Weighted tag
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Yotatrd12, Mar 3, 2017.
  1. Mar 3, 2017 at 6:17 AM
    Yotatrd12
    Yotatrd12 [OP] Member
    2012 gray tacoma
    Just have a queation is anybody on here running a weighted tag because when i purchased my tacoma they said i had to have weighted tag and i just got everything done at tag place yesterday and they told me i had to have weighted tag to i seen a 2016 tacoma same color yesterday and it didnt have weighted tag any help would be greatly appreciated
    ChadsPride likes this.
  2. Mar 3, 2017 at 6:22 AM
    JJ Customs
    JJ Customs Supreme Leader!
    Jay
    NV
    Sierra Denali Ultimate, 6.2
    A few additions to make me feel cool.
    Welcome but WTF is a weighted tag?
    Alfred, tomwil, MadDaddy and 5 others like this.
  3. Mar 3, 2017 at 6:23 AM
    Yotatrd12
    2012 gray tacoma
    Your license plate tag says weighted on it
  4. Mar 3, 2017 at 6:27 AM
    JJ Customs
    Jay
    NV
    Okay I have no idea what state you are in but regardless you should not be paying any oversized or weighted tag on a tacoma. Someone screwed up. Same happened to me in NV when I registered my truck. They typed that my truck weighs 55,000 or some b.s. and wanted $600 for registration. Look at your registration at what they claim your vehicle weighs. DMV screwed up.
  5. Mar 3, 2017 at 6:31 AM
    jake72
    jake72 Well-Known Member
    Jake
    N.E. PA
    2019 trd off-road dcsb mt
    Pennsylvania gives you a class 2 sticker to put by your inspection sticker. Nobody does though
  6. Mar 3, 2017 at 6:36 AM
    Yotatrd12
    2012 gray tacoma
    Ok ill post the weight and what they put the weight at on the registration im in nc i had a 03 tundra before my tacoma and never had to have a weighted tag
  7. Mar 3, 2017 at 6:37 AM
    robssol
    robssol If it ain't broke, leave it the eff alone!
    Rob
    S. Wisconsin
    06 Tacoma, TRD Sport, SR5, 4X4, AC
    Totaled but still alive! Frame 2.0, Fog lights anytime, Seatbelt reminder delete, Secondary air filter delete, LED bed lights, Running boards, 2017 Rims, Ultra gauge, Cup holder/consol/glove compartment lights, Interior LED conversion, Blue Sea aux. fuse panel, fuse panel mounting plate by Yotamac, ProEFX heated towing mirrors, LED engine bay lights, Redline Quicklift Elite hood struts, Wet Okole Heated Seat Covers,m, Rear bumper 2.0, Decal free visors, Washable cabin air filter, Overhead consol auto dimming override switch, BulletProof Fabricating Skid plate, 2lo module.
    In WI our tags have letters for the weight limit. Tacos almost always get a "A" (the lowest) that is only on the rear tag not the front.
    Welcome to TW!:hattip:
  8. Mar 3, 2017 at 6:38 AM
    Pigpen
    Dan
    Northwest Montana
    Your truck weighs roughly 4200 - 4500 pounds. Let's see what the state tries to say it weighs.
  9. Mar 3, 2017 at 6:44 AM
    robssol
    Rob
    S. Wisconsin
    Our tags are for the GVWR. Vehicle plus max payload.
  10. Mar 3, 2017 at 6:46 AM
    Pigpen
    Dan
    Northwest Montana
    copy that
    So, 5800 pounds, or somewhere thereabouts
    ChadsPride and robssol like this.
  11. Mar 3, 2017 at 6:50 AM
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2015 Tundra
    I always thought weighted had more to do with use than actual weight of the vehicle
  12. Mar 3, 2017 at 6:56 AM
    robssol
    Rob
    S. Wisconsin
    All trucks in WI get weight tags. As do Cargo vans and some SUVs. I've even seen them on a few CUVs. It has to do with the potential wear and tear a certain vehicle can do to the road. And the vehicles weight has something to do with that.
    JimBeam[QUOTED] likes this.
  13. Mar 3, 2017 at 7:47 AM
    JJ Customs
    Jay
    NV
    Take a look at what they listed the weight of the vehicle at. Like I said they screwed mine up in NV and when I got them to correct it the price dropped to half the price. I knew it was wrong when they told me what I owed and inquired as to why but you know DMV! So I just paid it and looked after and sure enough they added a 0 to the weight. I expect the same happened with yours.
  14. Mar 3, 2017 at 7:50 AM
    JJ Customs
    Jay
    NV
    Well according to this it might be legit if you told them you might tow.
    All trailers in North Carolina must have some form of plate on the trailer itself. The weighted tag needs to be on the truck. Private, noncommercial pickup trucks, registered with regular “First in Flight”-type license tags, may trailer a combined total load of up to 9,000 pounds.Aug 17, 2016
    Now if you never tow anything then you should not have to have it but if what I read is correct if the truck and your load are in excess of 9K then you run the risk of being ticketed for being overweight in NC without the weighted tag. I would say you would be pretty safe without it!
    JimBeam likes this.
  15. Mar 3, 2017 at 7:56 AM
    Yotatrd12
    2012 gray tacoma
    Im in nc
  16. Mar 3, 2017 at 7:58 AM
    JJ Customs
    Jay
    NV
    Hence the reason I posted the NC law.
    JimBeam, MadDaddy and Paul123 like this.
  17. Mar 3, 2017 at 7:59 AM
    Yotatrd12
    2012 gray tacoma
    It makes no sense i paid taxes yesterday and the tag oddice told me i have to have weighted because the weight of the truck plus if i decide to pull a trailer ive pulled two trailers with my tacoma i could understand if i pulled a trailer everyday but i dont ive got friends who habe full size chevrolets and there tags arnt weighted
  18. Mar 3, 2017 at 8:02 AM
    JJ Customs
    Jay
    NV
    What does your registration claim your truck weighs? I doubt you are required to have that tag. I am sure your DMV screwed up.
  19. Mar 3, 2017 at 8:18 AM
    Yotatrd12
    2012 gray tacoma
    I agree with you JJ customs
  20. Mar 3, 2017 at 8:19 AM
    Yotatrd12
    2012 gray tacoma
    I think it said 5000 something on my regiatration
