WEIRD BANGING I CANNOT FIGURE OUT
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BlessdApparel1, Aug 1, 2021.
  1. Aug 1, 2021 at 10:04 AM
    BlessdApparel1
    BlessdApparel1 [OP] Overland Warehouse Online
    Oceanside
    2013 Tacoma Build In Progress
    @pelfreybuilt Aluminum Front Bumper @Dirtking 2.5 Long Travel @bajadesignsofficial Fog Pocket Kit, S1’s, A Pillar Squadrons @bajadesignsofficial 20” S 8 @cbioffroadfab Bedrails @mountain_hatch Tailgate Attachment @dirtylyfewheels 17” Roadkill Race Beadlocks @falkentire Wildpeak A/T’s @yakimaracks RTT @nickdeyatnight Rocksliders And Custom Rear Swingout Bumper @shibui_tank On Board Air @calicowboywhiskey Whiskey @phalcon_trailers Dualzone Fridge @fabzonearmor Skids @Allpro Offroad Bed Stiffners And Gas Tank Skid @archivegarage Rear shock location @Iconvehicledynamics RXT Leafs Pack @4xinnovations hangars and shackle flip @Radflo Custom 2.0 resis with finned 2.5 Res and adjuster
    Guys, I’m beyond flustered.
    I had a noise start a few months ago.
    I have what almost feels/ sounds like a banging noise.
    it sounds like it’s coming from either under my seat or the door pillar or something underneath me.
    I’m beyond stumped.
    when it started, it was occasionally on big hits.
    it was really hard to actually make it happen now though; it seems like almost every bump.
    it almost sounds like something inside the door was loose, or that something above the gas tank is banging, or something going on with my door latch.
    but the doors make no noise when opened. I’ve taken the door panels off and nothing. Nothing that shows suspect.
    curious if anyone has had this. I’m so irratated at this stupid noise
  2. Aug 1, 2021 at 10:15 AM
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly a 1998 SR5 PU, 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    Get under there with a wrench and check every bolt and nut you can find for tightness. The U-bolts holding the axles first, shocks, then all of the exhaust tranny and engine mounts. If you added skids or sliders, steps or a roof rack, check those too. May also want to see if the bed is aligned to the cab if something is too close and hitting between them. Also check lug nuts.
    And the dumb one- are the passenger shoulder belts fully retracted? The buckles do bang against the sides if not.
    If the noise still happens, at least then you’ll know it's not critical.
  3. Aug 1, 2021 at 10:15 AM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Check your cab mounts, one or more could be loose or deteriorated.
  4. Aug 1, 2021 at 10:21 AM
    OnHartung'sRoad
    Beer bottles rattling around under the seat? Naw, actually I did have full water bottles on the floor bang my seat mount with every stop, that got old quick!
    wilcam47 and BlessdApparel1[OP] like this.
  5. Aug 1, 2021 at 10:27 AM
    BlessdApparel1
    Oceanside
    So i just redid the whole rear end so everything is tight, front shocks are fine and i just rebuilt the front end a month ago, bumpers and sliders are welded on. When it happens i hear it and it’s like i can almost feel it through my seat. Not the peddles. I figured I’d feel it through the peddles if it was drive train related.
    the gas tank seems like it’s in and not going anywhere.
    is there anything mounted above the gas tank between the tank and cab maybe?
    I’d have to lift the carpet to check these from the inside as Well right?
  6. Aug 1, 2021 at 10:30 AM
    BlessdApparel1
    Oceanside
    I considered this, or the tools behind the rear seat but they are jam packed and stuff won’t move.
    I thought maybe the tools behind the seat but i took those out and checked and same thing.
    mom so irratated with this noise though I’m gonna lose my mind :lalala:
    nightcrawler[QUOTED] likes this.
  7. Aug 1, 2021 at 10:30 AM
    BlessdApparel1
    Oceanside
    Maybe could be a motor mount? I’d feel that through the peddles for sure though
    OnHartung'sRoad likes this.
