Weird noise 2017 trd off-road
Discussion in '3rd Gen. Tacomas (2016-2023)' started by bulalo, Nov 9, 2017.
  1. Nov 9, 2017 at 1:16 PM
    bulalo
    bulalo [OP] Well-Known Member
    SoCAL Inland Empire
    2017 trd offroad 4wd LB
    KDMax pro 9.0
    . Sounds like when you run your finger around the rim of crystal wine glass . anyone has this ? Any ideas how to fix ? https://youtu.be/mV76JHlTVl4 . I have the v6 and same issue and sounds the same. Tnx. It doesn't come on all the time .
    Edit . Added more description.
  2. Nov 9, 2017 at 6:27 PM
    bulalo
    SoCAL Inland Empire
    KDMax pro 9.0
    Bump . Am I the only one ?
  3. Nov 9, 2017 at 6:33 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    Front LCA Howl unless they plug them now
  4. Nov 9, 2017 at 6:36 PM
    Captqc
    Captqc Well-Known Member
    Tigard, OR
    2017 Tacoma 4x4 TRD AC Off Road
    Sounds like the whistling A frames problem. Crawl under and see if the holes on your A frames are plugged or not.
    shakerhood likes this.
  5. Nov 9, 2017 at 6:36 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    Lifted, non lifted?
  6. Nov 9, 2017 at 6:36 PM
    nDub
    nDub Kan kun være malet af en gal mand
    Central Sierras - NorCal
    ‘17 TRD OR DCLB and a dǝǝſ
    Lead Free Gasoline
    I get that too sometimes.
    No idea what is going on.
    bulalo[OP] and 2016Tacoman like this.
  7. Nov 9, 2017 at 6:41 PM
    Lt. Dangle
    Lt. Dangle RIP @stun gun 2016-2020
    Ohio
    2025 Tundra Platinum OR
    Almost certainly the howling a arms. Easy to test out, just cover your holes on the a arms with tape and see if it goes away. My 17 OR currently is rolling this way.
  8. Nov 9, 2017 at 6:43 PM
    2016Tacoman
    2016Tacoman Well-Known Member
    J
    2016 Tacoma 4x4 V6 Metallic
    Exact same here.
  9. Nov 9, 2017 at 6:48 PM
    bulalo
    SoCAL Inland Empire
    KDMax pro 9.0
    Sorry forgot to add. No lift, A arms holes taped.
  10. Nov 9, 2017 at 6:53 PM
    nDub
    Lead Free Gasoline
    Yeah my holes are covered.
  11. Nov 9, 2017 at 6:58 PM
    jaredrunstrails
    jaredrunstrails Well-Known Member
    2019 DCSB TRD OR 4x4 Cavalry Blue
    Does it happen only at certain speeds?
  12. Nov 9, 2017 at 7:03 PM
    Lt. Dangle
    Ohio
    Widow or door seal bad? Def. sounds like air though to me.
  13. Nov 9, 2017 at 10:35 PM
    ECU4422
    ECU4422 Well-Known Member
    Robocon
    Nissan Frontier
    I didn't really hear a noise other than it seemed like the motor was working pretty hard to get up to speed.
  14. Nov 9, 2017 at 10:42 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    I did not really hear any noises in that video other than what sounds like a slight transmission whine.
  15. Nov 10, 2017 at 4:55 AM
    gearcruncher
    Canadain bumper technician
    Narrow the sound down a little more
    What gear are you in when you hear the sound ? does downshifting make it go away ?
    Bring the truck up to the speed where you hear the sound , keep your foot on the gas and downshift 1 gear . Do you still get the sound when you downshift ?
    What rpm is the engine running at when you hear the sound ?
    If you rev up the engine in your driveway while you are parked , do you get the sound ?
    Does shifting to 4x4 make the sound go away ?
    Do you get the sound on accel as well as decel ?
    Sorry bout more questions . Sounds can be difficult to diagnose from the keyboard in comparison to actually test driving the vehicle
    shakerhood and Riding Dirty like this.
  16. Nov 10, 2017 at 5:13 AM
    jsinnard
    jsinnard Well-Known Member
    J
    Virginia
    16 QS DCLB OR 4X4
    No noise like that in 20 months of ownership. My LCA noise sounded like you're blowing on a jug, not like that.
  17. Nov 10, 2017 at 5:15 AM
    Mickeyman
    Mickeyman YAR!
    Mick
    New Hampsha
    2016 TRD Sport access cab 4x4 auto
    Black tube steps,mud flaps, fluid filmed tonneau cover,jbl speakers heated leather seat covers,bed mat,husky floor liners
    The whine of the turbo spooling up!
    offthewallsurfer likes this.
  18. Nov 10, 2017 at 5:23 AM
    bulalo
    SoCAL Inland Empire
    KDMax pro 9.0
    Usually but rarely it happens near the end of upshift either 2nd to 3rd gear or 3rd to 4rth but only for a split second at a certain rpm and engine load. Yesterday while doing the ac drain tube mod, I accidentally tapped on the aluminum heat sink it's so flimsy it might vibrate and I think that's causing it. Something might cause it to resonate and make a sound (like when you tap a tuning fork) during load/trans /engine vibration. Not sure.
  19. Nov 10, 2017 at 5:31 AM
    gearcruncher
    Take the truck for a drive and watch the tach as you listen for the sound at the same time .
    Park in the driveway and rev the engine matching the engine rpm to where you heard the sound during upshifts . Do you still get the sound ?
    This will eliminate the complete drivetrain from the equasion if you still get the sound while parked
    EDIT if you dont get the sound by running the truck up to the rpm where you hear the sound in park , select drive range first gear and hold the brakes hard , then slowly bring the revs up to match the rpm listening for the sound .
    This is called a stall test and will test for resonance under load .
    A word of caution though . You must allow the transmission to cool after performing such a test . Leave the engine running in park to cool the transmission.
    Dealerships often use a stall test to eliminate noise complaints . If you can reproduce the noise in the driveway without test driving the vehicle , a lot of diagnostic time is saved
  20. Nov 10, 2017 at 5:34 AM
    bradshawnh
    bradshawnh ...to the rescue!
    Boston, MA
    2017 TRD OR DCSB 6MT, Tech, Inferno
    Do you have an automatic or a manual transmission? I know there was a TSB for high pitched whine on the manual trans, I had it done on mine! They installed a new insulator on the side of the transmission.
