weird blinker problem
Discussion in '1st Gen. Tacomas (1995-2004)' started by floger70, Nov 27, 2010.
  1. Nov 27, 2010 at 8:24 PM
    floger70
    floger70 [OP] Young Taco
    Brett
    Waverley, Nova Scotia
    2000 Taco, 4cyl, reg cab shorty.
    tundra front springs 3" lift chev half ton rear springs 3 inch lift magnaflow muffler cb 33" kuhmo mud terrains pioneer deck. bilstien 5100
    just noticed this today when my buddy and i went to go find some mud. my 2000 tacoma has a blinker issue. the drivers side blinker light is on in my truck. not flashing but steady on. now out side my truck its the same thing. just a steady on bulb. even if i put the left blinker on nothing changed. i can put the right blinker on and that works but the left one still stays on. also my 4 ways wont work just lights up both lights and they both stay on.
    any ideas?
    relay maybe?
    thanks
    brett
  2. Nov 27, 2010 at 8:31 PM
    Snipe
    Snipe Well-Known Member
    Pacific NW
    08 TRD Off Road
    I think you have a bulb burned out on that side
  3. Nov 27, 2010 at 8:35 PM
    floger70
    Brett
    nope. bulbs are both on. front and back. just dont blink when i have the blinker switch on inside just stay on steady and even when i have it turned off it stays on steady. just will not shut off unless i shut my lights off
  4. Nov 27, 2010 at 8:41 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    None of the blinker lights would normally have anything to do with whether your headlights or just your parking lights were turned on or not. Right?
    Check your brake lights/ tail lights for burned filaments. You'll probably have to pull all these bulbs to inspect them to be certain. This includes the blinkers.
  5. Nov 27, 2010 at 8:46 PM
    floger70
    Brett
    all the bulbs are fine and in perfect working order. i tried switching them all around. i tried cleaning the contacts in where the bulbs sit. still the same thing. i have no left blink just more or less a left hand yellow driving light lol but front and back haha
  6. Nov 27, 2010 at 8:52 PM
    timmo
    timmo Well-Known Member
    Tim
    OKC
    2010 doble cab 4wd sr5-silver
    yeah, maybe relay. my experience with bad bulbs has been, due to unbalanced load, a faster signal blinking or steady on but when a relay sticks you can get some silly effects. wish i could tell you where that relay is though!
  7. Nov 27, 2010 at 8:54 PM
    timmo
    Tim
    OKC
    well hey, here's this much: a relay's job is to switch from one state to the other and back and forth. if it's stuck in on state then that's all it's gonna do. does that apply at all?
  8. Nov 27, 2010 at 9:01 PM
    floger70
    Brett
    yea but shouldnt it only do that when i actually turn the blinker on? this stays on when i just turn my lights on regardless of whether i turn the signal light on or not and even when i turn the other side on (which works fine) the other one doesnt shut off.
  9. Nov 27, 2010 at 9:06 PM
    Yoytoda
    Yoytoda The Little Truck That Could
    Roland
    Big Bear,CA / Upstate NY(Saratoga)
    2010 Tacoma Regular Cab 4x4
    completely stock
    sounds like the switch inside the stalk is stuck or broken, maybe. doesnt explain why the other side still works ok
  10. Nov 27, 2010 at 9:07 PM
    Yoytoda
    Roland
    completely stock
    not really because the other side works ok... both turn signals share a flasher
  11. Nov 27, 2010 at 9:09 PM
    Yoytoda
    Roland
    completely stock
    the 4 ways are on a different flasher... unless your truck has a flasher module... then it could be a bad one of those, try that first
  12. Nov 27, 2010 at 9:10 PM
    floger70
    Brett
    well the 4 ways dont work either. when i put those on all that happens is both stay on and dont blink lol.
  13. Nov 27, 2010 at 9:39 PM
    Yoytoda
    Roland
    completely stock
    looks like you have old style flashers... the system should be simple to troubleshoot... you could have a bad ground on the driverside too
  14. Nov 27, 2010 at 9:41 PM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    did you check the blinker fluid? Sorry I have nothing to add
  15. Nov 27, 2010 at 11:20 PM
    Beerrun
    Beerrun Well-Known Member
    Jon
    Spokane WA
    10 Sedan Sport LB
    Fog light rewire- debadge- front window tint- 5100's @ 1.75- Toytec 1.5 AAL- Avid sliders- 4x4 lighted switch- Sockmonkey decals- Truxedo low pro QT cover- Weather Techs- Back up light Mod. Diff. breather mod. OEM roof rack-Yakima bars. HomerTaco grill. Hella Black Magic Lts. WT vent visors.
    I'm with Yoytoda. I think you have a ground problem on that side. I'd try grounding the light socket base with a jumper wire and see if the dash light goes out.
  16. Nov 27, 2010 at 11:22 PM
    Yoytoda
    Roland
    completely stock
    yup,
    take the bulb out make sure the socket is clean and check the ground wire or make a jumper for both light sockets...
    i had a bad ground on my k5 and it did the same thing...
  17. Nov 28, 2010 at 7:41 AM
    floger70
    Brett
    Ok thanks guys. I'll give that a try and double check everything
  18. Nov 28, 2010 at 7:55 AM
    RAT PRODUCTS
    RAT PRODUCTS Well-Known Member
    Farmington, MN
    Cummins Coal Roller
    Smokin with a smarty.
    I would try pulling the plug from the back of the hazard button and cleaning it. If it is not plugged in, the turn signals don't work at all. There might be something going on in the switch harness that's not allowing that part to shut off.
  19. Nov 28, 2010 at 12:37 PM
    floger70
    Brett
    okay cool. ill try that too.
  20. Nov 28, 2010 at 1:52 PM
    floger70
    Brett
    pulled the 4 way switch out and nothing happened. when i turn my lights off both blinkers front and back on both sides work perfectly. and when i have my lights off with my 4 ways on they work fine also. when i turn my park lights or my headlights on that is when this stupid light comes on and stayes on. I removed the bulbs front and rear again and cleaned everything again and put it all back again. also i checked all the fuese and relays and they are all working properly and none are blown.
    anyone got anything else? haha
