Weird complete loss of power. Help?
Discussion in '1st Gen. Tacomas (1995-2004)' started by TuckinTaco, Oct 14, 2021.
  1. Oct 14, 2021 at 3:41 AM
    TuckinTaco
    TuckinTaco [OP] Member
    BFE Colorado
    ‘98 Tacoma SR5
    98 Tacoma 3.4L manual. 210k miles
    Little background on truck: I bought the truck from a military Kid a few months ago. He Had paperwork for a bunch of work, new clutch, less than 40k on timing belt, new MAF sensor a few months ago after I first got it.
    ANYWAY…
    Tonight while driving home on the free way I get to about 75ish miles and the truck kinda dies for a second. I’m talking .5 seconds maybe. During that split second the check engine turns on quicker than a blink of an eye, but I lose no on electrical power to anything in the truck. Just complete loss of engine power for less than a second. I almost thought someone bumped me from behind lol. I tried recreating the problem multiple times with success. Seems fuel related because when I give it a certain amount of gas no matter what gear it does it. But if I put it in neutral, and match the rpms it was doing it while in gear I get no issue. Today is the coldest day we’ve had here in my city this fall so I’m not ruling out temperature related, but I’m assuming it’s fuel related, here is my reasoning, please lmk if I’m wrong: when giving it gas In neutral there isn’t as much load as there is when giving it gas in gear attempting to move the truck.
    Usually I wouldn’t be too concerned because I have a spare truck, but the fiancé is driving it since her car is in the body shop after getting t boned. Usually I’d park it and try to figure it out myself, but obviously I’m not in the situation to do that now.
  2. Oct 14, 2021 at 6:05 AM
    Truckntran
    Truckntran Well-Known Member
    1996 and 1998 Tacoma 2wd
    High mileage work trucks
    Throttle position sensor?
    wilcam47 likes this.
  3. Oct 14, 2021 at 6:12 AM
    teamhypoxia
    teamhypoxia MichelinMan
    Colorado
    '12 DCSB TRD OR
    You said check engine light came on.....
    You need to pull that code. Most auto parts stores will do it for you if you don't have a code reader.
    JudoJohn, wilcam47 and 0xDEADBEEF like this.
  4. Oct 14, 2021 at 6:26 AM
    Clearwater Bill
    Billy
    Largo Florida
    Yep, the code that was set is your starting point for diagnosis
    JudoJohn, INSAYN and wilcam47 like this.
  5. Oct 14, 2021 at 8:14 AM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    The code should help!
    Most all fuel related problems unless it is causing a Miss will not trip a code .
    Best guess the ECM drops out for a second.
    If there is no code your seeing the check engine light because the ignition is in the run position and the engine is not running the engine starts the light goes out.see any of the other normal warning lights ??
    Manual transmission a spinning engine compression start
    just a guess I am curious what plays out.
  6. Oct 14, 2021 at 11:59 AM
    TuckinTaco
    BFE Colorado
    ‘98 Tacoma SR5
    No codes with my outdated matco scan tool. The scanner has always been unreliable so I checked with my cheap on and still no codes. I checked all grounds I think, and checked fuse box for loose wiring. The ground wire nut out of fuse box (o think was ground I was rushing before work) was not tight, but not loose. I got about 1.5-2 turns out of it with 1/4 ratchet. I know enough about cars to get by, but I’m a diesel mechanic 2nd year in so some gas car stuff I don’t know. Any suggestions on some diagnosticss I should try to trouble shoot short.
  7. Oct 14, 2021 at 12:01 PM
    TuckinTaco
    BFE Colorado
    ‘98 Tacoma SR5
    To clarify the check engine doesn’t stay on, it comes on for a fraction of a second like when you kill a car.
  8. Oct 14, 2021 at 12:02 PM
    eon_blue
    Azusa, CA
    What kind of MAF sensor did you install, Denso/OEM or aftermarket?
  9. Oct 14, 2021 at 12:15 PM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    Sorta sounds electrical to me. That flicker of the check engine light is the thing thinking the engine has died completely. I would start with the basics like a loose battery cable and check all the connectors.
    JudoJohn, MalinoisDad, INSAYN and 2 others like this.
  10. Oct 14, 2021 at 12:17 PM
    homegrown_xt
    homegrown_xt Well-Known Member
    Sonoma County
    1996 Tacoma Xcab 4x4 V6 MTM
    Rancho Quick lift. Wheelers Off Road Progressive AAL with Rancho RS9000's, braided brake lines & clutch line. BFG 32x11.50 15 All Terrain Tires Deck Plate Mod. Flowmaster 60 series muffler and Marlin Crawler Short Throw Shifter.
    Is it possible the timing gear key way on the crank got wallowed out causing the gear to move and causing erratic cam timing changes?
