weird noise????
Discussion in '2nd Gen. Tacomas (2005-2015)' started by johnw, Dec 21, 2009.
  1. Dec 21, 2009 at 4:29 PM
    johnw
    johnw [OP] Well-Known Member
    john
    orlando florida
    06 prerunner v-6 4.0L 4 door
    well you asked for specs..... 06 trd sport speedway blue V-6 4.0 camburg lift spindles extended travel icons total chaos lowers allpro 4" leaf pack 17" xd hoss rims 305/65/17 mickey thompson baja atz Allpro hybrid bumper with 3 kragen HID lights color matched headlights grill craft grill AFE stage 3 CAI wicked flow muffler under cover bed cap inside i have..... wet okole real tree camo seat cover blue oznium dome light stealth sub box with 2 10" kicker comp subs kicker 400 watt amp weathertech floor mats
  2. Dec 21, 2009 at 4:57 PM
    johnw
    john
    orlando florida
    18 views and nobody?
  3. Dec 21, 2009 at 5:00 PM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    Can really hear anything discernible?
  4. Dec 21, 2009 at 5:02 PM
    johnw
    john
    orlando florida
    at 3 seconds you can here then at 4 i let of gas and it goes away then i get back on gas and that little humm or wine noise goes back
  5. Dec 21, 2009 at 5:43 PM
    Asgard
    Asgard Well-Known Member
    06 PreRunner DC SR5 w/LSD
  6. Dec 21, 2009 at 5:45 PM
    johnw
    john
    orlando florida
    oh no not at all listen the noise goes on and of when ihit the gas its a humming
  7. Dec 21, 2009 at 5:51 PM
    IndigoTaco
    IndigoTaco Well-Known Member
    07 Access Cab Sport 4x4
    can't hear anything......
  8. Dec 21, 2009 at 5:53 PM
    johnw
    john
    orlando florida
    oh well i can here it so idk i cant get any better quality
  9. Dec 21, 2009 at 5:57 PM
    rhodehard09
    rhodehard09 sometimes nonsense is the only sense someone has
    tampa, fl
    09 TRD Off Road 4x4 doublecab
    3" lift, allpro u-bolt flip kit,285/75/16 km2s, hella hid lights, hid conversions for headlights and foglights, led everything, debadged, 9145 reverse light bulbs, black tail lights, black headlight mod,trail-gear rock sliders, dynomax ultra flo muffler,satoshi with custom woven stainless grill,hella 100watt floods in grill, pioneer 4100 in dash dvd player, pioneer 800watt 4 channel amp, pioneer 4way 6x9s, pioneer 4 way 6.5s, 2 rockford p3 10's,rockford power 500.1 mono amp w/bass knob, 7 pin relocated, highlift and mount in bed, diff breather mod, led bed lights, secondary air filter removed,t-rex eyelids, mefab bumper bar, muddy under carriage
    may be a wheel bearing or universal joint
  10. Dec 21, 2009 at 5:59 PM
    johnw
    john
    orlando florida
    if it was that would it stop making that noise once i let off the gas?
  11. Dec 21, 2009 at 6:27 PM
    rhodehard09
    tampa, fl
    not necessarily. those parts when under torque act differently than when they aren't
  12. Dec 21, 2009 at 6:37 PM
    johnw
    john
    orlando florida
    oh ok well i will look at u joints tomnmorow
  13. Dec 21, 2009 at 6:44 PM
    Asgard
    If it was the wheel bearing you would hear the noise constantly, I know a bad u-joint or center bearing will make noise only under load (when you accelerate). Do you notice any vibration ?
  14. Dec 21, 2009 at 6:49 PM
    rhodehard09
    tampa, fl
    x2.5 ive had a bad wheel bearing that only made noise under load but it was on my 85
  15. Dec 21, 2009 at 6:51 PM
    carmellocafe
    carmellocafe Begin With The End In Mind.
    KEVIN
    N. California
    2014 TRD OR Access cab longbed
    I'd try changing the rear diff. fluid and greasing all of the u-joints first. :confused:
  16. Dec 21, 2009 at 6:51 PM
    johnw
    john
    orlando florida
    well when the noise is happening i can feel it thru the floor kinda. nothing bad
  17. Dec 21, 2009 at 6:52 PM
    Asgard
    OP has a PreRunner, his u-joints are sealed
  18. Dec 21, 2009 at 6:54 PM
    johnw
    john
    orlando florida
    the truck has a new diff in it. new as in 2-3k on it. because got hit and bent the axle. so new one put in
  19. Dec 21, 2009 at 6:57 PM
    Asgard
    ^^Maybe your driveshaft got bent also. I would just take it to a driveshaft shop and have them look at it, dealer if you're under warranty.
  20. Dec 21, 2009 at 6:58 PM
    johnw
    john
    orlando florida
    this noise just recently started happening. but i will check
