Weird buzz sound under hood
Discussion in '1st Gen. Tacomas (1995-2004)' started by swdavis, Nov 29, 2016.
  1. Nov 29, 2016 at 12:04 PM
    swdavis
    swdavis [OP] Do or Don't- there is no trying.
    Plant City, Fl.
    96 Tacoma SR5, 3.4L ,R150F
    None
    I have a weird buzz sound under the hood that is constant. The engine is off and I have unhooked the battery, yet it is still there. I believe it is electrical, but with battery unhooked it still does it. You can hear it inside the cab as well, just very faint.
    The truck is a 96 3.4L 4x4.
    Just in case the video does not upload, the sound is near the under hood fuse box (drivers side) right behind the battery.
    If you have dropbox, this link may work...https://www.dropbox.com/s/605m0gbiqqdu5ah/File Nov 29, 15 00 40.mov?dl=0
  2. Nov 29, 2016 at 12:08 PM
    vasinvictor
    vasinvictor Junkie
    Drew
    Arkansas
    '01 DCSB racetruck
    hx35 turbo, AEM F/IC, Transgo, custom converter, CalTracs, Elocker, 2-4" drop, 4x4 conversion (2023) on a new purple powdercoated fram, 255/55r18 street, 255/60r16 M&H Racemasters, 7.6 at 91
    Check all over the big black box behind the fuse box. That's your EVAP can and it will vent off excess gas tank pressure. There are a couple VSVs in there that open and close. See if you can isolate the noise a little better. Maybe use a length of larger diameter vacuum hose. Put one end to your ear and search around with the other.
    swdavis[OP] likes this.
  3. Nov 29, 2016 at 12:13 PM
    swdavis
    Plant City, Fl.
    None
    I will indeed.
  4. Nov 29, 2016 at 12:36 PM
    Dirty Pool
    Dirty Pool FLIES ON THE FRIES, KETCHUPS WATERED DOWN
    59.4 Miles, 56.67° NE Of Moab
    99 XCAB V6 MT TRD
    Dirty Pool rear bumper/air tank with integrated spare CV shaft storage, DP customized TJM front bumper, 8000 lb Ramsey/Technora rope, E-locked, Extended breathers with front diff catch can, PCV catch can, SAWs with DP heim joint seals, DP custom 6 leaf rear springs/Billies, DP custom skids, 2lo, Gray wire, Cap, Bed Rug, Black steelies, 01 Center console, Map lights, Disraeli gears
    Might be your issue since you disconnected the battery.
    https://www.tacomaworld.com/threads/buzzing-type-sound-coming-from-under-hood.284297/#post-7096881
    swdavis[QUOTED][OP] likes this.
  5. Nov 29, 2016 at 1:15 PM
    swdavis
    Plant City, Fl.
    None
    Thank you gentlemen. It is annoying, but nothing I can't live with.
