Weird Rear End Vibrate/Wheels not spinning evenly?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by rcfreak201, Aug 16, 2011.
  1. Aug 16, 2011 at 10:04 PM
    rcfreak201
    rcfreak201 [OP] Well-Known Member
  2. Aug 16, 2011 at 10:14 PM
    achirdo
    achirdo I Weld!
    Adam
    North DFW
    06 dodge ram 3500 5.9 cummins
    id guess something wrong with the LSD.
  3. Aug 16, 2011 at 10:18 PM
    achirdo
    achirdo I Weld!
    Adam
    North DFW
    maybe you burned out the clutch packs. im not sure. bump the thread in the morning for all the smart people to comment :eek:
  4. Aug 16, 2011 at 10:19 PM
    Warputer
    Warputer Dirt Road Inspector
    Lake Murray, South Carolina
    2011 TRD Off Road
    9" of Super Bro lift
    Shot in the dark here but years ago on another truck, I had a busted leaf spring perch that acted kind of like what you are describing.
  5. Aug 16, 2011 at 10:25 PM
    Warputer
    2011 TRD Off Road
    Square box between the leaf spring pack & the axle housing.....weld busted on this & caused my leaf pack to shift when torque was applied to it.....ended up twising up my drive shaft too. Like i said, it might just be something for you to check.
  6. Aug 17, 2011 at 12:25 AM
    username
    username Fluffer
    Pendleton, Or
    05 Taco with some crap welded to it
    mostly stock
    Is it an automatic or manual? If the lsd was fried that would cause a one tire fire (one spins easy). Inspect the rear suspension, like others said it's wheel hop caused by axle wrap. The best way to fix that is to link it and put a locker in. The cheapest way to fix is to stop driving like a window licker.
  7. Aug 17, 2011 at 10:16 AM
    Hiatt1991
    Hiatt1991 Well-Known Member
    Hiatt
    Ventura, CA
    2022 Toyota Tacoma SR5 DCSB 4x4
    4" Bodylift 20" Offroad shock spacers Turbo Encabulator
    LOCKER FTW!!!!! Trust me, youll really dig one.
  8. Aug 17, 2011 at 10:41 AM
    Hiatt1991
    Hiatt
    Ventura, CA
    ya they are pricey. Maybe you can find a wrecked trd offroad and buy the rear end?
  9. Aug 17, 2011 at 11:01 AM
    Yota Toy
    Yota Toy Taco Sauce
    FX retros, Blazer fog-light retro, JVC KW-NT30HD head unit, Pioneer 6X9's in front doors, Pioneer 6.5's in rear doors, two Pioneer 12" subs in sealed boxes, Sony X-Plod amp, Hidden Hitch trailer hitch, EGR window visors, two PIAA low-tone horns, Westin light bar with two 100-watt KC low profile driving lights.
    You should be able to put a floor jack under the rear diff and get both back wheels off the ground, then just try to turn one of the wheels by hand. If the opposite wheel spins in the opposite direction with ease, LSD likely not working. You should not be able to turn the wheels by hand when both are in the air if the LSD is working properly (with drive shaft stopped, IE in Park on an auto or in gear in a manual (engine off)).
  10. Aug 18, 2011 at 8:58 AM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    hmm weird, is the rear axel hopping up and down?
  11. Aug 18, 2011 at 9:04 AM
    Hiatt1991
    Hiatt
    Ventura, CA
    I really doubt its axle wrap. You said the problem occurred when you had your old leafs as well. I doubt its happening on your new ones. I think is either the tranny or more likely the rear diff. Its got to be where the engine power is transfered to the rest of the drivetrain. Hopefully its not the engine! But I really doubt it.
  12. Aug 18, 2011 at 9:22 AM
    97yota4wd
    Eric
    Mesa, AZ
    keep us updated!
  13. Aug 18, 2011 at 9:42 AM
    Hiatt1991
    Hiatt
    Ventura, CA
    ^ this.
  14. Aug 18, 2011 at 10:03 AM
    kinkrider101
    kinkrider101 Well-Known Member
    santa barbara
    2007 cummins/2007 tacoma
    wheels and tires
    Check your driveshaft at the carrier, the arb locker is expensive, but you can just put a lockright locker in there for much cheaper
  15. Aug 18, 2011 at 11:23 AM
    Jerez
    Jerez SoCal LED Dash Swap
    Rod
    Ontario Ranch
    08 TRD 2wd converted to 4wd
    Estock
    Sub'd :popcorn:
  16. Aug 18, 2011 at 2:39 PM
    Hiatt1991
    Hiatt
    Ventura, CA
    check ubolts. any play in driveshaft?
  17. Aug 18, 2011 at 2:43 PM
    Hiatt1991
    Hiatt
    Ventura, CA
    my bad. Meant to say u-joint. I always mix the two.
  18. Sep 22, 2011 at 7:33 PM
    UMBCrew
    UMBCrew Well-Known Member
    Nic
    Central Valley, CA
    05 6" Pro Comp Stage II
    6" Pro Comp Stage II, 305/65r17 Pro Comp Xtreme AT, Pro Comp 7033 17x9s, AFe Stage 2 Si, All-Pro Rear Bumper, Ultra-Guage, Kenwood KDC-X895, Kicker 6.5 2 ways
    ok same problem here tons of axle wrap on take off and ^^^^^^THIS^^^^^
    is the only answer new LSD or Locker....no other solutions?? im tired of droping cash on this truck
    and i just swapped out all three u-joints and the carrier bearing
  19. Sep 22, 2011 at 7:49 PM
    MartyMcfly
    MartyMcfly Time Traveler
    Rob
    Pahrump Nevada
    15' 4runner Limited 4wd
    see Build page for details.
    U joint is what connects the driveshaft to the diff.
    Did you ever get this figured out? If not, I think it's time to take it into a reputable rear end shop.
    I do all my own work on my truck except welding and driveline. To me the diff is a "magic box", so I'll let the pros work on that. Sounds line you have diff issues.
  20. Sep 22, 2011 at 7:58 PM
    MartyMcfly
    Rob
    Pahrump Nevada
    Sweet! You gonna be at Pismo this weekend? If so, see ya there! :)
