Weird noise coming from engine bay??
Discussion in '1st Gen. Tacomas (1995-2004)' started by 01GREENTACO, Feb 24, 2009.
  1. Feb 24, 2009 at 7:33 AM
    01GREENTACO
    01GREENTACO [OP] Not all who wander are lost
    Germantown, TN
    01 4WD
    Lost track many, many mods ago.
    I have heard a noise lately and it sounds like 2 metal pieces either rubbing together or maybe something loose below the cab. I have a 2001 6 speed manual. Any thought on what it might be? It usually occurs around 35-40 MPH and it continues to occur even at speeds of 65 and 70. It gets louder as I release the clutch and only stops when I come to a stop. It is not in the engine itself because I have shut it off to try and isolate the problem area and it still is audible even when the engine is completely off. Any mechanics out there who know what this might be or anyone have any other instances of this? :confused:
  2. Feb 24, 2009 at 7:50 AM
    OU812
    OU812 ban the term murdered out
    danusa
    Kilroy was here
    13 DblCab LB 4X4
    Nothing yet, brand new!
    More info needed..
    Clutch coupled or de-coupled?? Change pitch with engine speed and/or road speed?? What gear??
    Warm or cold drivetrain??
    Perhaps pilot or throwout bearing based on what you've stated so far. But possibly driveshaft carrier bearing.
  3. Feb 24, 2009 at 7:55 AM
    01GREENTACO
    Germantown, TN
    01 4WD
    Same pitch throughout. Starting in 4th gear and continues in 5th. Warm drivetrain.
  4. Feb 24, 2009 at 10:13 AM
    higherlux
    higherlux Well-Known Member
    Blake
    middle of S.C.
    1998 tacoma 2.7l 4wd/1986 POS
    Mall crawler status
    6-speed?????
    i thought they only came in 5-speed:confused:
  5. Feb 24, 2009 at 10:32 AM
    01GREENTACO
    Germantown, TN
    01 4WD
    5 speed with reverse so "technically" 6 speed.
  6. Feb 24, 2009 at 10:43 AM
    higherlux
    Blake
    middle of S.C.
    Mall crawler status
    ohi guess that would make sence then
  7. Feb 24, 2009 at 11:01 AM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    If it is isolated to 4th and 5th gear, I would suggest something is a miss in the tranny. Drain the fluid to see if there any shavings. I would suggest straining the fluid through a coffee filter to catch any thing.
  8. Feb 24, 2009 at 11:54 AM
    cadman
    cadman Well-Known Member
    Pensacola, Florida
    TRD PreRunner
    tecnically you count forward gears. 5 speed, reverse is a given.
  9. Feb 24, 2009 at 12:00 PM
    01GREENTACO
    Germantown, TN
    01 4WD
    I know, I know. I'm just saying.
  10. Feb 24, 2009 at 2:50 PM
    tmantstud
    tmantstud High Mileage Work
    Kansas City, Kansas
    98 Tacoma high mileage
    Bed liner, Polk db651s speakers, JVC head unit, Coverking custom saddle blanket seat cover
    I had something like that where it rattled around 2000 rpm. Try looking at the exhaust pipe where it bends up towards the engine bay, for mine there was a loose clamp that i removed and replaced.
  11. Feb 24, 2009 at 3:45 PM
    OU812
    danusa
    Kilroy was here
    13 DblCab LB 4X4
    Heat shield? Been offroad lately? Ck brakes for obstructions, pebbles, debris in drums? Ck the cat too.. I have heard/seen a few where the ceramic honeycomb breaks loose and rattles around in the housing..
    Definitely ck the gearbox fluid and front diff fluid too..
  12. Feb 24, 2009 at 6:31 PM
    01GREENTACO
    Germantown, TN
    01 4WD
    Went mudding a couple times in the last couple weeks. I will definitely check those spots though. I took off the rims recently but didn't notice anything unusual but I will for sure double check. So your saying, gearbox most likely?
