Weight to safely haul in bed?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by foggybottomboers, Apr 4, 2016.
  1. Apr 4, 2016 at 11:17 AM
    foggybottomboers
    foggybottomboers [OP] Member
    How much weight can you safely haul in the truck bed? I have a 2012 Toyota Tacoma TSS. I am being told by a family member that hauling 15 bags of animal feed (750 lbs) is too much for my truck and will cause transmission and other troubles.
  2. Apr 4, 2016 at 11:24 AM
    Up2NoGood
    Up2NoGood Well-Known Member
    Jaimes
    BC, Canada
    2014 TRD Sport DCLB
    That weight will be fine... they might have a point if you wanted to do that full time. But a trip from point A to point B would be no problem.
    foggybottomboers[OP] likes this.
  3. Apr 4, 2016 at 11:26 AM
    foggybottomboers
    I haul it a couple times a month for about 20 miles.
  4. Apr 4, 2016 at 11:30 AM
    Up2NoGood
    Jaimes
    BC, Canada
    2014 TRD Sport DCLB
    I wouldn't be concerned with that at all to be honest. You should have the listed weight on a sticker in your drivers door, but I believe the max allowable is somewhere around 1,000 - 1,100 lbs if I'm not mistaken.
    If you were worried about it you could always get a small trailer though.
  5. Apr 4, 2016 at 11:34 AM
    Up2NoGood
    Jaimes
    BC, Canada
    2014 TRD Sport DCLB
    lol I've done that a couple of times too but try not to make a habit of it. I'll have airbags going in soon so should eliminate any squat for heavier loads.
  6. Apr 4, 2016 at 11:37 AM
    Clearwater Bill
    Billy
    Largo Florida
    That alone is likely a good reason to be here double checking. :D
  7. Apr 4, 2016 at 11:45 AM
    foggybottomboers
    Thanks everybody. I thought it was fine, but figured I should check. :)
  8. Apr 4, 2016 at 12:03 PM
    Keating
    Keating New Member
    Paul
    Ontario
    2010 Double Cab SR5 4x4
    Depends how long/how far.
    I had a tip slip from the landfill (certified scale) in the glovebox for years that read 1025kg. That's almost 2300lb. It was all scraps/remnants from a interlock patio install. The leafs were flat, (sitting on the bumpstops) and the OEM Dunlops were a little squishy, even with 40PSI in them, but I got to the dump and back. That was 60,000 miles ago.
    I haul a cu.yd. of topsoil, mulch (1200-2400lb, depending on how recent it has rained) or 1/2 yard of 3/4" GA (1400lb) a couple times a year with no problem
    foggybottomboers[OP] and mwc273 like this.
  9. Apr 4, 2016 at 12:06 PM
    travistheone
    travistheone Well-Known Member
    2012 black sport double cab
    750 IS NO PROblem
