Weird noise on cold start.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Jericho9419, Jan 30, 2019.
  1. Jan 30, 2019 at 5:05 AM
    Jericho9419
    Jericho9419 [OP] Member
    Toyota Tacoma TRD 4x4 sport manual transmission.
    Truck makes a weird noise on cold start, it sounds like a squeaky noise and like a knock/rattle. It goes away once the truck comes to normal operating temperature. The noise is also affected when I press and depressed the clutch pedal.
    I've taking it to two different shops and they can't tell me what's going on, as the noise goes away once the truck is warm and the noise is hard to detect.
    Please help.
  2. Jan 30, 2019 at 7:34 AM
    TacomaMike37
    TacomaMike37 Well-Known Member
    13' DCLB MGM
    What year is the truck? Can you post a video of the sound? The 4L are loud in general.
  3. Jan 30, 2019 at 7:38 AM
    Jericho9419
    2013 trd sport 4x4 v6 4.0, 6 speed manual.
  4. Jan 30, 2019 at 7:38 AM
    PzTank
    PzTank Stuck in the Well
    Above the Notches
    ‘15 AC SR5 4X4 4.0 Auto
    ‘07 OR leather shift knob
    What’s the years for the secondary air pump system everyone hates??? 2012-2015?
    If your truck has it and the noise goes away when it warms up, that could be your culprit.
  5. Jan 30, 2019 at 8:37 AM
    Jericho9419
  6. Jan 30, 2019 at 9:30 AM
    TacomaMike37
    13' DCLB MGM
    The taco tick is normal, that other weird noise, which was more pronounced when you went near the undercarriage... I have no idea. Guaranteed someone here knows.
  7. Jan 30, 2019 at 9:37 AM
    Jericho9419
    I've owned the truck 6 years now and that "taco tick" is something that just started to happen about a month ago as well with the squeaky noise.
  8. Jan 30, 2019 at 9:48 AM
    ARB1977
    ARB1977 It’s a beaut Clark
    North Texas
    15 DCSB Prerunner 4.0L Blue Ribbon Metallic
    Black TRD Fj Cruiser wheels, TRD catback exhaust.
    Squeaky noise could be a pulley or belt. Run some fuel system cleaner in the tank and see if the tick goes away.
    Knute and tcjacado like this.
  9. Jan 30, 2019 at 9:49 AM
    GMan8402
    GMan8402 Well-Known Member
    98 SR5 4x4 / 14 Prerunner TRD OR 4x2
    Could it be a belt? That is what it sounds like to me. Is the tensioner pulley going out?
    Gtlegacy, Kpatt9 and markelhof like this.
  10. Jan 30, 2019 at 9:57 AM
    descartesairplnne
    descartesairplnne Well-Known Member
    Justin
    Truckee CA
    2014 Tacoma TRD
    redneck pinstriping, various stickers, not 1 but 2 glade air fresheners because I fart a lot.
    I have the exact same squeal noise in my 14 MT I think its actually the throwout bearing since if I remove the accessory belt it still makes the noise. With regards to the tick, it's most likely just your injectors or valvetrain. I wouldn't worry too much about it unless concerned with prior ownership or improper maintenance specifically oil changes. This is going to sound absolutely absurd but I've had 4 Audi's and once they get over 150K I dump 1QT of Kerosene (Coleman Fluid) in the oil and let it idle for about 5 minutes when warm. Once the oil is changed the valvetrain is buttery smooth and the valvetrain is virtually spotless, I've borescoped the cylinder walls and they always return to the crosshatch pattern from the factory. I'm not recommending this for our Yoda's but it works a treat on high compression tight tolerance cars like Audi.
  11. Jan 30, 2019 at 10:29 AM
    Jericho9419
    It's definitely not the belt, I just replaced it with the OEM serpentine belt. I inspected the pulleys and tensioner, they all seemed to be okay. I'm leaning towards the throw out bearing, as the squeak seems to be affected by the movement of the clutch pedal.
  12. Jan 30, 2019 at 3:43 PM
    Jericho9419
    Well... Just dropped it off at a transmission/clutch shop to get a diagnostic. Hopefully they can pinpoint the issue tomorrow.
    Depoxy likes this.
  13. Feb 1, 2019 at 4:52 AM
    Jericho9419
    Got the truck back last night, the tranny shop could nod determined the squeak/squeal for sure, I was told it could be a throw out bearing, the mechanic also said that the ticking noise is coming from the engine and advised me to take it to another shop to have the engine diagnosed. Not looking good .
    On a positive note I just read that Toyota is about to to roll out the 2020 taco.
  14. Feb 13, 2019 at 6:23 PM
    descartesairplnne
    Justin
    Truckee CA
    2014 Tacoma TRD
    Unless you're worried I think you're all good. I'd save your money for beer!
  15. Feb 13, 2019 at 7:06 PM
    jboudreaux1965
    jboudreaux1965 Ragin Cajun Fan
    Joseph
    Hub City
    2023 TRD Sport
    That doesn't sound right at all. The noise your talking about doesn't seem to change with RPM's that much? Maybe it's just the video, but what's the 'flutter' sound each time you press the gas?
    I'd suggest, first step, wait until she is completely cold, like first thing in the morning. Pull the belt, start recording, start her up, jump on a creeper and let her run for 30-45 seconds and crawl around underneath looking,listening,recording noises without noise from the fan, etc.
    tcjacado likes this.
  16. Feb 13, 2019 at 7:16 PM
    jboudreaux1965
    Joseph
    Hub City
    2023 TRD Sport
    Can you take a video shining a light through the oil fill tube with the engine running? Showing the oil spray on the chains?
  17. Feb 13, 2019 at 7:41 PM
    ToyotaRacingDev
    ToyotaRacingDev SWO Tacoma Enthusiast
    London, Ontario
    2008 Tacoma TRD Sport
    What’s the advantage of fuel system cleaner? I’ve never tried it
  18. Feb 13, 2019 at 8:05 PM
    jboudreaux1965
    Joseph
    Hub City
    2023 TRD Sport
    The benefits are amazing... In Louisiana :) Doesn't do much to help your truck, but it's made from oil products. I have plenty of buddy's who work in the oil field, the more sales the better! :) Families to feed!
  19. Feb 13, 2019 at 8:26 PM
    ToyotaRacingDev
    London, Ontario
    What are the benefits ?
  20. Feb 13, 2019 at 8:28 PM
    ALI3N_123
    ALI3N_123 ( -_・)ᡕᠵ᠊ᡃ່࡚ࠢ࠘⸝່ࠡࠣ᠊߯᠆ࠣ࠘ᡁࠣ࠘᠊᠊ࠢ࠘
    Eric
    Austin, Texas
    2021 Silver TuRD Squirt DCSB 4x4 // 2008 Black Rusty Shitbox DCSB PreRunner
    Is the squeak only in cold temperatures? Mine squeaks in the cold, but spraying some WD-40 on the pulleys makes it go away for a week.
