Weird 5100's at 2.5 and 3" Toytech Lift
Discussion in 'Suspension' started by cfenn, Feb 17, 2009.
  1. Feb 17, 2009 at 12:54 PM
    cfenn
    cfenn [OP] Well-Known Member
    San Antonio, Texas
    PreRunner
    TRD exhaust,TSB, 5100's on the front, 884 springs, Total Chaos UCA, 5100's on the rear, Wheelers HD rear springs , Nitto 285/70/17's on MB TKO 17x8.5's
    Switched out springs to the 884's and top plate spacer and it is the same height as when I had my 5100's set at 2.5 WTF??? Also now the drivers side is .5" lower than before :confused:
  2. Feb 17, 2009 at 1:21 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Sounds about right. The 884's will give about 2.5" lift. The 885's give about 3". Also, the OME springs are not rated differently for Driver side and Passenger side, SO, as the driver side of the Tacoma is heavier, it will sag more on the driver side if not accounted for with different spring preload. The OME springs, when use with the OME shocks and trim packer on driver side, keeps the truck level from side to side, but the Trim packers are not compatible on the 5100's. You may want to replace the 10mm top plate spacer with one that is 15mm. That will have the truck sitting level from side to side.
  3. Feb 17, 2009 at 2:45 PM
    cfenn
    San Antonio, Texas
    PreRunner
    Ahh I see.... Thank you oh wise one
  4. Feb 17, 2009 at 2:48 PM
    Cramer@Down-South
    Cramer@Down-South Cramerism
    San Diego
    Black '08 Tacoma PreRunner Lifted Beautifully
    Lifted with Fox 2.5 Black & Chrome coil-overs, rear has Fox 2.0 Black & Chrome piggyback shocks, KMC 17" wheels wrapped with 285/75/17 BFG All Terrains, Total Chaos upper control arm, Alpine DVD doubledeck, and Volant cold air intake.
    sounds like the notorious "Taco lean" due the gas tank and other extra weight on the driver side makes it "lean" a little bit. You can try to set the preload a little stiffer on the driver side to acount for the lean.
  5. Feb 17, 2009 at 3:06 PM
    cfenn
    San Antonio, Texas
    PreRunner
    It is an access cab so that is why I did the 884 guess I should have done the 885 :( At least it is done and rides much better now