  8. Aug 1, 2021 at 10:32 AM
    OnHartung'sRoad
    Gas tank straps tight? Oh yeah: (” the gas tank seems like it’s in and not going anywhere.”)
    No cracks in the slider welds? Maybe bang around a bit with a mallet on the frame and parts around the driver's side including the slider?
    wilcam47 likes this.
  9. Aug 1, 2021 at 10:32 AM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    You should be able to see them from the outside under the cab where it sits on the frame, another thing to check would be sway bar links and bushings.
  10. Aug 1, 2021 at 10:43 AM
    OnHartung'sRoad
    Did you lift it? Wondering if the UCA’s are getting hit if he kept the stock ones in, or if the shocks extended too far.
  11. Aug 1, 2021 at 11:00 AM
    BlessdApparel1
    Oceanside
    Yea UCA,LCA and CO are all aftermarket and tight. i thought it matched the sound of a bet coilover shaft but that’s not it either
    No sway bars anymore either
    I gotta figure it out somehow thiugh
  12. Aug 1, 2021 at 1:29 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    I had a banging noise from the bed right behind the cab. The right front bed bolt wasn't snug and the bed was allowed to bang up and down, even with my heavy Leer canopy
    Go to each corner of the bed and lift up. If it's loose you'll feel it
  13. Aug 1, 2021 at 5:17 PM
    Waasheem
    Waasheem
    2007 xrunner
    There’s a tool called chassis ear. I don’t own one or have the need for one. But your situation, if it’s driving you that bonkers you might want to get it. I read here recently someone mentioned theirs and how good it is.
  14. Aug 1, 2021 at 6:21 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Just stating one obvious that hasn't been mentioned yet.
    Is the spare tire tight?
  15. Aug 1, 2021 at 6:25 PM
    Aardvark13
    Aardvark13 Sultan of Squeeze, Wizzard of Slide
    Byl
    Knoxville
    2014 DCSB OR
    Aardvark4x4 Built for Go
    Do you have sliders? If so i would say def cab mount bushing. Even if you don't have sliders, I would check your cab mounts.
    BlessdApparel1[OP] likes this.
  16. Aug 4, 2021 at 8:26 AM
    BlessdApparel1
    Oceanside
    i do have sliders but they are welded on. I’ll check the cab bushings. And going to also check the bed.
    no spare underneath it’s on the bumper now
    I’m gonna check this when i get home. Maybe it is the bed
    I’m so frustrated I’m literally at the point of annoyance that I’d sell the truck lol. I get so aggravated everytime i hear it. When the truck is out of the shop, hopefully I’ll get this figured out
  17. Aug 4, 2021 at 8:44 AM
    Aardvark13
    Byl
    Knoxville
    2014 DCSB OR
    Right on. The reason I asked about sliders is if your cab mount bushing is worn, the cab can actually sag down enough that it hits the bar that connects the slider to the frame during a bump.
    Here where my finger is pointing is what I mean:
  18. Aug 4, 2021 at 9:39 AM
    BlessdApparel1
    Oceanside
    Ahhhhh maybe that is happening!
    I’ll check. I feel it would be pretty noticeable if it was so it shouldn’t be hard to detect.
  19. Aug 4, 2021 at 9:52 AM
    hogfan1978
    hogfan1978 Well-Known Member
    Nacogdoches, TX
    08 TRD Sport 4x4 DC LB
    I’d get a large friend to get on the hitch or in the bed and start bouncing the truck while I’m listening underneath.
    On my old blazer I had a mud clod that got lodged between the frame and body. Once it dried and shrunk, it rattled around like a marble in a tin can.
    TRD-ED likes this.
  20. Aug 4, 2021 at 10:04 AM
    MY50cal
    MY50cal ---- Tread Lightly ---- Leave No Trace
    Mojo
    Camden County, NC
    09 PM RC / 05 SWB AC (RIP)
    Yep.
    x2
    Sounds like a slider-to-cab thump to me. Hopefully it's sagging mount bushings as opposed to the sliders being installed to high.
    Got my first taste of this noise during winter when ice would build up between the slider and cab. Makes quite a thump.
