Weights for truck bed
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Sgt.Tee, Dec 5, 2018.
  1. Dec 5, 2018 at 7:22 AM
    Sgt.Tee
    Sgt.Tee [OP] Well-Known Member
    Pete
    NE Pa
    2019 MGM SR Tacoma 4&4
    I did a search and come up with nothing. Do I need weights in the back of my 6 ft. Bed.
    I have not been a truck owner in some time and curious how the truck will handle in the snow. It is 4 wheel drive.
    I had a Blazer 4 wheel drive and it needed weight in the back to get traction.
    Just curious on this one.
  2. Dec 5, 2018 at 7:26 AM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    Whatever snow and ice gets back there is enough for mine. You could always tie off a tube of sand if you feel your truck needs it.
    tonered and phsycle like this.
  3. Dec 5, 2018 at 7:27 AM
    Col4bin
    Col4bin Well-Known Member
    Maine
    2018 TRD OR Double Cab
    running a 60pound tube sand from home depot over each axle....about 5 bucks each. people have lots of opinions on weight but i noticed a huge difference in the two snow storms here in maine.
  4. Dec 5, 2018 at 7:29 AM
    Mtn Mike
    Mtn Mike Well-Known Member
    Spokane, WA
    2017 TRD OR AC
  5. Dec 5, 2018 at 7:34 AM
    Sgt.Tee
    Pete
    NE Pa
    Ok Mike I will check that link. I did try a search before I posted but nothing came up. I guess wording needs to be right on, Thanks guys for the advice
  6. Dec 5, 2018 at 7:35 AM
    Col4bin
    Maine
    thats a great thread to read btw
    Mtn Mike likes this.
  7. Dec 5, 2018 at 7:41 AM
    Hemlocktherm78
    Hemlocktherm78 Well-Known Member
    4 3 gallon buckets with dry sand (incase u need the sand when stuck). rachet strap to front bed
  8. Dec 5, 2018 at 7:49 AM
    phsycle
    phsycle Well-Known Member
    CA
    Wait till the first storm. I've never needed weight in the back. If you do get something back there, make sure to strap them down. They can become projectiles in a collision.
    over60, shakerhood and tonered like this.
  9. Dec 5, 2018 at 7:57 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    That is what I did, while knowing that folks put weight in their beds for winter. It wasn't so much outright traction, but the rear felt too light when cornering. Lacing two 60lb tube sands by the tailgate made it feel right for me.
    As a tip for anyone, considering the excellent TRAC system, find your favorite on ramp or nice, wide curve and go around it a bit aggressively in the wet. You'll get a feel for the balance of truck, if it pushes, over-steers, or throttle-steers nicely. With the TRAC system on the default setting, it will keep you pointed in the right direction.
    RocTaco likes this.
  10. Dec 5, 2018 at 8:07 AM
    phsycle
    CA
    May be a good excuse to get a rear bumper. :D
    tonered[QUOTED] likes this.
  11. Dec 5, 2018 at 8:15 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Very true. Because swing out! But, at only $10/yr of sand. . .
    Tires and front and tank skids are at the top of the list now though.
  12. Dec 5, 2018 at 8:23 AM
    phsycle
    CA
    I'm trying to decide between skids or rear bumper. I am leaning to a rear bumper as I drag the rear more than get hung up underneath (on the trails I frequent). Non-swing out, though. That would drive me nuts using the rear tail gate. My next tire will be 255/75/17, so it should fit under the truck fine.
  13. Dec 5, 2018 at 8:28 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    I have used the hitch as a shovel, but the scratches on the bare Sport tank were a bigger worry. For now, an OR / Pro take-off would be just fine.
    That swing-out issue is what keeps the bumper further down on the list. The fam has been wishing for a TT, so the hitch has to stay or be incorporated.
    Decisions!
    phsycle[QUOTED] likes this.
  14. Dec 5, 2018 at 8:31 AM
    coopcooper
    coopcooper certified youtube mechanic
    alberta canada
    black on black on black 05 trd off road
    stickers and sticker accessory's
    I rarely use 4wd except to get out of my street cause the plows like to bury my truck when they come by other than that I find tacos handle pretty good in 2wd, I also don't have winter tires and do just fine.
    TacoCon and Tocamo like this.
  15. Dec 5, 2018 at 8:31 AM
    CusterFan
    CusterFan Well-Known Member
    Southeastern Illinois
    Silver Sky 2019 Tacoma SR, AC, 4X2, 2.7
    https://www.puzzleweights.com/
    https://www.youtube.com/watch?v=-YRk9MiqWIM
  16. Dec 5, 2018 at 8:43 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    honda50r likes this.
  17. Dec 5, 2018 at 8:56 AM
    CusterFan
    If I was an important person that had to drive on snow or ice covered roads I would stack firewood bed rail level in my truck. I just posted the Puzzle Weights for another option.
  18. Dec 5, 2018 at 8:58 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    I agree about both. I like the first one since you can have a nice campfire anywhere that way. :cheers:
    CusterFan[QUOTED] likes this.
  19. Dec 5, 2018 at 9:08 AM
    CusterFan
    That is what I use to do back in the day. :) And always had a cooler full of cold Bud.
  20. Dec 5, 2018 at 9:14 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    :drunk:
