Weird noise in curves
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 11Bravo, Sep 23, 2017.
  1. Sep 23, 2017 at 11:24 AM
    11Bravo
    11Bravo [OP] Member
    Todd
    Silver 2013 Tacoma crew cab 4x4
    Lift, Toyo MT
    maybe I'm crazy, maybe the truck is, I don't know. Here's the thing though.
    2013 Tacoma double cab TRD Sport 4x4, 6" lift. Whenever I take a curve at speeds >25mph, I hear a whiring noise that I can only describe as like an electric motor or actuator maybe. It's only for a second or two and sounds like it's maybe coming from the dash or steering column.
    1. Anyone else noticed a similar issue?
    2. Is there even a mechanism that would make that type of sound in the area?
  2. Sep 23, 2017 at 12:27 PM
    Pork Chopper
    Pork Chopper Well-Known Member
    Dallas, TX
    07 DC 4x4
    My first assumption would be front wheel bearings but those were not installed in the dash last time I checked. Maybe needle bearing? Power steering pump can make noises but that would be ANY time the wheel is turned and you can easily tell that noise is under the hood.
  3. Sep 23, 2017 at 12:32 PM
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
    VSC, maybe? Lift messing with it?
  4. Sep 23, 2017 at 12:55 PM
    Pigpen
    Dan
    Northwest Montana
    Def the VSC trying to decide if it wants to activate ABS. You can recalibrate it, but if the ABS isn't actually kicking on there's no real problem.
    JoefromPTC likes this.
  5. Sep 25, 2017 at 7:18 AM
    11Bravo
    11Bravo [OP] Member
    Todd
    Lift, Toyo MT
    No, it doesn't apply the brakes. Thanks for the info guys, I'm glad to know that it's the truck, not me that is crazy. I'll keep an eye/ear on it and if I notice any for-the-worse changes, I'll head to the mechanic.
  6. Sep 25, 2017 at 7:20 AM
    Pigpen
    Dan
    Northwest Montana
    If it activates the VSC/ ABS, there's an easy DIY to recalibrate it.
    11Bravo[OP] likes this.
