Weird problem with my Truck- Help
Discussion in '1st Gen. Tacomas (1995-2004)' started by xSpyderguyx, Mar 19, 2012.
  1. Mar 19, 2012 at 7:05 PM
    xSpyderguyx
    xSpyderguyx [OP] Well-Known Member
    Caleb
    Washinton State
    2001 3.4L v6 SR5
    s40 Flowmaster 33" Toyo M/T tires 16" P.A wheels 3" revteck Suspension lift
    So the other day I went to start my truck and when I turned it over there was nothing. No clicking, no indicator lights, no door beeping, it wouldn't do anything when I turned it over. I then checked my batter and I know it isn't dead. It is Die hard premium that is less than a year old. So I got back in my truck and then it mysteriously fired when I tried again?? It hasn't done it since and I have probably fired it 10 or so more times. And then today it Happened again, I fucked around with the ignition and got it again.
    What is going on?
    My truck is an automatic, v6, 2001.
  2. Mar 19, 2012 at 7:07 PM
    MonkeyProof
    MonkeyProof Power Top
    SoCal- SGV
    are the cables properly secured/tight at the battery terminals? have you tried wiggling them?.. shouldnt move at all
  3. Mar 19, 2012 at 7:08 PM
    Max-4_Yota
    Max-4_Yota The Welfare Cadilac
    Michael
    South Carolina
    04 Tacoma 4x4, V6, 5spd
    Squattin'
    Loose connection? Clean the terminals and tighten the up real good.
  4. Mar 19, 2012 at 7:09 PM
    xSpyderguyx
    Caleb
    Washinton State
    2001 3.4L v6 SR5
    Looking at it, and my ground is definetly a little loose. Gonna have to tighten her down.
  5. Mar 19, 2012 at 7:10 PM
    blacksheff405
    blacksheff405 no one ever pays me in gum
    caleb
    north carolina, concord
    02 dbl v6 12' lift on 38's
    lift kit (12'), super swampers 38's, brush gard, kc's , sub, amps, high end audio equipment
    ^ this I had a problem similar and this fixed it
  6. Mar 19, 2012 at 7:10 PM
    MonkeyProof
    SoCal- SGV
    that would be step one to diagnosing the problem :cookiemonster:
  7. Mar 19, 2012 at 7:11 PM
    ruler1
    ruler1 stump thumper
    palmetto fl
    97 2.7 4x4 5speed
    header, k&n intake, ome coils, springs and struts,diff drop, Urd simulator, dynomax exhaust, slotted roters, bpv relocater
    Could be a lot of things. Check for tarnished crusty terminals (actually take them off and look sometimes they are hard to find). After checking electrical hookups for loose grounds or connections check starter. There are copper parts that can wear out and can become intermittent as they get close to failing. If you have power and it doesn't even try to start it can be the starter. Don't rule out the battery until you test it. Free at most parts houses. Good luck and don't just throw parts at it. I hope it's just a loose wire and an easy fix. If you can move the terminal clamp at all it's not tight enough.
  8. Mar 19, 2012 at 7:11 PM
    joes06tacoma
    Joe
    Central Coast, CA
    This. And make sure they are clean beyond any doubt. Pull the cables and wire brush or sand the terminals and the battery posts.
    My brother drove his truck home from work, walked inside, came out ten minutes later and his truck was DEAD. Just like you described. I walked out to his truck and put my voltmeter on the battery posts. 12.6V, fully charged. Then I put the meter probes on the battery cable ends. 0V. It happened in ten minutes time. No explanation. And the terminals looked clean and felt tight. Pulled the cable and sanded the contact surfaces and battery posts. Truck ran another 2 or 3 years with the same old battery in it, no more problems till he sold it. Weird.
  9. Mar 19, 2012 at 7:12 PM
    dfrugia
    dfrugia Well-Known Member
    Goose
    Roswell, NM
    2012 DC TRD OFF RD 4X4
    Running boards w/steps, Weathertechs
    Temp changes - things loosen and tighten up.
