Weird noise Help!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bordinco90, Jul 13, 2020.
  1. Jul 13, 2020 at 7:43 PM
    bordinco90
    bordinco90 [OP] Well-Known Member
    SW Louisiana
    2008 Desert Sand Mica Tacoma Prerunner DCSB
    18 inch Black rims with 265/65/18 AT tires. Bilstein 5100 shocks. Black Halo Headlights and Black LED taillights. Window Tint. Black Aftermarket Grille.
    Just watched a vid on how to do it. Uh..... no. I'm not mechanically inclined, so I guess I'll bring it to a local shop or the Toyota Dealership. :spending:
    wilcam47 likes this.
  2. Jul 13, 2020 at 8:23 PM
    Muddinfun
    Muddinfun Well-Known Member
    Don’t go to the dealer!
    Jimmyh and ImMrCrash like this.
  3. Jul 13, 2020 at 10:27 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    And if you do you better grease up before you get there. They will tell you to replace the drive shaft to the tune of about $1,100.
    wilcam47 and Muddinfun[QUOTED] like this.
  4. Jul 13, 2020 at 11:08 PM
    bordinco90
    SW Louisiana
    Yeah nevermind going to the dealership. I'll take it to a local mechanic that I trust.
    wilcam47 and Jimmyh[QUOTED] like this.
  5. Jul 14, 2020 at 4:04 AM
    GP_spence
    GP_spence Well-Known Member
    AL
    2013 DCSB TRD Off-Road 4x4
    Since starting this post have you gotten under your truck to see if you have greasable u joints? Takes like 5 minutes. If you do buy a grease gun and grease them. Might make the noise go away, then you can replace them at your convenience. Either way it's something you should know how to do.
  6. Jul 14, 2020 at 9:42 PM
    bordinco90
    SW Louisiana
    I checked today. There is no grease zerks on any of my u joints. I was hoping that there was some. I'm still undecided on where to bring it.
  7. Jul 15, 2020 at 4:13 AM
    GP_spence
    AL
    Good to know! Yeah be prepared if you take it to a dealership they will most likely replace the whole driveshaft, they don't really f around with individual u joints. Any driveshaft shops in your area? I'd hope that you can replace the u joints with greasable ones and maybe the carrier bearing while you're at it.
  8. Jul 15, 2020 at 6:59 AM
    bordinco90
    SW Louisiana
    No none in my area. I called a local shop that is really good at doing front end work, but when asked about replacing the U-joints they didn't seem too confident about replacing them.
  9. Jul 29, 2020 at 6:02 AM
    bordinco90
    SW Louisiana
    I called a local shop and they said that they can do it. It's there now. They are putting ones with grease zerks. Now for another question. How often should I grease them and what kind of grease should I use?
  10. Jul 29, 2020 at 6:06 AM
    GP_spence
    AL
    Every oil change or at least every 10k miles. I use Lucas Red N Tacky.
    Island Cruiser, wilcam47 and SR-71A like this.
  11. Jul 29, 2020 at 6:17 AM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    Yup. Any NLGI #2 rated grease will do.
    bordinco90[OP] likes this.
  12. Jul 29, 2020 at 8:17 AM
    bordinco90
    SW Louisiana
    Cool that's the kind I will use then. How much do I put in every time? Sorry for all of the dumb questions, I've never messed with U-joints before. The shop just called me and said one of the U-joints was bad. I'm assuming the rear one since that's where the noise was coming from. I told them to replace all 3.
  13. Jul 29, 2020 at 8:21 AM
    GP_spence
    AL
    Pump in grease until you see fresh grease coming out of all 4 sides of the u joint. Pretty easy stuff. Clean up is the most difficult part. Get some shop towels, or some folks just leave it and sling it everywhere when they drive it next.
    SR-71A and wilcam47 like this.
  14. Jul 29, 2020 at 8:25 AM
    bordinco90
    SW Louisiana
    Ok that seems easy enough. Thanks for the help!
  15. Jul 29, 2020 at 5:53 PM
    #35
    rdsaal
    rdsaal Well-Known Member
    2018 Black Tacoma SR5
    So my Tacoma is a 2018 at just under 50k miles and developed the same squeak. Shop said they’re going to replace the rear u-joint. Should I ask them to just grease it? Doesn’t seem like a lot of miles.
  16. Jul 30, 2020 at 5:05 AM
    #36
    SR-71A
    Zack
    Southern Maine
    If it is a sealed joint then it cannot be greased. If it is meant to be greased, but hasnt been in 50k miles, its probably toast
  17. Jul 31, 2020 at 3:40 PM
    #37
    tonyl13
    tonyl13 Well-Known Member
    tony
    Sonoita,Az.
    09PreRunner xcab
    badgeless
    Ah the sound of uJoints going bad. My PreRunner also has no grease fitting
  18. Jul 31, 2020 at 7:25 PM
    #38
    bordinco90
    SW Louisiana
    Well the shop called today to let me know my truck was ready. Couldn't make it today, but I cant wait to pick it up monday!
    wilcam47 and Muddinfun like this.
  19. Aug 3, 2020 at 2:27 PM
    #39
    bordinco90
    SW Louisiana
    Picked the truck up today and everything feels great!
  20. Aug 3, 2020 at 4:02 PM
    #40
    C4vettrn
    C4vettrn Well-Known Member
    Randy
    Ft. Wayne IN.
    2015 trd 4x4
    17" SR8's
    Get Dana u-joints if you can. That is all I will use.
