Weird problem with locking truck
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Nickrick, Jun 26, 2025.
  1. Jun 26, 2025 at 7:58 PM
    Nickrick
    Nickrick [OP] Member
    Jersey
    22 Army Green TRD Sport DCSB
    N/a
    Hey all,
    2022 TRD Sport, with the 6MT so I have an H-Key.
    Over the past few days my truck has been.. lazy? To respond to key inputs.
    The most prominent problem is that when I’m done driving, and get out of the truck, it won’t lock .
    Pressing it once or pressing it 50 times won’t change the behavior. It sit there unlocked.
    BUT after trying it and verifying a few times: if I hit the unlock button a few times, it’ll eventually register and be all normal, it’ll let me lock and lock it with no hesitation or delay.
    What gives? Anyone run into this before ?
    I changed the batteries on both keys to no avail , both are doing the same behavior.
    brigsby99 and lastcall190 like this.
  2. Jun 26, 2025 at 10:32 PM
    Speedfreak
    Speedfreak Member in poor standing
    Dave
    Canada Eh!
    2017 Tacoma TRD Sport DCSB 6MT, Blazing Blue Pearl
    Manual Mall Crawler
    My wife's Subaru remote was doing this recently. I threw a new battery in it and it has been fine since. I didn't think it was the battery because it wasn't that old, but figured it was cheaper to try than a new remote.
    xBloodxLinex likes this.
  3. Jun 26, 2025 at 10:43 PM
    eaglehawaii
    eaglehawaii Well-Known Member
    Hawaii
    22 Super White.. ... 18 Magnetic Gray ... 02 Gold RIP in 25
    Fob battery is weak and needs to be replaced.
  4. Jun 26, 2025 at 11:13 PM
    Azrael's Gaze
    Azrael's Gaze Well-Known Member
    Steve-O
    Springfield, Oregon
    2022 Black Tacoma TRD Offroad
    Definitely try the battery
  5. Jun 27, 2025 at 4:37 AM
    Nickrick
    Jersey
    N/a
    Sorry guys I was half awake when I posted this , first thing I did was change the battery which I also thought could’ve been the culprit.
    The unused second key received a new battery and same behavior.
  6. Jun 27, 2025 at 4:55 AM
    Clearwater Bill
    Billy
    Largo Florida
    Are the 'new' batteries fresh?
    Or just previously unused?
    Rednecktacoma22 likes this.
  7. Jun 27, 2025 at 10:28 AM
    Rednecktacoma22
    Rednecktacoma22 Well-Known Member
    Logan, UT
    22 TRD OR 6MT
    I would consider coin cell batteries dead around 2.8v. Might be worth a quick test for the recently replaced ones in the keys.
  8. Jun 27, 2025 at 11:55 AM
    kahanabob
    kahanabob Well-Known Member
    Maui
    16 TRD 2WD 4DR
    You did mention you changed the batteries in you original post.
  9. Jun 27, 2025 at 11:57 AM
    kahanabob
    Maui
    16 TRD 2WD 4DR
    Maybe disconnect the truck battery and the re connect, just a shot in the dark.
    Like a computer when acting up, shut down and re start
  10. Jun 27, 2025 at 2:29 PM
    eaglehawaii
    Hawaii
    Based on the Edit times logged on the two posts made by the OP, it appears he added the note about changing the battery to his original post.
    At any rate, I'm be curious to see what's causing the lock to operate intermittently.
  11. Jun 27, 2025 at 5:00 PM
    Toycoma2021
    Toycoma2021 Well-Known Member
    Northern California, Temporarily
    2021 Access Cab, LB, AT, V6, Off Road
    Does the beep that occurs with locking happen - the beep is from a noise maker in front of the battery.
    If there is a beep the FOB/key is talking to the vehicle, and it may be an actuator within the door(s). That is another question does this happen on all doors or only the driver's door.
  12. Jun 27, 2025 at 5:09 PM
    Grey 2015
    Grey 2015 Well-Known Member
    Skip
    Loxahatchee Florida
    2015 Tacoma
    My wife's 2019 4Runner has a similar issue with the drivers side door lock when unlocking, apparently it's well documented but no recall as of yet.
  13. Jun 27, 2025 at 5:10 PM
    jersey jim
    jersey jim Well-Known Member
    Jim
    2018 Cement DCSB TRD Sport 4x4 6MT
    When mine started doing that it was the fob batteriy, I'm with the others, make sure the new batteries are actually good.
  14. Jul 1, 2025 at 9:42 AM
    Nickrick
    Jersey
    N/a
    newly purchased a day before I posted
  15. Jul 1, 2025 at 9:45 AM
    Nickrick
    Jersey
    N/a
    no response from the truck when it misbehaves. No lights or anything.
    Also to the person who suggested the battery disconnect , I will try this tonight ask well, can’t hurt , sadly I’m out of warranty so the ECU being problematic wouldn’t be covered but , let’s try it.
  16. Jul 1, 2025 at 9:47 AM
    Nickrick
    Jersey
    N/a
    Appreciate the idea, yep I tested them with a multimeter and bought another pack of 4, 8 new good batteries and it’s still acting the same way.
  17. Jul 1, 2025 at 11:06 AM
    jersey jim
    Jim
    Well, so much for the easy fix. Good luck figuring it out.
  18. Jul 1, 2025 at 11:21 AM
    Toycoma2021
    Ok, I’m going from memory right now so give a bit of leeway. Try holding the key closer to the rear door windows of the truck, IIRC the receiver for the locks and the tires is located near the rear of the cab above the head liner. Have you applied some strange type of window tinting? If so try the front of the vehicle through the windshield. Any sound deadening? Just putting a few things out there.
