Weird coolant issues, I'm stumped
Discussion in '1st Gen. Tacomas (1995-2004)' started by 5000fingers, Mar 14, 2018.
  1. Mar 14, 2018 at 8:34 PM
    5000fingers
    5000fingers [OP] Well-Known Member
    Bruce
    Bay Area, CA
    '95 Tacoma, 6 cyl.
    Please help me figure out what's going on, my Taco ('95, 200K miles) is sick.
    Clue #1: new radiator about 6 months ago
    Clue #2: hissing, bubbling sounds coming from behind the dash upon acceleration
    Clue #3: reddish brown goo accumulating under the radiator cap and in the overflow tank.
    Clue #4: previously green coolant is now the color of piss or flat beer
    Clue #5: I am not losing coolant, at least not noticeably
    Clue #6: Assuming from Clues 1-5 that I have a head gasket leak of some sort, just today I ran a combustion gas test (the fluid type) of the coolant. But the fluid stayed blue, indicating no exhaust gases in the coolant.
    Huh? What could be happening here?
  2. Mar 14, 2018 at 8:46 PM
    Markcal
    Markcal Well-Known Member
    It sounds like you still have air in your cooling system from the radiator replacement.
  3. Mar 14, 2018 at 8:46 PM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    The hissing bubbling behind the dash sounds to me like you didn't have your heater on when you burped the air from the coolant system when refilling and now have air trapped.
    Reddish brown goo sounds like your transmission cooler from the old radiator was starting to leak.
    Look up pink milkshake.
    Toyota should never have green coolant and if you switch to red with a simple drain and fill and no water flush and block draining your getting a chemical reaction of the two mixing, not good.
    It's still possible you have a small head gasket leak.
    Miles on truck?
    What Motor?
    Manual or automatic?
  4. Mar 14, 2018 at 8:50 PM
    El Taco Diablo
    El Taco Diablo Professional Pinstriper
    Matt - KN6DZP
    Hughson, CA
    Impulse Red DC, 5vz-fe, 4wd swap, LT, dual case, F/R locked
    Just 3 tons of fun!!!
    You mentioned green coolant. Did you THOROUGHLY flush the coolant system of the Toyota red coolant before adding the green coolant?
    Toyota coolant does not mix well with any other coolant. The mixture will cause a lot of the symptoms you're talking about. It will turn to a light reddish brown mud looking crap. If it is backing up in the heater core, that would be why you are hearing things go on under the dash.
    Flush your system. I would add a flush agent and drive it a few days. Then drain. Put a flush in again fill with distilled water. Run the engine to operating temp and then let it idle for a few minutes... then shut it off and let that sit overnight.
    Then I would flush the heater core opposite of the normal flow of the coolant till the water running through runs clear... then flip the flush and run it the normal direction of flow, till the water runs clear. Put it all back together and flush the system again.
    You need to get as much of that red out as you can if you want to run green.
  5. Mar 14, 2018 at 8:58 PM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    I'm 99.9999999% sure that reddish goo you're seeing is the Toyota red mixed with the green.
    That is the cheapest and easiest thing to fix (and the most likely cause). I would eliminate that as a possibility before freaking out and tearing off cylider heads.
    The pink milkshake is not as common a problem as people make it out to be... yet it seems to be the very first thing some people want to suggest as the problem.
  6. Mar 14, 2018 at 8:59 PM
    Markcal
    It amazes me that Prestone can claim on the front of their 1-gallon jugs that it mixes with all color antifreeze. I'm surprised someone has challenged that claim for causing damage yet.
  7. Mar 14, 2018 at 9:00 PM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    NO DOUBT! +1000
  8. Mar 14, 2018 at 9:05 PM
    roger2chris
    roger2chris Well-Known Member
    Roger
    Pineville NC
    2018 Toyota Tacoma SR5 4x4 MGM DCSB
    do you have heat in the truck and is it over heating and do you see white smoke
  9. Mar 14, 2018 at 9:10 PM
    Markcal
    Why I say that is I came from a 1988 Nissan truck and used Prestone for all 18 years and still had some down cellar, so according to their claim I did just that and I'm 100% sure it's what caused my water pump to leak at 30,000 miles. I ran a flush/cleaner through while doing multiple distilled water flushes too, to get all the green out and went back to the factory recommended coolant.
  10. Mar 14, 2018 at 9:15 PM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    I was totally agreeing with you. Prestone should not make the claim they mix with ALL coolants... They aren't the only ones that make that claim though, NAPA makes the same claim with their coolant and others do so as well.
    Green coolant WILL NOT mix properly with Toyota red... ever.
    I run Prestone in my coolant system, because it cools better than Toyota red. I just made sure to get all the Toyota red out before putting in the Prestone.
    tan4x4 and Markcal[QUOTED] like this.
  11. Mar 14, 2018 at 10:05 PM
    5000fingers
    Bruce
    Bay Area, CA
    '95 Tacoma, 6 cyl.
    OK, I really don't think it's the Toyota red anti-freeze mixing with green, because I've never used Toyota red anti-freeze! And yes, I did use a flush agent before I replaced the radiator.
  12. Mar 15, 2018 at 3:40 AM
    License2Ill
    License2Ill Woke like a Coma Toyota Tacoma
    Ian
    It's a dry heat thou, AZ
    2004 SC'd 5VZ DC 5spd 4x4 TRD.GOV
    Bailing wire & Duct tape
    Pretty bold statement. Got any proof to back that up?
    Key-Rei likes this.
  13. Mar 15, 2018 at 7:54 AM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    Well... Whether you used red or not, Toyota did. So at some point there was red in your cooling system. And if you didn't flush ALL of it out, before using green the sludge is what happens.
    When I say flush the system, I'm not just saying flush it once and you are done. You have to flush the entire system. Even when you completely "drain" the system, there is still residual coolant in the heater core and all throughout the block. You have to flush and then flush and then flush again etc to get it clean enough.
  14. Mar 15, 2018 at 9:59 AM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    I have personal experience. When I bought the truck (a 2 year old lease return) 14 years ago, It was having problems with over heating. I flushed the system thoroughly and changed to Prestone. It ran cooler immediately... not as cool as I would have liked but cooler, without doing anything else in the cooling system. Now that I have replaced most of the cooling system and I'm still running Prestone, the truck runs the way I think it should.
    Which is more proof than anyone can provide that says otherwise.
  15. Mar 15, 2018 at 4:03 PM
    License2Ill
    Ian
    o_O
    :rolleyes:
    :thumbsup:
    :rofl:
    :boom:
