. Nov 9, 2014 at 6:15 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Just an FYI Toyota upped the reinforcing in the Tacoma gates in 2008 , most bent gate pics are from earlier model trucks
  11. Nov 9, 2014 at 6:21 PM
    File IFR
    File IFR "... Intercepting The Localizer"
    Central MA
    2012 MGM 4X4 DC-LB TRD Sport
    If a bike's back tire is on the tailgate while driving, avoid any bumps to minimize bouncing.
    There is a member here that bought a new truck from the dealer. The buyer asked if the gate is strong because he puts his bike (street bike) in the bed of pickups. Salesman said he'd have no problem. It turns out that the gate was severely bent from his first haul.... back to the dealer he went. The dealer did remove a tailgate from another truck on the lot to replace it.
    I wish I could find the picture the member posted, it was bad, but it was a street bike.... dirt bikes are much lighter.
  12. Nov 9, 2014 at 6:29 PM
    oldracer
    oldracer Well-Known Member
    I too saw the bent tailgates, so I made my own reinforcement. That was before the companies listed on this forum started making reinforcements.
    Someone above (tacomtn), mentioned that they only reinforce the center of the tailgate. Not really, even though the center is where the damage usually occurs, if you reinforce the entire width of the gate, you will be OK.
    The ends don't seem to bend. And the cables seem to work OK also.
    Anyway: Once it is bent, Too Late!
    oldracer
  13. Nov 9, 2014 at 6:33 PM
    KB Voodoo
    KB Voodoo Well-Known Member
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    It would take a lot to bend mine....
  14. Nov 9, 2014 at 6:36 PM
    SpeedoJosh
    SpeedoJosh Well-Known Member
    Florida
    2010 Access cab, Base, 4x4
    Yea, I get nervous every time I bang around back there. The only solution on the market isn't appealing to me though since the lip doesn't align correct. There is a member with talks of a reinforcement that does not have a lip. I've been eagerly watching his thread.
  15. Nov 9, 2014 at 7:45 PM
    KB Voodoo
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    No lip on the back = little to no added strength.
  16. Nov 9, 2014 at 8:06 PM
    99sh
    99sh Well-Known Member
    DCLB
    Can you explain how the overhanging lip adds strength?
  17. Nov 9, 2014 at 9:24 PM
    SpeedoJosh
    Florida
    How do you suppose that? A full sheet of metal bolted on top of the tailgate would definitely help support any weight put on it.
  18. Nov 9, 2014 at 9:27 PM
    TacomaTruckParts
    Jesse
    San Gabriel
    Not completely true, the other bends should add a lot more strength than the factory tailgate. True, bends do add rigidity; 2 out of three bends will be sufficient for the majority of applications. Yes, for ultimate strength, that outside lip would help.
    I agree with the post above, That outside lip just does not appeal to me.... I like the idea, just not the execution (what is available thus far).
    Jesse
  19. Nov 9, 2014 at 9:30 PM
    OZ-T
    Peter North
    British Columbia
    If the flat sheet uses the factory bolts , they're just mounted into plastic
  20. Nov 9, 2014 at 9:52 PM
    SpeedoJosh
    Florida
    Multiple attachments though. I looked at his drawing, his measured forces, and measurements he took with the sheet of steel. So I trust that he'll R&D it with weight to see how the screws hold up. If I put something on there that weighs enough to bend the sheet of metal enough to rip all of those screws out, then my tailgate was doomed anyway.
    Like TacomaTruckParts said, I know the bend would help, but in my opinion they don't look good. The absence of the bend is obvious, and they rarely sit level with the rest of the bed caps. I like the way the OEM stuff looks, and don't want to mess with it. If the potential vendor doesn't come through, then I'll just continue to tip toe across the bed.
