weird noise from behind glove box
Discussion in '1st Gen. Tacomas (1995-2004)' started by tacoma92, Jul 15, 2010.
  1. Jul 15, 2010 at 9:25 PM
    tacoma92
    tacoma92 [OP] Black Hole Sun
    Forrest
    Gulf Shores, Alabama
    09 SR5 Toyota Tacoma
    when i turn my truck on, it makes a clicking noise behind the glove box. any body have any idea wat tht is and any suggestions on how to fix it?
  2. Jul 15, 2010 at 9:36 PM
    crazyasu45
    crazyasu45 Well-Known Member
    Canada
    2013 MGM DCLB 4X4 TRD SPORT
    3" SUSPENSION LIFT
    Passenger Airbag sensor of some sort :confused:
  3. Jul 15, 2010 at 9:40 PM
    HBMurphy
    HBMurphy Ban Pending
    Paul
    So California Coast
    09 Off Road Delete Model
    None
    leave in the air box for the cabin filter...
    Edit: LEAF not Leave :eek:
    Edit the Edit: 01 - oops no cabin air filter huh? :eek: :eek:
  4. Jul 15, 2010 at 9:47 PM
    CopDoctor
    CopDoctor Well-Known Member
    Colorado Springs, CO
    08 335i
    BMS Intake, JB4 chip, Plastidip everywhere
    is it only clicking when your ac is on? could be the ac blower back there like many trucks
  5. Jul 15, 2010 at 10:20 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 Auto Trans With Lots of Mods King Extended Travel COs Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Alcan Custom 8-Leaf Rear Spring Packs Fox 2.0 Resi Rear Shocks FrankenFab Rear Shock Relocate All-Pro U-bolt Flip w/Timbren bumps Toytec 1" Extended Shackle 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Gunmetal 16x8 SCS Ray10s 285/75r16 Cooper STT Pros Limited Edition Relentless Front Bumper Smittybilt X2O 10K Winch 3" LED Pods w/Amber covers in the Bumper 22" Single Row LED Bar on the Bumper Mini D2S Projectors XB35 Ballasts + 4500K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Whynter 65 qt. Fridge/Freezer CVT Mt Bachelor RTT Badland Custom Bed Rack GM 140 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Magnaflow 18" Muffler 13WL Brake Calipers Braided Steel Brake Lines AFE Pro Dry S air filter ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    Welcome to TW.
    Do you mean, after you start the engine? Not just turning the ignition key to the "on" position, right?
    If you open the glove box, does the noise get louder?
    Behind the glove box is the firewall. Beyond that is the engine compartment. With the engine running, open the hood. Does the clicking noise get louder/easier to hear?
  6. Jul 15, 2010 at 10:23 PM
    TacoTron
    TacoTron Tacotronn
    Anthony
    Albuquerque, NM
    07 Toyota Tacoma
    Fabtech Lift on top of 3 inch body lift. 34s trail grapplers on 18inch eagle alloys. KRFab Rear bumper, BHLM with HIDs, TRD seat covers, Hood scoop, N fab tire carrier, black valence, TRD intake, 40s Flowmasters, Foglight mod, best for last and thats my 4.56 gears, and much more too come.
    Could be the bolt right behind the glove box on the top right gotta find it and look behind the plastic a little bit. I kept having that stupid noise also and found a thread on here about it and the bolt was lose tighten the hell out of it and the sound was gone.
  7. Jul 18, 2010 at 11:39 AM
    tacoma92
    Forrest
    it makes the noise before the truck gets turned on completely. and it does it even when the ac is off. it doesnt make any sense
  8. Jul 18, 2010 at 3:40 PM
    AKTacoma
    AKTacoma Dedicated Crew Chief
    Houma, Louisiana
    08 Tacoma DCLB
    does it go away at all? It could possibly be something to do with your ABS doing a test of some sort when you turn your truck on.
  9. Jul 19, 2010 at 12:01 AM
    tacoma92
    Forrest
    it starts before i start my truck and doesnt go off til i shut the truck off again
  10. Jul 19, 2010 at 7:32 AM
    woodygg
    woodygg Well-Known Member
    So Cal
    04 DC Tacoma 4x4
    mine used to do that and i cannot the life of me remember what it is. my mechanic told me, and it wasn't anything to worry about (on mine anyway).
