Weird front end popping noise
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Hops, Mar 13, 2009.
  1. Mar 13, 2009 at 2:51 PM
    Hops
    Hops [OP] Well-Known Member
    Gabe
    south mississippi
    08 Silver Streak Mica Access Cab 4X4
    Shock and leaf spring TSB, Neoprene seat covers, weathertech digital fit floor mats, vent visors, bug shield, secondary filter removed, K&N drop-in filter, century camper shell, 265/75R16 ATM's...
    When i shift out of four wheel drive i often get a weird popping noise in the front diff. it seems to be really bad if the wheels are turned. Sometimes it is worse than others, anybody else have this problem?
  2. Mar 13, 2009 at 2:53 PM
    Jester243
    Jester243 rabble rabble rabble
    Dan
    Spokane, WA
    2016 Trail Premium 4Runner w/ KDSS
    I seem to get that only when I am on the gas when it shifts out of 4WD
  3. Mar 13, 2009 at 3:02 PM
    NumNutz
    NumNutz One of the original 7928
    Virginia Beach, VA
    07 Tacoma 4x4 - Kings, TC, Dakars, broken stuff
    Lots.
    It's normal. It will make that sound when you shift out of it. If you aren't on the accelerator it will be less violent but you aren't hurting anything.
  4. Mar 13, 2009 at 3:02 PM
    Jester243
    Dan
    Spokane, WA
    I figured everything is fine, I just don't shift out while hard on the gas.
  5. Mar 13, 2009 at 3:50 PM
    Hops
    Gabe
    south mississippi
    cool thanks guys, i noticed it was doing it at pretty low speeds, like under 5 mph which kinda made me nervous...
  6. Mar 13, 2009 at 4:10 PM
    Pster
    Pster Well-Known Member
    Charlotte, NC
    2006 Tacoma 4x4
    Bak Flip bed cover, shorty antenna, Peripheral iPod interface, Garmin 750 mount, add'l bed tie down rings, Westin nerf bars, hitch safe, tailgate lock, Ideal 1 3/4" turn-key clamp to secure tailgate from removal, Spare tire security cable, spare tire stainless air hose extender, Fumoto oil drain valve, Amp Research Bed X-Tender w/Schlage Cable Lock, bed mat, Redline hood struts
    I don't even shift into or out of 4 wheel drive anymore unless the truck is stopped, foot on brake and tranny in neutral. Very smooth, no sounds at all.
  7. Mar 13, 2009 at 5:37 PM
    squad314
    squad314 Thinks he's Steve McQueen
    Marc
    Into the mystic....(foggy Saint John, NB)
    TRD Sport+Leather 4x4
    Front 5100's @2.5", Rear 5125's with AAL. Light Racing UCA's, Factory hood deflector, Sirius Sportster 5, TRD air filter, Weathertech's f&r, "Hello Kitty" steering wheel cover.
    I think the wheels should be as straight as possible when shifting as well....try that too.
