Weird noise Help!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bordinco90, Jul 13, 2020.
  1. Jul 13, 2020 at 3:22 PM
    bordinco90
    bordinco90 [OP] Well-Known Member
    SW Louisiana
    2008 Desert Sand Mica Tacoma Prerunner DCSB
    18 inch Black rims with 265/65/18 AT tires. Bilstein 5100 shocks. Black Halo Headlights and Black LED taillights. Window Tint. Black Aftermarket Grille.
    I noticed the other day when backing up that I have a weird noise coming from the back of my 2008 Tacoma prerunner. I posted a vid as well. It only happens when backing up. Its not the brakes, but because I'm not pressing down. U joint maybe?
    wilcam47 likes this.
  2. Jul 13, 2020 at 3:25 PM
    bordinco90
    SW Louisiana
    Any help would be appreciated
  3. Jul 13, 2020 at 3:25 PM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    Have you greased your ujoints? How many miles?
  4. Jul 13, 2020 at 3:26 PM
    bordinco90
    SW Louisiana
    U joints have never been greased. The truck has 170k and I am the original owner. I have no clue where the zerks are at.
  5. Jul 13, 2020 at 3:27 PM
    bordinco90
    SW Louisiana
    Or the u joints for that matter.
  6. Jul 13, 2020 at 3:28 PM
    BINK05TRD
    BINK05TRD Well-Known Member
    Massachusetts
    TRD OR AC SILVERSKY 15
    Either end of the driveshaft.
  7. Jul 13, 2020 at 3:29 PM
    BeardeDave
    BeardeDave Member
    Dave
    Colorado Springs, CO
    08 Access Cab TRD-OR
    Nothing fun yet...
    My truck just hit 165K and my U-joints were making the same noise. You might be able to get away with just greasing them, but that's gonna be a band-aid fix until you can throw new u-joints on there. Not a very difficult DIY with the right tools.
    Muddinfun and wilcam47 like this.
  8. Jul 13, 2020 at 3:36 PM
    bordinco90
    SW Louisiana
    Yeah I was fearing that. How many U joints are on the truck? 2?
  9. Jul 13, 2020 at 3:38 PM
    BeardeDave
    BeardeDave Member
    Dave
    Nothing fun yet...
    I've got a 4x4 and had 3, not sure if it's the same for the 2wd. I also replaced the center support bearing since I was already tearing it all apart. Pretty sure it was on it's way out soon anyways.
    wilcam47 and SR-71A like this.
  10. Jul 13, 2020 at 3:47 PM
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
    Don't think PreRunners have greaseable u joints. I know mine doesn't
    lynyrd3, RobP62 and wilcam47 like this.
  11. Jul 13, 2020 at 3:57 PM
    Sprig
    Sprig Well-Known Member
    Ken
    N. Calif. The Twilight Zone
    Tacoma TRD double cab 4x4, Barcelona Red
    If you don’t know where the u joints or zercs are you shouldn’t be the one to try to install new ones. Thank your truck to a reputable shop, have them check out the sound and have them repair it.
  12. Jul 13, 2020 at 3:57 PM
    bordinco90
    SW Louisiana
    Yeah im not sure if they do or not.
  13. Jul 13, 2020 at 3:58 PM
    Muddinfun
    Muddinfun Well-Known Member
    Yep, definitely U joints. You can tell by the speed of the noise. The driveshaft turns almost 4 times faster than the wheels.
  14. Jul 13, 2020 at 4:41 PM
    bordinco90
    SW Louisiana
    Yeah thats what I planned on doing. Thanks
  15. Jul 13, 2020 at 4:52 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    My PreRunner came with grease zerks on the drive shaft. That being said OP the PreRunners have three universal joints also. Do all three if one is bad the others are not far behind.
    Oh and make sure they replace them with greasable joints as they last longer if greased.
    wilcam47 and TnShooter like this.
  16. Jul 13, 2020 at 4:57 PM
    Plain Jane Taco
    USA
    At some point the PRs went to a non greaseable joint. I know for certain mine does not have them. Wish it did.
  17. Jul 13, 2020 at 5:03 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    Some do and some don't. Only way to know is to check...
    wilcam47, BeardeDave and TnShooter like this.
  18. Jul 13, 2020 at 5:24 PM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    hahaha sounded like something else there for a second :D
    But yeah, speed of the noise is related to the speed of the truck so its a good bet its in the drivetrain (u-joints) as others have said. Also, like @BeardeDave said its probably a good bet to replace the carrier bearing while you're there.
    Given you're a pre-runner I think you would want Spicer P/N 5002007 (with dust seals) but verify that for yourself, might be different for the 2005-2011 trucks idk
    Remember to chock the tires good and set the parking brake cause as soon as you drop the DS the wheels are no longer held by the transmission if your truck is auto
    RobP62, 12TRDTacoma, wilcam47 and 2 others like this.
  19. Jul 13, 2020 at 7:31 PM
    bordinco90
    SW Louisiana
    Yeah thats what I will do. Not too bad 12 years and 170k without greasing them regularly.
    SR-71A and wilcam47 like this.
  20. Jul 13, 2020 at 7:33 PM
    bordinco90
    SW Louisiana
    Yeah ikr lol. Yeah I will check to see how much it will cost to replace all U-joints.
