Weird No Starter Juice After Battery Disconnect
Discussion in '1st Gen. Tacomas (1995-2004)' started by NevadaSage, Sep 24, 2017.
  1. Sep 24, 2017 at 2:09 PM
    NevadaSage
    NevadaSage [OP] New Member
    Jake
    Kids 96' Tacoma Single Cap
    96' 4x4 2.7
    After changing the dreaded fuel filter while trying to trouble shoot a major bog in the motor, my son decides to disconnect the battery for the evening so it gets a 'restart' to the electrical, he did however leave the negative connected. He reconnected the positive side a few hours later and nothing but a click and some buzzing behind the dash. I checked the battery numerous times and used my start box and nothing, just a click or two. The headlights will take a minute to come to life as if they were on a dimmer ???? Any thoughts or suggestions, I do not beleive this is a starter issue, I tapped it a few times and nothing.... Battery is showing 75% with 12.5 volts
  2. Sep 24, 2017 at 5:35 PM
    lucky13don
    lucky13don Well-Known Member
    Don
    Milton, fl
    R.I.P.04 tacoma prerunner, 04 sequoia 4x4
    Too many to list
    Check the main fuse and 80 amp battery fuse. Might of popped them put cable back on. Always disconnect negative first, install last. You don't want to know how I learned that..
    ElBlancoTaco likes this.
  3. Sep 24, 2017 at 5:35 PM
    lucky13don
    Don
    Milton, fl
    Too many to list
    Also all connections are tight and clean?
  4. Sep 25, 2017 at 9:42 PM
    NevadaSage
    Jake
    UPDATE ! and slightly embarrassed.... after checking every fuse and preparing for the worst, I had the kid turn the key and I gave the positive battery connector a good shaking... Started right up.... Just need to be taken apart and cleaned thoroughly.... now on to the engine bog.... thank u lucky13 for your responses...
    Dalandser and ElBlancoTaco like this.
  5. Sep 26, 2017 at 9:07 AM
    lucky13don
    Don
    Milton, fl
    Too many to list
    All good. I drive for 3a. I deal with that all day..glad it was a easy fix
