Weird humming noise when in reverse
Discussion in '1st Gen. Tacomas (1995-2004)' started by Zonakid, Sep 21, 2017.
  1. Sep 21, 2017 at 1:33 AM
    Zonakid
    Zonakid [OP] Member
    Isaiah
    2002 Toyota Tacoma Pre Runner
    So I own a 2003 Toyota Tacoma prerunner sr5 2wd v6. Every time I put my truck into reverse it makes a weird humming noise. I talked to some coworkers, they told me the sound is coming from the transmission. It drives smoothly and everything is fine. It's just when I put it into reverse it makes that humming sounds and gets really annoying. Has anyone run into this problem? I wanna know if it’s a quick and not so serious fix or if the transmission is going bad. Please help!!
    xanlex275 likes this.
  2. Sep 21, 2017 at 2:06 AM
    Rockymtntacoma
    Rockymtntacoma Well-Known Member
    Jake
    SLc,UT
    03 ext cab 4x4 v6 5 speed sr5
    Dual cases, triple sticks, 4.88’s, Harrop e-locked f/r, 35’s, boosted
    Manual or automatic?
  3. Sep 21, 2017 at 5:57 AM
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
    punctuation is your friend.
    also, got a sound clip of the "humming"? sure it's not a grinding kind of sound?
  4. Sep 21, 2017 at 11:36 PM
    Dadypig
    Dadypig Aka daddy pig
    Jaime
    East bay Kali
    2001 silver extended cab sr5
    Stock for now
    Just don't go in reverse and you won't have that problem...:mudding:JK!
    How does the fluid look,when was the last time it was changed?Try changing the fluid and seeing if that helps.
  5. Sep 22, 2017 at 4:00 PM
    Zonakid
    Zonakid [OP] Member
    Isaiah
    It’s an automatic
  6. Sep 22, 2017 at 4:01 PM
    Zonakid
    Zonakid [OP] Member
    Isaiah
    Topped of my trans
    topped of my transmission fluid like 2 days ago still making that noise though
  7. Sep 22, 2017 at 4:02 PM
    Zonakid
    Zonakid [OP] Member
    Isaiah
    No it’s not a grinding sound
  8. Sep 22, 2017 at 4:03 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    Topped off isn't changed, though.
    How many miles? Trans ever been serviced?
  9. Sep 22, 2017 at 4:21 PM
    Zonakid
    Zonakid [OP] Member
    Isaiah
    I’m at 169000 and not that I know of
  10. Sep 22, 2017 at 4:27 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    I've never had to "top off" my trany oil, except that time I installed a trany cooler and spilled a little.
    These aren't mid 70's domestic pickups that need to be "topped off" every other fill up.
    That tells me you've got a leak or something and need to get it fixed ASAP.
  11. Sep 22, 2017 at 4:41 PM
    eon_blue
    eon_blue Okayest Member
    Azusa, CA
    If you're auto trans has never been serviced in 169k miles then it would be best to take it into a reputable mechanic in my opinion and see what they suggest. 15 years and 169k miles on the original auto trans fluid probably as something to do with it. But this far along it might be too dangerous to do a flush; a drain and fill is likely the safest bet.
  12. Sep 22, 2017 at 4:42 PM
    eon_blue
    Azusa, CA
  13. Sep 22, 2017 at 5:02 PM
    Zonakid
    Zonakid [OP] Member
    Isaiah
    I’m gonna have to try that out then and hopefully that helps makes the noise go away
  14. Sep 22, 2017 at 10:15 PM
    gearcruncher
    Canadain bumper technician
    Without a video clip with sound , my best guess from the armchair is the pressure regulator valve inside the transmission resonating or what some guys describe as a buzzing .
    When you select reverse , the transmission needs maximum pressure to hold that gear . Its a tell tail sign that there is an issue with the hydraulics inside the transmission .
    Others above have suggested a transmission fluid change and I agree .
    You mentioned the fluid was topped off ? How long were you running around with low trans fluid ? How much fluid did it take to top off the transmission ?
    169K without a trans inspection and fluid change is pushing it
    There may be some wore out valving that needs to be checked out.
    You can select reverse and check the pressure with a pressure gauge
    When you have the pan off and inspecting your filter and magnets , why not try this
    https://www.tacomaworld.com/threads/sonnax-zip-kit-a340-late-installation.435019/#post-14714790
    Here is a write up involving your transmission
    https://www.tacomaworld.com/threads...sions-write-up-your-4-speed-automatic.325531/
    License2Ill and T4RFTMFW like this.
