Weird rattle like sound from 6MT under load
Discussion in '3rd Gen. Tacomas (2016-2023)' started by JDKred, Jul 24, 2021.
  1. Jul 27, 2021 at 10:44 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Have you looked at the heat shields on the cat yet? Everyone is quick to overlook the simplest solutions sometimes.
    Junkhead and JDKred[QUOTED][OP] like this.
  2. Jul 27, 2021 at 10:44 AM
    JDKred
    JDKred [OP] Well-Known Member
    JD
    16 MT KDMax Tuned
    I'll check it out
  3. Jul 27, 2021 at 10:53 AM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    Driving a stick isn't only about learning how to shift.
    When to shift is also important.
    Lugging causes pre-ignition and abnormal engine wear.
    OZ TRD likes this.
  4. Jul 27, 2021 at 11:54 AM
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    Just curious OP, is this your first manual or your first truck with a manual transmission?
    Junkhead likes this.
  5. Jul 27, 2021 at 12:55 PM
    JDKred
    JD
    16 MT KDMax Tuned
    No, my last truck was a first gen Tacoma.
    My concern is that the sound, at least from what I can tell, is from the transmission...
    My initial thought was the throw out bearing but I have never had MT issues before so I'm not sure how to diagnose the issue.
    I get that if I was in the wrong gear under load, it could make that sound, perhaps just excessive stress.... But that is why I am gathering ideas and input....
    RustyGreen[QUOTED] likes this.
  6. Jul 27, 2021 at 3:33 PM
    50ate
    50ate Well-Known Member
    Washington
    2019 OR DCSB 6spd
    I have a 19 6spd with kdmax I too got the 87 oct fuel tune. I hear the ping from time to time. I have ran a couple tanks of plus and super and I think it goes away for the most part. I definitely notice it more when the A/C is on. I’m glad I have a manual transmission but I’ll tell ya I miss the days of cars having throttle cables..
    i haven’t looked at the heat shields but that’s cause it sounds like a ping to my ears. If it was shields I could get it to do it more often just through different rpm ranges. Mine happens mostly in the second and third gears
  7. Aug 24, 2021 at 6:45 PM
    Myles G
    Myles G Well-Known Member
    Myles
    Any luck OP? I’m about to take my truck into warranty for the 2nd time with this issue.
  8. Nov 10, 2023 at 7:27 PM
    Dirtytco
    Dirtytco Member
    Josh
    2016 MGM Offroad on Kings
    What was the issue? Any fix to the problem? I am having the same issues and doing some digging. Thanks
  9. Nov 10, 2023 at 7:34 PM
    Tacosha
    Tacosha Well-Known Member
    Andy
    Calgary, AB, Canada
    2019 Black Tacoma TRD OR ACLB 6MT
    minor, TRD skid plate, front recovery points, Regken mud flaps, rear diff breather, AC drain pipe extended. Upgraded sound with active sub woofer, tonneau cover, CB radio.
    Before digging dipper to anything in this case, check heat shields along your exhaust - very often they loose and starting rattling.
  10. Nov 10, 2023 at 7:37 PM
    Dirtytco
    Dirtytco Member
    Josh
    Thanks, I have the same issue as the guy was stating earlier. I can be cruising in neutral/rolling and all is well but when I’m in gear I hear random “chatter” per say.
  11. Nov 10, 2023 at 7:39 PM
    Tacosha
    Andy
    Calgary, AB, Canada
    That's what they do quiet often - changing load and rpm's, shifting gears, e.t.c.
  12. Nov 10, 2023 at 7:43 PM
    Dirtytco
    Dirtytco Member
    Josh
    Ahh I see. It’s weird to me cause it’s a new sound and feel for me. Its a 2016 and I have had it for 7 years and 105k rough miles. Going to change the fluid next.
  13. Nov 10, 2023 at 7:56 PM
    Phlogiston
    Phlogiston There are no victims, only volunteers.
    A@!#$@$%#$%
    The wild west
    2016 SR5 DCSB
    Did you figure it out?
    This is the longest i've held my breath
  14. Nov 11, 2023 at 3:30 AM
    faawrenchbndr
    faawrenchbndr Til Valhalla
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    85 is NOT recommended to be used
    if your noise is not preignition, it is a throw out bearing
  15. Jun 28, 2024 at 4:01 PM
    #35
    Tylerkxj
    Tylerkxj Member
    Orlando, FL
    2021 TRD Pro
    Has anyone figured this out? It's driving me nuts
  16. Sep 29, 2024 at 12:37 PM
    #36
    Motorbreath24
    Motorbreath24 New Member
    Jesse
    Colorado
    2023 DC SB 4X4 Sport 6MT
    Was a determination on this ever made? Is it just normal 3rd gen gearbox noise? Im also experiencing this issue on a 2023 Sport 6MT. It's not my first manual. It's not pre ignition or a loose heat shield. It's definitely a gear box rattle. I first noticed it in 2nd under load between 1-2k rpm. Now its is also happening in 1st in the same rpm range. I haven't noticed it in 3rd on up. The truck is largely stock. The only mods are Trail Edition wheels with 265/75/16 ko3's.
  17. Sep 29, 2024 at 1:08 PM
    #37
    Green Jeans
    Green Jeans 6MT AC TRD OR 1GR-FE FTMFW
    Oregone
    '13 TRD Off-Road
    The MY13 MT I’ve owned since new (sitting at 180l) has TB issues but those are usually called a chirp. When I was dealing with a rattle or “tick” while under load it was only evident with the rear slider open. Replacing the rear u-joints solved my ticking sounds, and helped me narrow down other creaks to worn body mount bushings. YMMV
