weird knocking feeling
Discussion in '2nd Gen. Tacomas (2005-2015)' started by freesample, Dec 18, 2008.
  1. Dec 18, 2008 at 8:38 PM
    freesample
    freesample [OP] Well-Known Member
    Newfoundland, Canada
    09 Tacoma Double Cab TRD Sport LB
    Visors, Deflector, Husky Liners, too expsensive for good ones :(
    when i go over washboard type roads or any series of smaller bumps i can feel a knock or some kind of looseness through the steering wheel...i think i can hear it too. i dont think it has anything to do with steering left or right as it also happends when i'm going completely straight. i feel it most at anywhere from 20 - 40 mph. any suggestions into what it could be? the truck is going in for an oil change into the dealer next week so i wanted to know what i should ask them to check. thanx!
  2. Dec 18, 2008 at 9:10 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Not sure but let us know what the dealer says.
  3. Dec 18, 2008 at 10:17 PM
    Teocalli
    Teocalli Member
    '08 TRD
    I had a similar scare. Loud knocking noise under my foot. Then I realized I had a ton of compacted snow and ice between the corner panel and door jam. Knocked it loose and chipped away until the noise was gone. A serious relief considering the dealer is two hours away. And I was almost positive the noise was coming somewhere from the suspension or steering column.
  4. Aug 20, 2009 at 7:37 PM
    freesample
    old thread i know but i still havent gotten anywhere with this
  5. Aug 21, 2009 at 8:01 PM
    Bandit
    Bandit Road Warrior
    SC
    2021 TRD OR DC 4x4
    Debadged, decals removed ARE V series Camper Shell, RallyArmor mud flaps I’m old, my truck is boring
    my 05 does it. if you turn the wheel back and forth really quick it tightens up and almost goes away... just a tacoma thing i guess. been like that for 45k miles and no problems yet. dont worry about it.
  6. Aug 22, 2009 at 5:58 AM
    dalsmthme
    dalsmthme Well-Known Member
    Ithaca, NY
    '09 Double Cab 4X4 SR5
  7. Aug 22, 2009 at 7:30 AM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    BSP '10 4x4 TRD Off-Road DC
    See build thread in signature
  8. Aug 22, 2009 at 1:58 PM
    dalsmthme
    Ithaca, NY
    First gen column is different. That solution wont work on a 2nd gen.
  9. Aug 22, 2009 at 2:12 PM
    Bearskill
    Bearskill Well-Known Member
    Sac
    06 Access cab PreRunner Sport
    FlowMaster 40 duals out the back, T-Rex grill, Color matched TRD Nerf bars, Icon coilovers set at 2'', 2.75" OME Dakars spring packs, OME Nitro-Charger extended rear shocks, Carrier bearing drop kit, Wheeler's Extended break Lines, Total Chaos UCAs, Mojave Teflons and 31 1/2" Toyo Open Country A/Ts, Pioneer single din unit, Yakima roof rack, Malone roof basket with X2 KC 130w long range Slimmlights mounted to it, Garmin 255w nav, Fire bottle mod, Air Force standard First Aid kit mod, Hidden Muchette mod (don't ask), and 1 huge OCD about my truck.
    Hey, wow, another person with the same clunk as me. Just like all the other things wrong with my truck the dealer says it's "normal". Ya, right. On wash board dirt roads it feels like my steering rack is going to fall right off. I take it back to the dealer and they say they can't dupicate it. Im not holding my breath, but if you find out some thing new or what the cause is let us know. There are like ten people besides me with this prob on here.
  10. Aug 22, 2009 at 3:27 PM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    My truck does the same thing. Doesn't bother me much though...
  11. Aug 22, 2009 at 5:53 PM
    teri4lance
    teri4lance Well-Known Member
    SE Texas
    09 SR5 4x4
    Removed the price sticker in the window, bobbed 6" off the mudflaps, debadged. TSB completed.
    I thought something was loose in mine, but Dealer said no problem was found. My old Wrangler never did this (on the same roads)
