Weird minor issue when refueling
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OuchIDied, Sep 1, 2021.
  1. Sep 1, 2021 at 1:09 PM
    OuchIDied
    OuchIDied [OP] Well-Known Member
    2021 Silver Sky Tacoma Off-Road
    Feel free to make fun of me if I'm doing something stupid.
    Ever since I got my 2021, every time I refuel the gas pump does not turn off soon enough to prevent gas from flowing out the filler hole.
    This is tested with different pumps at different gas stations. It'll trigger but at least a cup or two will escape. Spout is fully pushed in. I tried adjust the angle of the pump/spout and same issue.
    I know there's an easy resolution... don't fill up the whole way. But surely I'm doing something stupid...
  2. Sep 1, 2021 at 1:10 PM
    Tacospike
    Two Trucks
    idk, never had this happen.
  3. Sep 1, 2021 at 1:12 PM
    OuchIDied
    Exactly. Me neither. I'm 31 and have operated enough gas pumps.
  4. Sep 1, 2021 at 1:16 PM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    Same same. How sloppy is your hole? Lol
    DWD484, iblis01, TRD-ED and 15 others like this.
  5. Sep 1, 2021 at 1:17 PM
    OuchIDied
    Whenever I have issues, I always assume a sloppy hole. But I checked and it was clean.
  6. Sep 1, 2021 at 1:20 PM
    Pongo
    Pongo Well-Known Member
    Scott
    2016 Inferno Tacoma TRD Sport
    Since you say it happens at different stations using different pumps the logical assumption would be user error. However, if we set that aside as one would assume you have experience on using a pump the next logical thing to check/inspect the filler neck of the truck.
    Big tall dave and Chew like this.
  7. Sep 1, 2021 at 1:20 PM
    Superdave1.0
    Superdave1.0 Grandma Dave
    SoCal
    LX470, 2025 Civic Si
    Easy. Just be a cheapass like me and never fully fill up.
    iblis01, StayinStock, FishnTx and 3 others like this.
  8. Sep 1, 2021 at 1:23 PM
    Lawfarin
    Lawfarin Who me?
    Beetle Juice
    NY
    2024 GMC Sierra
    Evap or filler neck issue.
    Newwt, Chew and 12TRDTacoma like this.
  9. Sep 1, 2021 at 1:24 PM
    OuchIDied
    Agreed. Saw nothing interesting with the filler neck. I was hoping that someone had something similar and saw something on their truck.
    I'm leaning towards something with the construction of the fuel shutoff system on a pump and maybe all of a sudden I started doing something idiotic. Like angling the nozzle wrong and blocking those holes on the nozzle that I assume have to do with the shut off.
  10. Sep 1, 2021 at 1:24 PM
    Puppypunter
    Puppypunter Well-Known Member
    Johnny
    2019 Black SR
    Could be an issue with the Venturi. Take it to the dealership, it may be broken or disconnected.
  11. Sep 1, 2021 at 1:29 PM
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    What happens if you fill at the slowest speed? I've had this happen a time or two with different vehicles but it's usually on full blast.
    ndoldman59 and OuchIDied[OP] like this.
  12. Sep 1, 2021 at 1:29 PM
    OuchIDied
    Another note is that it happened on the first ever refuel. So I really don't sense something being broken.
    Weird theory... if the sensor on the nozzle senses liquid and causes the pump to shut off... could the subtle taco lean have something to do with it? If it leans to the driver side... the liquid would hit the sensor and the pump would have less time to shut off before an overflow. Because the pumps will shut off.
    I have an Off Road and used to have an SR5. Perhaps the Bilsteins versus the Hitachis could be it.
    Stupidest thing I've ever thought of ^^^
    StayinStock and tcjacado like this.
  13. Sep 1, 2021 at 1:31 PM
    OuchIDied
    Am I stupid for never thinking of this? I totally forgot there were two notches on the auto-fill latch thing...
    RedWings44[QUOTED] likes this.
  14. Sep 1, 2021 at 1:34 PM
    Riotfunk
    Riotfunk Well-Known Member
    Taco TRD off road
    I use the auto latch all the time and have never had that issue. Even fueling my bike it'll stop as soon as fuel touches it. Maybe you have kung fu grip
  15. Sep 1, 2021 at 1:37 PM
    ndoldman59
    ndoldman59 Well-Known Member
    Murray
    West Fargo, ND
    2021 magnetic silver SR5 DCSB V6
    Had it happen 1x set it to slowest fill, never had it happen before at faster fill setting.
  16. Sep 1, 2021 at 1:40 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Yes.
    But all jokes aside, there is no such thing as a stupid question. If you are still under warranty take it in, but it sounds like you either have an issue in the neck or in the vent solenoid. Toyota is well renowned for their less than stellar EVAP systems and it appears they continue to take pride in their build quality excellency into their latest generation production vehicles as well.
    If you are no longer under warranty then you are going to need to do this on your own, and which leads to my first suggestion, try a different fuel station. Try a Shell or a Chevron and see what happens. Stay close to the nozzle and if it does it again then you will know you have an EVAP issue and will have to take the steps necessary to test the neck first, and if not that, then vent or purge solenoid (though unlikely it is purge, but EVAP systems are weird and finicky as all hell, so anything is possible).
    OuchIDied[QUOTED][OP] likes this.
  17. Sep 1, 2021 at 1:41 PM
    Skydvrr
    Nick
    YMH
    Black '17 OR
    Interesting. Must be something whonky in the filler neck
  18. Sep 1, 2021 at 1:44 PM
    holvey
    holvey Well-Known Member
    Brian
    Portland, OR
    2020 DCSB TRD OR
    I would fill it up except for 1 gallon and take it to the dealer and have them check it out. If you have to take them to a gas station to show what happens, do it.
    I am probably more concerned about this than most because living in Oregon we are not allowed to pump our own gas. New Jersey is like this too, and it would drive me nuts to have to explain this to the attendant every time I had to fill up.:frusty:
    12TRDTacoma and OuchIDied[OP] like this.
  19. Sep 1, 2021 at 1:46 PM
    OuchIDied
    I think I'll mention it at the 5k service. Its definitely not something that needs fixed immediately.
    Wouldn't mind haven't it written down in their system so if I ever need a new charcoal canister or a paint touch up where the gas hit.
    Skydvrr likes this.
  20. Sep 1, 2021 at 1:51 PM
    Superdave1.0
    SoCal
    Anything they write in their system stays with the truck for life. In 5-10 years if you sell, the next owner will be able to see the service history. That includes any issues you mention to the dealer that they document. Not a big deal, just something to consider.
