Weird noise when start up. help please
Discussion in '2nd Gen. Tacomas (2005-2015)' started by calixto25, Aug 23, 2012.
  1. Aug 23, 2012 at 10:58 PM
    calixto25
    calixto25 [OP] Well-Known Member
    Arizona
    TRD sport
    Hids, billet grille, headlights, fog lights, k&n intake, throttle body spacer, led taillights, led bulb conversion.
    I have a 2005 tacoma trd sport. I live in az so its not to cold out right now but when its colder in the morning first start up there is a shaking noise coming from the passanger side of the truck you can hear it from under the dash the best, out side the vehicle not so good. I have looked for loose bolts, wires, heat sheilds under truck I have no idea what it could be. Does anyone else have this problem or have ran into it?
  2. Aug 23, 2012 at 11:17 PM
    dbkid05tacoma
    dbkid05tacoma Well-Known Member
    Brooks
    Phoenix, Arizona
    05 long travel 4.0L
    Total chaos long travel, fox 2.5 coil overs, glassworks unlimited fenders front and rear, DMZ fab motor mounts, Bilstien 5100s in the rear, k&n cold air intake, 33/12.5r17 red letter grabbers
    check your motor mounts. the 2005 tacomas had a problem with the motor mounts and they break. this happened to mine and the only place i know of that will fix it is DMZ in california. i had mine fixed by him and they are great.
  3. Aug 24, 2012 at 6:38 AM
    calixto25
    Arizona
    TRD sport
    Ok I'll check out the motor mounts. The noise doesn't happen again after the truck starts and runs for about 10-15 min. It's gone after the truck warms up. How do I check the motor mounts to see if they are bad?
  4. Aug 24, 2012 at 6:43 AM
    Maticuno
    Maticuno Resident Pine Swine
    California High Deserts
    2011 Suburban 2500
    JBA Shorty Headers, Flowmaster FlowFX Sing/Dual Exhaust
    Would you describe the noise as a metallic clack, different than the tapping normally associated with the 4.0 in these trucks?
  5. Aug 24, 2012 at 8:46 AM
    calixto25
    Arizona
    TRD sport
    If you were to unscrew a bolt on your seat brackets and wiggle your seat it sounds like that kind of noise.
  6. Aug 24, 2012 at 7:51 PM
    dbkid05tacoma
    Brooks
    Phoenix, Arizona
    05 long travel 4.0L
    get up under the truck an visually inspect them. or if you have someone start the engine while you have the hood up and either side of the engine jumps.
