Weird noise when hitting gas
Discussion in '2nd Gen. Tacomas (2005-2015)' started by iliketurtles, Sep 9, 2011.
  1. Sep 9, 2011 at 3:20 PM
    iliketurtles
    iliketurtles [OP] Well-Known Member
    I drive a 2011 4wd tacoma w/the v6 and 6 speed..whenever I hit the gas in reverse after moving forward or hit the gas in 1st after reversing I get a single, loud click from under the truck. I can't tell exactly where it's coming from, but it sounds to be in the middle of the truck. Has anyone else experienced this or heard of it?
  2. Sep 9, 2011 at 3:24 PM
    trek
    trek the boss man
    California
    2010 tacoma sport TRD
    i get that
  3. Sep 9, 2011 at 3:56 PM
    iliketurtles
    You know what causes it?
  4. Sep 9, 2011 at 6:42 PM
    Tacoma Mike
    Tacoma Mike 43 Year Toyota Master/ASE Master Tech.
    Southern Maine
    2011 Double Cab V6
    Large Storage Box, 02610 intermittent switch swap, "Hot Wire" Power Outlets, DRL Shut Off, Disable Fob Beep, Disable Seat Belt Buzzers, Parking Light Mod, Battery Tender, 4 Leaf Spring Pack, Rear Headrest Removal, Custom Ultragauge Mount, Factory Tow Package (7 Pin) Rear Diff Mod, Taco Lean Mod
    Do you get it immediately when the tires start in the other direction ???
  5. Sep 9, 2011 at 6:55 PM
    Nubes
    Nubes Tacoma Addict
    Texas
    2011 Silver TRD O/R DCSB PreRunner
    Gray WeatherTech's front and back, DeeZee bed mat, Foglight Mod, Magnaflow 12256, Debadged, Ammo Can Storage Boxes, Shrockworks Sliders.
    I got that on my old 2005 A/C 5 speed. It would make a pop sound when I moved in reverse. Never knew what it was but I lived with it, doesn't do it on my 2011 though :confused:
  6. Sep 9, 2011 at 6:59 PM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    That's the front brakes
  7. Sep 9, 2011 at 7:15 PM
    Tacoma Mike
    Southern Maine
    2011 Double Cab V6
    That's where i was heading OZ but he needs to get it confirmed with a buddy listening next to the front end.
  8. Sep 9, 2011 at 7:29 PM
    OZ-T
    Peter North
    British Columbia
    Sure , but I have exactly the same thing , brakes clack after changing direction
  9. Sep 9, 2011 at 7:33 PM
    neoflex
    neoflex Well-Known Member
    My 4Runner does that but the Tacoma doesn't yet which I believe is probably because my pads are not that far worn yet. Toyota trucks pads set themselves when you shift into reverse to the change in direction. Totally normal. Brought the Runner to two different dealers to question it and got the same answer. Seems to be normal in Toyo Trucks once the pads have a decent amount of mileage on them.
  10. Sep 9, 2011 at 8:04 PM
    iliketurtles
    Yes. The Toyota tech seemed to have no idea what it was. I'll ask them about the brake thing. Thanks guys.
  11. Sep 9, 2011 at 8:25 PM
    06SR5canada
    06SR5canada Well-Known Member
    Saskatchewan
    06 dblcab SR5
    2ndary air filter removed, flowmaster 40
    most likely brake pads shifting direction, if that aint it a u-joint is my guess.
  12. Sep 10, 2011 at 4:01 AM
    Tacoma Mike
    Southern Maine
    2011 Double Cab V6
    check it yourself.
    If you hear this nose as described then i have a way to calm it down quite a bit.
    You don't need to go there just to confirm this.
  13. Sep 10, 2011 at 4:03 AM
    brian
    brian Another Traitor
    Elizabeth City, NC
    2008 F-350 Powerstroke
    Just FYI I have brand new pads and mine still does it
  14. Sep 10, 2011 at 4:21 AM
    Toyota Tech31
    Toyota Tech31 Sometimes when I close my eyes, I can't see.
    Debary, Florida
    '08 SWB Bad ass SPORT
    Air Raid air intake, 40 Series Flowmaster Muffler, Front Turn Signals Now Turn And Park, KENWOOD HEAD UNIT W/ ALL KENWOOD SPEAKER UPGRADES AND 2-10" KENWOOD SUBS BEHIND BACK SEAT, Bilstein 5125'S In Rear W/ 1.5 AAL'S, Bilstein 5100 W/ Eibachs Up Front, LR Upper control arms, NFAB steps, Bruteforce Fab Hybrid front bumper, LP10000 SuperWinch, 2 Rigid Industries SRM-2's, OKLedlightbars 6 CREE LED lights as fogs, AVID RBG, 2 4" red ring HIDs mounted behind the grille.
    From our experience, if it's not pad shift, it is typically from the drive shaft changing direction, if that makes any sense. When u put it into a forward gear from reverse, the slack is taken out the first time u hit the gas, thus causing a noise like u are describing. As a Toyota Tech, this is where i would start.
  15. Sep 10, 2011 at 8:37 AM
    iliketurtles
    Thanks. I'll check those out in a few months when I get home.
