Weird noise... Timing chain??
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ms4x4outlaws, Jan 20, 2013.
  1. Jan 20, 2013 at 11:31 AM
    ms4x4outlaws
    ms4x4outlaws [OP] Well-Known Member
    Darren
    GULFCOAST, MS
    4X4 TRD OFF ROAD
    MUD TIRES
    I oiled all of the pulleys and it doesn't go away, I have read that it could be the alternator but the noise is coming from both sides. I will upload a vid soon.
    Any ideas?
  2. Jan 20, 2013 at 11:36 AM
    ms4x4outlaws
    Darren
    GULFCOAST, MS
    4X4 TRD OFF ROAD
    MUD TIRES
  3. Jan 20, 2013 at 11:37 AM
    ms4x4outlaws
    Darren
    GULFCOAST, MS
    4X4 TRD OFF ROAD
    MUD TIRES
    Ohh and I def take this truck in the mud as you can see from the vid.
  4. Jan 20, 2013 at 11:41 AM
    P9HST2
    P9HST2 Well-Known Member
    Iowa
    2012 MGM AC TRD OR
    WeatherTech floor liners, tailgate hoseclamp, Famous Fab sliders, Brute Force Fab rear bumper, Icon "3T" suspension.
    Did you pull off the belt and see how the pulleys feel by hand? Sounds like a bad idler or tensioner pulley to me. Adding external oil to the pulleys isn't likely to do anything to them, but not good for the belt if it gets on it.
  5. Jan 20, 2013 at 12:37 PM
    92dlxman
    92dlxman drinking whats on sale
    Kevin
    Visalia, CA
    08 access 4x4 4.0 6-gear
    5100s, ome884s, wheelers aal kit, and some rustoleum
    hey lol, it sounds like a ford! hows yer ps fluid?
  6. Jan 20, 2013 at 12:41 PM
    ms4x4outlaws
    Darren
    GULFCOAST, MS
    4X4 TRD OFF ROAD
    MUD TIRES
    Yea ps is good. That's my other thought but its fine.
  7. Jan 20, 2013 at 12:42 PM
    ms4x4outlaws
    Darren
    GULFCOAST, MS
    4X4 TRD OFF ROAD
    MUD TIRES
    I haven't taken the belt off yet I will later today
  8. Jan 20, 2013 at 12:45 PM
    TeamSarcasm
    TeamSarcasm Flawless Escalation to the Ludicrous
    The better coast
    My 2010 civic with 15k on it was making a wining noise like that. Turned out I had a cracked power steering pump with extremely low fluid. If the sound increases when you turn the wheel I would look into that.
    This is the noise I heard before getting it fixed, needed new pump, pinion rack the whole shabang.
    http://i1228.photobucket.com/albums/ee457/garrin9000/Rec-2013-01-02-11-29-2.mp4
    ediit: I was lazy and didnt read the post before I put this :eek:
  9. Jan 20, 2013 at 1:42 PM
    Vstrom30
    Vstrom30 Well-Known Member
    Midwest
    Tacoma Access Cab 4x4
    Times like this you need a stethoscope so you can put it on or near each suspected component. Sometimes the power steering fluid looks like it's the correct level, but it can be a burnt film left over and stained to the plastic reservoir. It could be any of the above, but it might be worth it to actually pull the power steering cap off and check the stick.
  10. Jan 20, 2013 at 1:46 PM
    The Traveler
    The Traveler Desert Chief
    SoCal
    1991 Toyota Pickup 4x4 Prerunner
    PLEASE PLEASE PLEASE find the origin of this whining sound!!
    My Taco has been plagued with this noise since the day I bought it, and it showed no indication of ever being in mud prior to the purchase. I've checked, flushed, and refilled the PS reservoir with
    Lucas stop leak PS fluid, and it didn't help at all. I think it's an idler gone bad, but I haven't had the time to take it apart and check them one by one.
    Subbed for the end result!
  11. Jan 20, 2013 at 1:49 PM
    98tacoma27
    Ben
    Not Beech Creek
    x2 Sounds like the pulleys
  12. Jan 20, 2013 at 3:05 PM
    ms4x4outlaws
    Darren
    GULFCOAST, MS
    4X4 TRD OFF ROAD
    MUD TIRES
    In pulling belt off as we speak ill let ya know. ImageUploadedByTapatalk1358723154.300109.jpg
  13. Jan 20, 2013 at 3:11 PM
    crazyasu45
    crazyasu45 Well-Known Member
    Canada
    2013 MGM DCLB 4X4 TRD SPORT
    3" SUSPENSION LIFT
    my bets on the altenator...my 98 was making that noise a week before it went...then the wipers and windows started slowing down...no warning lights came up on the panel either...
  14. Jan 20, 2013 at 3:31 PM
    ms4x4outlaws
    Darren
    GULFCOAST, MS
    4X4 TRD OFF ROAD
    MUD TIRES
    I thiught Thats what it might be.. Just checked the pulleys and they aren't that bad, all 3 were just a little wore equally just a little slack in the bearing but still spun freely. I'm sure it's not power steering.then I looked underneath the truck and found this this.
    ImageUploadedByTapatalk1358724559.744917.jpgImageUploadedByTapatalk1358724604.851221.jpg
  15. Jan 20, 2013 at 3:32 PM
    ms4x4outlaws
    Darren
    GULFCOAST, MS
    4X4 TRD OFF ROAD
    MUD TIRES
    I know it just started leaking. I was just under here a week ago. I ran the truck hard (high RPMs) this weekend.
  16. Jan 20, 2013 at 3:42 PM
    92dlxman
    Kevin
    Visalia, CA
    ouch. . . . please keep us updated
    how many miles?
  17. Jan 20, 2013 at 3:47 PM
    Toyota Tech31
    Toyota Tech31 Sometimes when I close my eyes, I can't see.
    Debary, Florida
    '08 SWB Bad ass SPORT
    Air Raid air intake, 40 Series Flowmaster Muffler, Front Turn Signals Now Turn And Park, KENWOOD HEAD UNIT W/ ALL KENWOOD SPEAKER UPGRADES AND 2-10" KENWOOD SUBS BEHIND BACK SEAT, Bilstein 5125'S In Rear W/ 1.5 AAL'S, Bilstein 5100 W/ Eibachs Up Front, LR Upper control arms, NFAB steps, Bruteforce Fab Hybrid front bumper, LP10000 SuperWinch, 2 Rigid Industries SRM-2's, OKLedlightbars 6 CREE LED lights as fogs, AVID RBG, 2 4" red ring HIDs mounted behind the grille.
    First, with the belt off, start the truck and see if the noise is still there.
    Second, that leak is most likely your crank seal, replace that before it gets too bad.
  18. Jan 20, 2013 at 3:55 PM
    ms4x4outlaws
    Darren
    GULFCOAST, MS
    4X4 TRD OFF ROAD
    MUD TIRES
    That's a good idea to crank the truck with belt off I can't believe I didn't do that. Duhh. And yea I'm going to have it replaced soon.
    117000 miles
  19. Jan 20, 2013 at 4:07 PM
    Toyota Tech31
    Debary, Florida
    I just did a crank seal on a 4.0 tundra today. Mine went like a year ago. The tundra was a little easier than ours, but they still aren't that bad.
  20. Jan 20, 2013 at 4:08 PM
    ms4x4outlaws
    Darren
    GULFCOAST, MS
    4X4 TRD OFF ROAD
    MUD TIRES
    Pulled belt off and the noise went away!!! So now I know its something in the belt drive system.
