weird 'hissing' or 'shushing' noise on acceleration?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tinystaco, Jan 18, 2014.
  1. Jan 18, 2014 at 11:05 AM
    tinystaco
    tinystaco [OP] Active Member
    12 Tacoma I4 5speed 4x4
    OK. I just traded my Silverado in on a 2012 model Tacoma i4 5speed truck. I didn't notice this sound when I test drove it or when I rode it to work and back home but it kinda sounds like an air sucking noise on the passenger side front of the truck. Maybe from the air cleaner box? Is this normal or??? Plz help
  2. Jan 18, 2014 at 11:10 AM
    blakes09
    blakes09 Toyota Tech..when im not Fishing
    Blake
    Deep South
    4x4
    what kind of airfilter is on it?
  3. Jan 18, 2014 at 11:12 AM
    tinystaco
    Stock OEM filter. Doesn't do it when coasting around or in high rpms.
  4. Jan 18, 2014 at 11:13 AM
    medic2230
    Murph
    Bama! Roll Tide
    Make sure all the clamps are closed on your air box.
  5. Jan 18, 2014 at 11:15 AM
    tinystaco
    Its very faint too. My wife says I'm crazy that it sounds exactly the same as when we test drove it. Maybe it did and I didn't notice it but I can now.
  6. Jan 18, 2014 at 11:18 AM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Running along the base of the windshield (specifically under the passenger wiper blade on mine) is a two piece black plastic molding that was not properly clipped together. Carefully snap it back together and perhaps that will take care of the problem.
  7. Jan 18, 2014 at 11:21 AM
    tinystaco
    I will definitely check there. I just noticed it last night and today I've made 10 trips up and down the road trying to figure it out. I figured it may have been just air being sucked into the filter. Maybe its that tho.
  8. Jan 18, 2014 at 12:42 PM
    dafloydboy
    dafloydboy Well-Known Member
    M.L. Evans
    lancaster s.c.
    15' base access cab
    Are camper shell
    I noticed the same sound from both of my 4cyl 5speed tacos, but not my 4cyl double cab. The sound is coming from the catalytic converter area it's a normal sound, basically exhaust pressure moving through. my guess is the base models have less sound dampening material inside and you just hear more from outside, don't worry about it
  9. Jan 18, 2014 at 10:33 PM
    tinystaco
    Thanks dafloydboy. Seems that's what it is now that I think about it
  10. Mar 12, 2014 at 7:27 PM
    jjtjward
    jjtjward Member
    Odessa, Tx
    Tacoma TSS
    Borla exhaust with tips and borla filter system
    I had same type of noise on my 07, I found the air filter tube that goes into the fender was vibrating against the fender causing the sound on my truck, I added some 1/2" pipe insulation around opening and my noise went away. Somthing easy to check.
