Weird muffler howling noise
Discussion in '1st Gen. Tacomas (1995-2004)' started by mountainbiker42, May 20, 2013.
  1. May 20, 2013 at 4:25 PM
    mountainbiker42
    mountainbiker42 [OP] Member
    Kyle
    Illinois
    2004 Tacoma 2.7 5 speed 4x4
    Got kind of a weird question here. Today I had a muffler put on by Midas and its making this weird howling noise when I accelerate. Anyone ever have anything like this? Hope they didn't put the wrong muffler on.
  2. May 20, 2013 at 4:36 PM
    TacoDell
    TacoDell Truck ~n~ Tow
    SoCal
    '00 Tacoma SR5 4X
    Donahoe CO's, Deaver leaf paks, Lockright Locker, All Pro body armor ( sliders, front and rear bumpers ), All Pro under belly skids, Warn M8K w/Masterpull synthetic line, Dual Optima battery system, 4 ea LightForce Striker 170 offroad lights, 8 ea wired rock lights, and plenty more I'm sure
    don't hear it... nor see it !? :notsure:
    but you want us to guess :rolleyes:
    hmmm...
    Maybe the dorks at midas installed it backwards !?
    or
    Maybe they used 2.5 or 3 inch pipe after the can !?
    or
    Maybe you got one of those whistle mufflers installed !? :p
    I'm done guessing... Lol
  3. May 20, 2013 at 4:53 PM
    Raceline08
    Raceline08 Well-Known Member
    Brett
    Santa Rosa, ca
    Silver 08 DBC SB 4x4 TRD Offroad
    front Billies, 885x coils, taco lean spacer, TC UCA'S, Magnaflow 22" OME Dakars, Billy 110 rear's, B.A.M.F CMC, custom made E-locker guard
    Ya, Kinda vauge? Crawl under that thing and maybe look around a little, write down some specs on the muffler, part numbers maybe brand?
    Thanks,
    Brett
  4. May 20, 2013 at 5:02 PM
    02TACOMA4WD
    02TACOMA4WD Well-Known Member
    02 Tacoma TRD 4x4
    Could be a bad muffler bearing...
  5. May 20, 2013 at 5:09 PM
    KenpachiZaraki
    KenpachiZaraki Its Wicked Flow BITCHES!!
    Alex •﹏•
    Lubbock
    05 TRD. 325/275/365 SBD
    ALL POSER- Afe Pro Dry S drop in filter, 3" AP leaf pack, Eibach w/5100's up front, 5100's rear, Fog Light Mod, ABS off mod, Dash Light MOD, Doug Thorley Long Tube Headers, Wicked Flow Bitches MAX Muffler, 4" floods, 20", 43" light bars, 265/75/16 Hankook Dynapro ATm, oil catch can, rear diff breather relocate, Custome Sliders, SOS concepts Front bumper, Demon Eye Mod, backlit TRD emblem on bumper, Morimoto D2S projectors,
    Probably this. OP take the truck back and tell them to change the muffler bearings out. If they don't, your truck will continue to wear down the tires!
  6. May 21, 2013 at 12:25 PM
    mountainbiker42
    Kyle
    Illinois
    Yeah maybe ill have them refill my blinker fluid too. They used the cheapest muffler they had, maybe it is backwords or just the wrong muffler.
  7. May 21, 2013 at 2:09 PM
    KenpachiZaraki
    Alex •﹏•
    Lubbock
    Was it welded? They might have not welded it right or left some holes. Kinda hard to say with limited info. Maybe have another shop check it out?
  8. May 21, 2013 at 2:18 PM
    Aw9d
    Aw9d That one guy
    Cheapest muffler they have.
    There's your problem. You get what you pay for.
  9. May 21, 2013 at 2:45 PM
    mountainbiker42
    Kyle
    Illinois
    Yeah it was welded and there are no holes. I looked under there and it's not backwards, probably just a piece of garbage muffler. I'll check and see who makes it so everyone knows not to purchase this thing lol.
  10. May 21, 2013 at 4:40 PM
    kmok
    kmok Plastidipped ma Hootus!
    Kyle
    Columbus, Ohio
    2005 Subaru Outback XT 5MT
    Did they cause the exhaust flanges for the cats to break loose some? After getting my muffler replaced it was quiet for the first day then it started roaring again (hole in the muffler before) and that was my issue.
  11. May 30, 2013 at 8:41 AM
    mountainbiker42
    Kyle
    Illinois
    Well I took it back to Midas today and they said the noise is coming from the muffler just like I thought and they said that's just the way it is. They won't exchange it, but if I bring in a different muffler they would install it free of charge. Any suggestions for mufflers? Just need something quite for the 2.7L that won't make a howling noise.
  12. May 30, 2013 at 8:54 AM
    KenpachiZaraki
    Alex •﹏•
    Lubbock
    Wicked Flow, but I'm biased :)
  13. May 30, 2013 at 12:12 PM
    02TACOMA4WD
    02 Tacoma TRD 4x4
    My flowmaster 40 sounds great. Not Ricey and not too loud. It has just the right tone
  14. May 30, 2013 at 12:24 PM
    TacoDell
    SoCal
    '00 Tacoma SR5 4X
    take that business to small claims
    well... unless you specifically requested the cheapest
    crap they sell !?
    then that would be on you.
    But if it was their recommendation
    and it does not function as it should as a OEM replacement.
    They should be held accountable (liable) for selling you sub-grade components.
    I'd prolly take them up on their free labor offer...
    buy a MF or FM or something else, and have them install that.
    Make sure they use 2.25" dia. tailpipe tubing...
    larger will just aggravate things...
    cause more scavenging issues (noise) and less torque.
    Larger diameter tubing tends to back fire slightly
    or make scavenging noises that are less then desirable. IME
    I tried a 2.5" dia tailpipe...
    cut that crap off quick and replaced it with 2.25"
    all better ;)
