Weird clunking noise!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by GKsDad77, Jan 19, 2022.
  1. Jan 19, 2022 at 10:33 AM
    GKsDad77
    GKsDad77 [OP] New Member
    Leroy
    2021 grey Tacoma SR5
    None
    Hey fellas, new here to the forum. I have a 2021 tacoma SR5 with 9800 miles and the same weird clunking noise many of you have had. I will be taking the truck back to the dealer on Friday for the second time for this noise and now have a few items to have the dealer check out thanks to you guys, much appreciated! This is my second tacoma, first one was a 1997 manual 2wd drive single cab that I could not kill no matter how many times I loaded it with 3/4 ton of construction materials. I love tacomas and hope this new one is as good to me as my first one! I cried the day I had to get rid of 1997, so many great memories!
    Leroy
  2. Jan 19, 2022 at 10:42 AM
    cryptolime
    cryptolime Here to Help
    Wilmington, NC
    2021 SR 4x4 2.7L
    what conditions does the clunk require?
    shakerhood likes this.
  3. Jan 19, 2022 at 10:46 AM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    What did the Dealer repair the first time you took it in, should be on your receipt?
  4. Jan 19, 2022 at 11:14 AM
    Sroberts
    Sroberts Well-Known Member
    Sean
    Vancouver, Canada
    2017 Tacoma TRD O/R Blazing Blue DCSB
    Is this a drivetrain clunk?
  5. Jan 19, 2022 at 11:19 AM
    Nw_nomad
    Nw_nomad Well-Known Member
    2019 Tacoma Trd offroad 6MT
    Is your new tacoma a manual? Sometimes mine makes noise similar to pans knocking together when I depress the clutch off road.
  6. Jan 19, 2022 at 11:27 AM
    Off Topic Guy
    Off Topic Guy 2023 Trophy Points - Runner Up
    Couple questions; is the truck completely stock? What mods have you done? When do you hear the clunk? (at speed, going over bumps, turning wheel, applying brakes, etc?)
  7. Jan 19, 2022 at 2:19 PM
    GKsDad77
    Leroy
    None
    Completely stock, no mods, hear it more at low speeds but still there at mid speeds. It is an automatic trans so not a clutch issue. Nothing was repaired the first time, they said everything was fine and sent me on my way, the truck only had 5500 miles on it the first time I heard it. It sounds to me like some sort of suspension clunking. Other forums said body/ cab bushings worn out already and others say LCA not torqued enough. I'll mention both to service on Friday.
  8. Jan 19, 2022 at 2:23 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Line the inside of the accumulator heat shield with sound insulation, like Noico. It will all but eliminate that sound. There is a TSB that installs a similar thing.
    I'd bet on front cab mounts. I installed some Energy Suspension universal ones and have been happy for 10k since.
    Nw_nomad[QUOTED] likes this.
