Weight reduction mods?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by S7ICKlVlAN, Mar 26, 2012.
  1. Aug 17, 2022 at 12:22 PM
    #101
    kgarrett11
    kgarrett11 Master Yoda
    Garrett
    CA desert
    2015 DCLB
    I never weighed it, but it's quite heavy taking it out
  2. Aug 17, 2022 at 12:49 PM
    #102
    Color_Me_Taco
    Color_Me_Taco Well-Known Member
    Doug
    Utah
    2022 TRD OffRoad, 2019 TRD OffRoad, 2021 Subaru STI, 2021 Kawasaki ZX6R
    ADD, Rigid, ToyTech, DBcustomz, Methods, Nittos, Powertank, Morimoto
    Use helium in your tires...your truck will float off the ground.
  3. Aug 17, 2022 at 1:30 PM
    #103
    JGO
    JGO Well-Known Member
    South Central Kentucky
    '14, 4 Cyl, A/T, Silver A/C
    Take off your tailgate.
  4. Aug 17, 2022 at 2:10 PM
    #104
    mattybouges
    mattybouges Well-Known Member
    Boston
    2022 Lunar Rock TRD OR Short Bed
    I’m documenting my weighted configurations; I’ll let u know when I take them out. “Quite Heavy” leads me to believe this might be a more worthwhile mod. Thx man
    kgarrett11[QUOTED] likes this.
  5. Apr 10, 2023 at 8:59 AM
    #105
    sierra_surfer_taco
    sierra_surfer_taco Well-Known Member
    San Diego
    2000 Tacoma TRD
    FWIW, I took my sway bar off my 2000 Tacoma TRD and it weighed 14.75 lbs. I know this is a 2nd gen thread, but FYI. Also, I love how the truck rides now, but I have Bilstein 6112s in the front which keeps the handling in check.
  6. May 13, 2023 at 7:43 PM
    #106
    mattybouges
    Boston
    Finally did the rear seat delete and measured it. 2022 double cab rear seat delete comes in at minus 70 lbs. IMO that is quite significant given the paltry payload for the 4x4 taco's.
    DVexile likes this.
  7. May 14, 2023 at 10:48 AM
    #107
    2WD
    2WD Well-Known Member
    Pete
    2013 DCSB TRD Off-Road Pre-Runner Taco
    King 25001-119A, JBA HC and superbumps, EL095 leafs with longer overload leaf removed and 2 degree shim, Bilstein 5160 rears with fox roost shield on passenger side, King 2'' bump stops, B&M 70264 trans cooler, CSF FJ radiator, Leer Trilogy X2T bed cover, Scangauge, 34R AGM battery, weathertech floormats, Gold plug on the differential, fancy engine and diff oils, UNI air injection filter mod, Factory antenna chopped 4'', De-badged, Ram mount on A pillar, Cooper ST Maxx 265/75 R16.
    I did. Optima red top 34r. Used a battery tray from non-tow package Tacoma and an aftermarket tie down. AZ heat kills batteries fast, regardless if they are big or small. The Optima weighed on my bathroom scale at 39.4 pounds. My old Duralast gold 27F weighed 48.8.
  8. May 14, 2023 at 11:08 AM
    #108
    MadJacks
    MadJacks Well-Known Member
    Justin
    Edmonton, Alberta
    2020 TRD Sport MT
    I weigh 140lbs, so theoretically I have an extra 30-40lbs than the average driver.
    That being said, I get the best traction/fuel economy with about 200lbs in the back over the rear axle. Sometimes is more about weight transfer than weight reduction.
  9. May 14, 2023 at 11:41 AM
    #109
    TacoDinner
    TacoDinner Well-Known Member
    Remove side view mirrors. This should help with aerodynamics too.
