Weird dash sound isolated under\behind glovebox.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by anthonywilk, Mar 29, 2017.
  1. Mar 29, 2017 at 4:42 PM
    anthonywilk
    anthonywilk [OP] Active Member
    Anthony
    Canada
    2008 TRD sport
    3'' toytec lift, SCS Stealth 6 rims, 285\70\17 Kelly Safari tsr
    I've done some searching but I cant seem to find anyone who's that this same problem as me, I have an 08 Tacoma, double cab short box 6 spd, 3" lift, 285\70\17's. now, my issue is that when I take off from a dead stop more so on flat or incline (something with a bit of load) I get this weird almost deep rattle like if you were to take your tongue and put it on the roof of your mouth and blow out gently making a noise. it sounds like its coming from behind the glovebox, as far as I can tell you cant feel the vibration you can just hear it. I'm hoping someone else has experienced this or has a general idea on where to start looking, I can post a video to try and capture the sound if need be. thanks
  2. Mar 29, 2017 at 4:45 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    Have you pulled the glove box out?
    Maybe it's something dumb like the dampener for the glove box coming loose and banging around.
  3. Mar 29, 2017 at 5:09 PM
    anthonywilk
    Anthony
    Canada
    2008 TRD sport
    Okay I've attached the video, I took the glovebox right off as well as the dampener and went for a little drive, I apologize for the drone in the video (truck is straight piped) I was completely off the throttle, the noise is definitely evident in the first takeoff
  4. Mar 29, 2017 at 5:17 PM
    anthonywilk
    Anthony
    Canada
    2008 TRD sport
  5. Mar 29, 2017 at 5:22 PM
    RacecarGuy
    RacecarGuy Well-Known Member
    Houston, Texas
    '12 DCSB OR
    Pelfreybilt front and rear HC bumper w/swingout, BAMF LCA Skids, BAMF Diff skid, Pelfreybilt IFS and Trans skid, RCI gas tank skid, Bronze SCS F-5's, Icon RR's ext travel, Dakar leafs, Archive Garage shackle flip
    Have you pulled out the cabin air filter and see if there is junk in it, or something rattling around in there?
  6. Mar 29, 2017 at 5:29 PM
    anthonywilk
    Anthony
    Canada
    2008 TRD sport
    I did, the filter is almost new I just replaced it, np junk floating around in there either, noise is still there with or without the filter in there :facepalm::facepalm:
  7. Mar 29, 2017 at 5:31 PM
    desertrunner24
    desertrunner24 Well-Known Member
    Jake
    Fresno , CA
    2011 TRD offroad 4x4
    Some
    check your intake tube into the inner fender. they raddle when the foam gets worn out around it.
    RacecarGuy likes this.
  8. Mar 29, 2017 at 5:42 PM
    anthonywilk
    Anthony
    Canada
    2008 TRD sport
    I will do that right now thanks. come to think of it, it almost makes an acoustic type sound
  9. Mar 29, 2017 at 5:44 PM
    desertrunner24
    Jake
    Fresno , CA
    Some
    yeah mine had a similar noise with my stock cai. when I put a trd on, the noise went away
  10. Mar 29, 2017 at 6:11 PM
    anthonywilk
    Anthony
    Canada
    2008 TRD sport
    bingo! pretty sure that's the issue, looked and the foam is there but its not doing anything. I pulled that tube off and drove around the block and the noise went away! gonna head back out and come up with a solution, thanks for all the help guys
