Weird beeping, won't start.
Discussion in '1st Gen. Tacomas (1995-2004)' started by 1985 4runner, Jan 28, 2016.
  1. May 13, 2022 at 3:46 PM
    r0meboards
    r0meboards New Member
    2004 Tacoma Prerunner
    Hey tacoma folks – resurrecting this thread as I have the same beeping issue. I suspect the aftermarket alarm / immobilizer is acting up (I disconnected the battery this morning to clean the terminals). Anyone have recommendations on how I can troubleshoot this? I found the alarm is an Avital 3100 but not sure if the immobilizer is part of that or something separate...
  2. May 13, 2022 at 4:10 PM
    Smokestacks
    Smokestacks Well-Known Member
    BayArea
    1996 3.4L 4x4 Tacoma extra cab MT.
    Eaton Truetac limited slip Bilstein 5100s struts set at 2” 5100s shocks Torch add a leaf B&M short throw shifter Hella h4 headlights Warn front hitch Curt rear hitch Sony DSX-GS900 Deck Custic 1000watt amp Alumpro 10” sub Lund Steel Gullwing tool box Broadway rearview mirror Weather tech window deflectors
    Test your battery. Check your alternator and if you have an alarm check that too can sometimes just unplug it another thing to look at is related fuses.
    Area51Runner likes this.
  3. May 13, 2022 at 4:26 PM
    r0meboards
    Thanks! Yeah the battery / alternator works fine. I managed to take out the entire alarm brain box but guessing the immobilizer is separate? Its pretty hard to navigate all the wires and tight space under the wheel, I haven't been able to find anything that is obviously not a Toyota OEM part. As far as I know the 2004s didn't have a factory immobilizer installed?
  4. Dec 1, 2024 at 3:17 PM
    Can96TacomaD60
    Can96TacomaD60 Member
    Gabriel
    1996 Tacoma 3rz
    D60 14"shocks on 3 links
    Hi guys, same problem, can't upload a video. Probleme came out of nowhere, I was trying to start up my truck after a 1 1/2 years of and ran fine but stalled (fuel probleme) and after a couple of try, this electrical probleme came out. Starts beeping when key is out, fuel pump doesn't work, cranks but no sparks, when I'm turning on and of my lights, flashers or clutch start button, beeping fades a bit but it will never stop, chek engine light, battery light and airbag light flash with the same beat as the beeping that comming off the intergration relay.
    I just ordered a intergration relay and will see if it change anyting.
