Weird Hum noise on cold start in the morning and at only 900 RPM
Discussion in '2nd Gen. Tacomas (2005-2015)' started by airrage, Feb 19, 2017.
  1. Feb 19, 2017 at 6:25 AM
    airrage
    airrage [OP] Well-Known Member
    Myrtle Beach, SC
    2006 Tacoma Prerunner SR5 DCSB
    17X9 Gear Alloy Rims, BFG KO2's , Android Radio, 32" LED Light Bar in Bumper, LED Bed Lights,
    Ok this is driving me nuts but I get a weird humming noise up front it seems when its usually cold or first start taking off in the morning. It only happens at 900-1000 rpm ONLY!!!!!! It can be either in drive or neutral but notice it mostly when I turn the wheel little. NO vibration from it whatsoever. Anyone know what this could be???
  2. Feb 19, 2017 at 7:33 AM
    Pigpen
    Dan
    Northwest Montana
    Is it right at startup, then goes away after several seconds? There's an air pump that pushes fresh air through your exhaust to dilute the dirtier emissions from a cold engine at startup.
  3. Feb 19, 2017 at 8:06 AM
    airrage
    Myrtle Beach, SC
    I know what u mean thats a different hum. Not that one! Lol
    Pigpen[QUOTED] likes this.
  4. Feb 19, 2017 at 8:43 AM
    fla_sun
    fla_sun Well-Known Member
    2006 SR5 4X4 AC 4.0 Auto
    Mine starting doing a vibration sound about a year ago. Only when it is cold at high idle and it goes away when I start driving.
  5. Feb 19, 2017 at 8:56 AM
    airrage
    Myrtle Beach, SC
    Yes it sounds like a vibration noise without the vibration
  6. Feb 19, 2017 at 9:07 AM
    desertrunner24
    desertrunner24 Well-Known Member
    Jake
    Fresno , CA
    2011 TRD offroad 4x4
    Some
    it sounds like it's your air box.the connection that goes into the inner fender vibrates against the fender. mine had this same noise until I replaced my stock intake for a trd
  7. Feb 19, 2017 at 9:14 AM
    wtjl240
    wtjl240 Well-Known Member
    Jeff
    Spring Hill, TN
  8. Feb 19, 2017 at 10:28 AM
    airrage
    Myrtle Beach, SC
  9. Feb 19, 2017 at 10:28 AM
    steelworx
    steelworx Member
    2006 Tacoma 2WD Manual SR5
    I had a similar noise, it was heat shields on the exhaust. Added someone high quality hose clamps on it and it has been good for the last two years.
  10. Feb 19, 2017 at 10:30 AM
    airrage
    Myrtle Beach, SC
    I will check that, matter of fact now that you say that I did change the air filter about month - 2 months ago and I don't remember it doing that before then so could of shifted perhaps!
  11. Feb 19, 2017 at 10:48 AM
    desertrunner24
    Jake
    Fresno , CA
    Some
    yeah mine made the noise at about the same rpm and when I would put it in reverse and turn left or putting it in park and letting it idle. it seemed to be more frequent when I had a passenger. it was weird. not its gone though
