Weird but quick question about air fresheners lol
Discussion in '1st Gen. Tacomas (1995-2004)' started by Carter Tacoma 03, Mar 15, 2021.
  1. Mar 16, 2021 at 2:43 PM
    Caslon
    Caslon Well-Known Member
    2003 Base Cab. 2 whl drive. 5 speed
    Some states you’re not allowed to dangle stuff off your mirror, Sight hazard. Arizona I think.
  2. Mar 16, 2021 at 2:57 PM
    RysiuM
    RysiuM Well-Known Member
    Rysiu
    Was Golden State, now Poland EU
    1995 4x4 LX Ext Cab, I4 2.7, MT, 335K miles
    DD Deck+backup camera, LED DRL, All LED except H4 Hella
    No need for "stink killer" if the truck does not stink in the first place. What all these "air fresheners" do is adding a stronger stink, to the air, so you don't smell the original stuff.
    The whole idea of the fresh air in the truck, is to not have the stink in the first place. Make sure you AC evaporator is clean from all dead leafs and bugs, get a good steam cleaning to you upholstery, especially the driver sit, as it is used most often, and for God sake, stop farting in the car. Every fart into your sit sprays a micro particles of shit into the cushion, and they stay there for a very, very long time. How do I know? You don't want these details :D
    jnossoff, paetersen and vtown like this.
  3. Mar 16, 2021 at 3:24 PM
    ALI3N_123
    ALI3N_123 ( -_・)ᡕᠵ᠊ᡃ່࡚ࠢ࠘⸝່ࠡࠣ᠊߯᠆ࠣ࠘ᡁࠣ࠘᠊᠊ࠢ࠘
    Eric
    Austin, Texas
    2021 Silver TuRD Squirt DCSB 4x4 // 2008 Black Rusty Shitbox DCSB PreRunner
    I used to smoke in my truck but then quit and kept the cigarette smell in my truck. Took it to a detailing place and their Ozone machine took care of it in one night.
    SSTacomamama likes this.
  4. Mar 16, 2021 at 3:29 PM
    plurpimpin
    plurpimpin Well-Known Member
    PDX
    2010 TRD Off Road 4x4
    “new car smell” air fresheners always crack me up because new car smell is just all of the plastics off gassing and releasing volatile organic compounds (aka toxic fumes)
  5. Mar 16, 2021 at 3:30 PM
    JaxPearlTaco
    JaxPearlTaco Amateur Decision Specialist
    Brian
    Jacksonville, FL
    1997 Ext Cab 4x4 5 speed 3.4
    N/A
    We've got one of those at my shop and I use it about once a month, always leaves me lightheaded even after I let it air out :rofl:
  6. Mar 16, 2021 at 3:32 PM
    LarryDangerfield
    LarryDangerfield One Larry a day keeps the money away ™ Moderator
    Tyler
    Northern Wisconsin
    Black 2020 Nightshade Edition 4Runner
    Oh there will be some mods all right
    @Itchyfeet do you know this man?! I legit thought it was you at first.
  7. Mar 16, 2021 at 6:02 PM
    Caslon
    That foam spray you spray up the AC drain tube works. Turns to foam at the condenser area, then turns into a liquid and drains out. Drained out a lot of brown nicotine smoke residue. It’s called Kool-It AC cleaner. $16. Bought it at Napa Auto parts store. They may have to overnight it to your local Napa store.
  8. Mar 16, 2021 at 6:39 PM
    Carter Tacoma 03
    Carter Tacoma 03 [OP] Well-Known Member
    Carter
    2003 Toyota Tacoma Xtracab Prerunner 2WD 2.7L L4
    Does it fit on the first gen vents tho?
  9. Mar 16, 2021 at 6:40 PM
    Carter Tacoma 03
    Carter
    First gens don’t have a cabin air filter they only have an engine one lol
  10. Mar 16, 2021 at 6:41 PM
    Carter Tacoma 03
    Carter
    Don’t have ac :(
  11. Mar 16, 2021 at 6:46 PM
    Caslon
    I thought most all first generations came with AC as standard equipment. I stand corrected. Great idea to spray something through the air intake. I’d never spray Lysol through my air intake. I don’t have a bloody cold. Spray something like Fabreze that has odor killing enzymes. 1950’s Lysol does not. Screw that. Not sure why so many suggest that spray.
  12. Mar 16, 2021 at 6:50 PM
    Tacoma13_NC
    Tacoma13_NC Well-Known Member
    2013 SR5 4x4 DCSB 4.0L (Black) OTT
    Bilstein 6112/5160; JBA HD UCAs; 1.5" 3-Leaf AAL's w/ overload; OME CB drop; RCI aluminum skids w/ catalytic converter shields; Wheeler's U-Bolt flip kit with Superbumps; TRD Pro 4-Runner Wheels; BFG KO2's (265/70/17); Diode Dynamics SS3 Sport (Yellow) fogs; CaliRaised 32" hidden light bar; Morimoto XB LED headlights with upgraded HD harness; Unifilter mod; Rear-View mirror riser bracket; Truxedo Lo Pro tonneau cover; New OEM color-matched grille; Bumpershellz color-matched rear bumper cover; Ultra-Gauge MX 1.4 w/Spiker mount; Baja Designs S2 Sport Ditch Lights with SDHQ brackets; Fog Light Anytime Mod; Overland Tailor Tune (OTT)
    It's universal, it should fit on any flat bladed vent. I'm not sure how the 1st Gen vents are configured though so I can't say for sure.
  13. Mar 16, 2021 at 7:17 PM
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    So, I need to stop driving the truck every time I need to release a bit of pressure????
    BTW, the curious want to know the details. Are you an expert seat sniffer??
  14. Mar 16, 2021 at 7:47 PM
    paetersen
    paetersen Well-Known Member
    mix up a spray bottle of bleach and water (mostly water) with a little bit of dish soap if you want a clean scent. turn the cabin fans on high and mist the mixture into the air intakes by the windshield wipers. We do this to get dead mouse smell out of the heater box and ducting if one died in there. I do this a few times a year because the PO was a smoker and every once in a while that musty smoked in smell comes back. BTW, the air fresheners are all carcinogenic.
    Caslon likes this.
  15. Mar 16, 2021 at 8:19 PM
    #35
    Caslon
  16. Mar 16, 2021 at 8:20 PM
    #36
    Caslon
    Follow that up with Fabreze, thru the hood area air intake vents, fragrance of your voice. Fabreze kills odors, Lysol doesn’t.
  17. Mar 16, 2021 at 8:34 PM
    #37
    Carter Tacoma 03
    Carter
    Yeah the ax is weird so the button where “ac” goes is just solid liek there is a mold for it if you know what I mean but the button isn’t there. I can put it on the cold setting though like the blue but I don’t know how that is different from ac maybe I just don’t have it but my truck can blow cold air? I’m still not sure how that works but thanks.
  18. Mar 16, 2021 at 8:37 PM
    #38
    Carter Tacoma 03
    Carter
    Yeah like I said I don’t have ac she only blows cold air I understand what you mean but I was honestly just asking if these air fresheners fit in the first gen vents. My truck doesn’t smell at all I keep it in great condition I’m a clean freak lol not a crumb but thanks for the suggestions
  19. Mar 16, 2021 at 8:41 PM
    #39
    Carter Tacoma 03
    Carter
    I understand this but I don’t but it’s also funny lol
    jnossoff likes this.
  20. Mar 16, 2021 at 8:46 PM
    #40
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Direct injected Texas Roadhouse ribs and bloomin onion scent into my seat, today
    Wulf and nictarine like this.