    Pscdouglas likes this.
  11. Oct 14, 2021 at 12:27 PM
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    02 Pre Runner supercharged 4cyl
    TRD supercharger , Doug Thorley header , K&N CAI 265/75-16 Toyo open country mud terrain , 15x8 Method Racing wheels , Rancho 3" lift , 4.88 gears , Detroit Locker
    Cam or crank sensor failing
    wilcam47 and DrZ like this.
  12. Oct 14, 2021 at 12:37 PM
    TuckinTaco
    BFE Colorado
    ‘98 Tacoma SR5
    UPDATE: Just got to work, tried to duplicate issue countless times. Giving it more throttle on large hills in 4-5th gear. Also tried going up to 5k in all the gears flooring it, could not replicate issue. It’s colder today, but not as cold as last night, I will attempt to duplicate the issue tonight when it’s colder on way home.
    I wanna thank y’all for the quick replies so far, didn’t think I would get many opinions (my first post). Thank you guys!!! Hopefully it was just a weird occasion, likely not, but hopefully. I assume it’ll do it again tonight haha.
  13. Oct 14, 2021 at 2:08 PM
    Bivouac
    An electrical gremlin causing the engine to stall then because you have a manual transmission restart.
    Does this truck have a tach? does it drop to zero and rebound when this happens?
    Since you state no other electric fails this is in the ignition /ECM area.
    Good Luck!! Intermittent problems are a pain.
  14. Oct 14, 2021 at 3:56 PM
    Glamisman
    Glamisman Well-Known Member
    at this point if it were me I would start by wiggling wires and harness's, not jerking on them, moving them with an index finger in an attempt to replicate road vibrations. Start at the battery positive post and follow each harness and wiggle it. If nothing in the engine compartment then take the knee panel off and start at the ignition switch harness and do the same. As mentioned above it is something that is more than likely ignition related.
    Dm93 likes this.
  15. Oct 14, 2021 at 4:13 PM
    USMILRET
    USMILRET Tacoma Owner
    1998, 2007 and 2020 Tacoma
    I suspect that you may be experiencing a temporary lack of fuel pressure at a certain engine load. I am wondering if an automotive tech would still perform a fuel volume test for your 6 cylinder engine or if they strictly go off of a fuel pressure test. Anyway if you are starting to develop a fuel restriction these would be the components that I would look at although in no particular order. In tank fuel pump, fuel filter, fuel injectors, fuel pressure regulator.
  16. Oct 14, 2021 at 4:17 PM
    Wulf
    Wulf no brain just damage
    rock raisin
    Check the connector to the ignitor mounted on the passenger fender.
    If it is loose the engine may stall over bumps that jostle the connection
    0xDEADBEEF likes this.
  17. Oct 14, 2021 at 8:03 PM
    TuckinTaco
    BFE Colorado
    ‘98 Tacoma SR5
    I don’t think the tach moved really.
  18. Oct 15, 2021 at 2:09 AM
    TuckinTaco
    BFE Colorado
    ‘98 Tacoma SR5
    UPDATE: Tonight was as cold as last night, and it did it a few times on way home. I payed attention to as many variables as I could tonight.
    -Hitting bumps didn’t seem to do anything, sometimes it would do it, but I hit some bigger bumps on purpose and when I did that nothing happened. I’m not ruling out bad wire or connection and plan to try the thorough check while jiggling wires as someone suggested above.
    -It happened in both low and high rpm, gear, and speed, but seemed much more common when I give it more fuel at higher mph. Consistent Rpm doesn’t seem to have to much to do with it while cruising. It seems like when I give it what I’d like to call passing throttle (passing slow driver) it likes to sometimes occur 7/10 times. So this again is making me think fuel related.
    -To clarify I didn’t lose power to anything, headlights, radio, heater, interior lights, nothing turned off. The tac, Speedo, fuel, and other gauges did not move, all acted as normal. As I said before the check engine illuminates for less than a quarter of a second, gone as fast as it came.
    I’m just puzzled, what would cause it to do it in 25 degree weather but not in the 60ish degree I had earlier today? I’ve been brainstorming all day.
    I’ve been thinking of better ways to describe it to y’all. Imagine driving 65mph. And someone presses your brake pedal down 25-50% and let’s go all within a second. Almost like I’m brake checking someone.
  19. Oct 15, 2021 at 2:18 AM
    TuckinTaco
    BFE Colorado
    ‘98 Tacoma SR5
    cable driven I believe. Unless you’re making a joke. I’m confused haha.
  20. Oct 15, 2021 at 2:35 AM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    My bad. Drive by wire. In the old days there was a direct link between the gas pedal and throttle. Nowadays its drive by wire. Somewhere 2000-2005 vehicles went drive by wire.
