Weird electronic “hum” while parked
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TxStVanWilder, Nov 10, 2018.
  1. Nov 10, 2018 at 11:30 PM
    TxStVanWilder
    TxStVanWilder [OP] The Pale Horse
    Tx
    2013 TRD Sport
    Ok so it’s starting to get “cold” here in Texas... Yes I know I know, spare me the guff Yankees. Anyways I’ve noticed either after sitting for a day or two and more often since it’s getting cooler outside that the truck doesn’t spin over as fast as it did when I first put the battery in (2 years ago). I attributed this just the first cold snap of the year, better get used to it...
    Today while doing some woodworking in the driveway with my wife we both heard a soft hum or electrical sound. It almost sounded like a home AC running outside, but a street or two over. Paid no mind to it at first. After turning off the power tools another time I heard it again, but I was standing closer to the truck. I could put my head near/under the rear fender and it sounded like a small pump or something was running. Wouldn’t guess the fuel pump would run or prime with no key in the ignition, but it was definitely coming from underneath the truck.
    I started the truck once and let it idle for about 20 seconds and shut it off, sound was gone. Went about my business.... Working with tools again later, turned them off and sound was back again...
    Couple things, 1, I’m wondering WTH this electronic “running” sound is and 2, I’m wondering if it’s the reason the truck doesn’t spin over as quick as in the past.
    Any insights?
    Truck is a 2013 TRD Sport 4 door long bed.
  2. Nov 10, 2018 at 11:32 PM
    tcjacado
    tcjacado Well-Known Member
    It's the fuel pump evaporative system.
    I married my tacoma likes this.
  3. Nov 10, 2018 at 11:32 PM
    Rusty1606
    Rusty1606 Active Member
    Smog testing. It pressures the gas lines i believe to check for leaks. Its normal. Mine catches me off guard sometimes
  4. Nov 10, 2018 at 11:33 PM
    TxStVanWilder
    Tx
    2013 TRD Sport
    Damn you guys are quick.
    Learn something new everyday.
    tcjacado likes this.
  5. Nov 10, 2018 at 11:34 PM
    tcjacado
    It usually pisses people off that sleep in the bed of the truck when camping.
  6. Nov 11, 2018 at 1:07 AM
    MolonLabeTaco
    MolonLabeTaco Well-Known Member
    Dude
    N. Texas
    '12 DC 4x4 OR
    I’ve spent probably 50+ hours standing next to my truck, with it not running, and have never heard this. Odd that it’s a common deal and I’ve never heard it.
  7. Nov 11, 2018 at 4:53 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    There is a vacuum pump under the bed that draws vacuum on the fuel tank/canister. Then it sits back and waits to see if the vacuum drops off. If it leaks down then it sets evap codes.
    Generally speaking, if the vacuum bleeds down very slowly it will set "evap (small) leak detected".
    If it bleeds down a little faster it will set "evap (large) leak detected".
    If the there is a wide open hole in the fuel tank (like the gas cap is left off) the vacuum pump will not be able to draw any vacuum at all and it will set "evap (gross) leak detected". Meaning, a leak that is too large to measure..
  8. Nov 20, 2018 at 4:46 PM
    hikerduane
    hikerduane Stove & lantern collector, retired
    Duane
    Meadow Valley, Jefferson USA
    '16 Blazing Blue Pearl TRD Sport AC V6 manual, tow pkg
    RCI sliders fuel tank skid plate, Softopper, tailgate insert
    First time I've heard mine today. Started the truck, let it run 10, 15 seconds, no more noise. Around 31,000 on the truck now.
    Duane
  9. Nov 20, 2018 at 11:53 PM
    buckhuntin-tacoma
    buckhuntin-tacoma Shed hunter
    Dennis
    Quincy IL
    2014 Spruce Mica Tacoma DCLB
    I’ve heard it on mine several times!!
  10. Nov 21, 2018 at 5:09 AM
    EF
    EF Well-Known Member
    Upstate NY
    2015 TRD Off Road Blue Ribbon
    If you open the gas cap to accelerate the venting during the sound it immediately stops. My 2015 does it, never caught my 2008 or 2003 doing it.
    Usually hear it at odd times if the night when truck has been sitting for hours.
  11. Nov 21, 2018 at 6:13 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    When the pump is humming it's not venting, its trying to draw vacuum on the tank and perform a leak test. You're not really hurting anything by taking the cap off but it will prevent it from running/completing its test.
  12. Nov 21, 2018 at 6:49 AM
    Crow Horse
    Crow Horse Well-Known Member
    Central NY
    2012 DCSB TRDOR
    That might be the SAI.....
    b_r_o likes this.
  13. Nov 21, 2018 at 8:02 AM
    hikerduane
    Duane
    What's the SAI? I don't read that many of the tech threads. Many explode with posts.
    Duane
  14. Nov 21, 2018 at 8:04 AM
    Crow Horse
    Central NY
    2012 DCSB TRDOR
    Secondary Air Injection pump.....
  15. Nov 21, 2018 at 8:08 AM
    hikerduane
    Duane
    Thank you.
    Duane
  16. Jan 13, 2024 at 6:09 AM
    PbrTallboy
    PbrTallboy Member
    David
    Minnesota
    2014 Tacoma V6 Access Cab 4WD TRD Sport
    I just heard this last night for the first time in ten years on my 2014 long bed Tacoma. I guess I was in the garage at the right time.
    Trucks at 100k and never heard this.
    Cold yesterday, like 5. Parked in garage and six hours later went to garage and heard humming from truck bed. Thought it was fuel pump? Went on for at least ten minutes. Got keys and with key turn to acc or on noise immediately stopped.
    truck started fine. No cels. No lights. Turn off. On again. No cel. ???
  17. Jan 13, 2024 at 10:46 AM
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    No, it's the evaporative emissions test as stated above. I've heard my wife's Corolla do it on multiple occasions when I step out into the garage in the evening. I've only ever heard my truck do it a couple of times.
    Yes, as you now know, it's normal.
    Dm93 likes this.
  18. Jan 13, 2024 at 11:34 AM
    PbrTallboy
    PbrTallboy Member
    David
    Minnesota
    So no need to freak out? Working as designed? It was running for like 10 minutes...is that normal?
  19. Jan 13, 2024 at 11:42 AM
    Tacoma Mike
    Southern Maine
    Normal.
    Sleep well….
    PbrTallboy likes this.
  20. Jan 13, 2024 at 11:45 AM
    PbrTallboy
    PbrTallboy Member
    David
    Minnesota
    Thanks, will do!
