Weird idle/stopped noise
Discussion in '1st Gen. Tacomas (1995-2004)' started by Gr8WhiteTaco, Apr 3, 2009.
  1. Apr 3, 2009 at 8:18 AM
    Gr8WhiteTaco
    Gr8WhiteTaco [OP] bishes love my haircut
    Aaron
    Knoxville, TN
    SOLD 02 Double Cab TRD 4x4
    2005 Mazda 3S hatchback
    I've got this really weird noise coming from my truck.:confused: Its almost like a squealing sound, no grinding or clunking noises. It happens once I've come to a stop and the motor is at idle, but if i shift into neutral it stops. Happens in 2WD, 4WD HI & LO. I thought it was just a wet belt at first, but its starting to concern me and is kinda embarassing when your stopped at a light or in drive thru. Could really use any help on this.
  2. Apr 3, 2009 at 9:05 AM
    Gr8WhiteTaco
    Aaron
    Knoxville, TN
    any help at all? has anyone else had any troubles llike this?
  3. Apr 3, 2009 at 12:27 PM
    tablesalt
    tablesalt Tacoma Lover
    Riverside, CA
    04 PreRunner, Double Cab TRD V6
    Good ole' Stock. Black.
    your belt might be slipping? when was the last time you had your fan belt service? I might be wrong, but I figure I throw something out there.
    tablesalt
  4. Apr 3, 2009 at 1:30 PM
    Gr8WhiteTaco
    Aaron
    Knoxville, TN
    that might be it, i havent had belts looked at since i bought the taco last sept. im thinking it could be the idler pulley since it only does it at idle
  5. Apr 3, 2009 at 1:32 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Check your A/C idler - the bearings on that idler are notorious for going bad and squeeling.
    You actually have 3 accessory belts on the 3.4L.
  6. Apr 3, 2009 at 1:39 PM
    Gr8WhiteTaco
    Aaron
    Knoxville, TN
    ok well im hoping its just a belt or pulley because i got enough to fix on the taco.
  7. Apr 4, 2009 at 9:58 AM
    tablesalt
    Riverside, CA
    keep us updated
    tablesalt
  8. Apr 4, 2009 at 10:19 AM
    ETaco23
    ETaco23 Marshall offroad Fabrication
    Evan
    PNW
    13' Pyrite Mica TRD Offroad DCSB 4x4
    Color Match Grille, Bed mat, Kings with JBA UCA's, Dakars and 34" BFG KM3, Snugtop Canopy, and my "Marshall Fabrication" Rock Sliders.
    How many miles are on your truck? bc all your should be changed at around 90K..
  9. Apr 4, 2009 at 1:30 PM
    Gr8WhiteTaco
    Aaron
    Knoxville, TN
    got around 110,550-ish on the odo right now.
  10. Apr 4, 2009 at 4:55 PM
    ETaco23
    Evan
    PNW
    Yeah! def. change all your belts if it wasnt done at 90K man... Thats a must do!
  11. Apr 4, 2009 at 4:59 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Janster has it right. Sounds like your ideler pully.
  12. Apr 4, 2009 at 5:25 PM
    Gr8WhiteTaco
    Aaron
    Knoxville, TN
    ok well, i'll check it out myself or have someone take a look at it. if its just the AC idler, about how serious is it and how much could it cost?
  13. Apr 4, 2009 at 5:33 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    The ideler is about $40.00 or so. Maybe less. Its been a while since I priced them out. Just remove the belt, and replace it. I think there is only 2 or 3 bolts holding it on.
  14. Apr 4, 2009 at 5:47 PM
    Gr8WhiteTaco
    Aaron
    Knoxville, TN
    ok, well thanks for the help guys, I may take a look at it after church tomorrow. I'll kepp yall posted.
  15. May 15, 2009 at 9:32 AM
    Gr8WhiteTaco
    Aaron
    Knoxville, TN
    Ok, today I think if figured out what the weird noise coming from the taco is. I stopped at my mailbox and the noise started, luckily I was stopped on an incline so i lfet it in drive. I got out and walked around to see where it was coming from. It sounded like it was coming from the back, so I looked around at back and noticed it was coming from the rear passenger side wheel area. I knew I had a broke exhaust hanger so I just wiggled the exhaust around to see if anything happened and when I would push the exhaust off the frame, the noise stopped. So I'm thinking the noise is just the exhuast hanger vibrating against the frame. So I'm gonna try to get it welded up and see if that fixes the noise.
  16. May 18, 2009 at 12:42 PM
    Gr8WhiteTaco
    Aaron
    Knoxville, TN
    Alrighty, I finally got the exhaust hanger welded back up so now the weird noise is gone.
