Weird results after LR UCA's installed.
Discussion in 'Suspension' started by Fabulous, Apr 19, 2011.
  1. Apr 19, 2011 at 7:51 AM
    Fabulous
    Fabulous [OP] Well-Known Member
    Fabian
    Calgary, AB
    2017 Tacoma double-cab TRD Sport
    TRD Pro grill and fog lights, Toytec Boss lift, 265/70-17 Duratracs on 17 x 8.5 FN Verge wheels, LEER canopy, 30% tinted front windows.
    So prior to installing my LR UCA's my lift was at about 2.5/ 2.6" of lift in the front with the Eibach springs, and 5100's set at 0.85. I installed my UCA's over a week ago, and my truck is sitting at 3" now?! I don't get it. I followed the instructions, and tightened the long upper bolt to 83 ft/ lbs when the truck was on the ground...could this be the issue as the truck was at approx. 3.5" higher when I put it on the ground and tightened the bolt. Should I loosen the bolt over the weekend while I'm out of town and see if it makes a diff? Anyone have any insight on this?
  2. Apr 19, 2011 at 8:13 AM
    PreRunnerSeth
    PreRunnerSeth Well-Known Member
    Apex, NC
    15 Black DC OR Prerunner
    Most likely it was because your suspension couldnt droop anymore because of the limits of the stock ball joint, once you added UCA's it could go lower.
  3. Apr 19, 2011 at 8:21 AM
    Fabulous
    Fabian
    Calgary, AB
    It could go lower with the stock UCA's...like about 2" when you'd jack it up...
  4. Apr 19, 2011 at 8:22 AM
    PreRunnerSeth
    Apex, NC
    Wait! you said you installed LRs.... did you preload the suspension before you torqued them? the long bolt that holds them to the frame side needs to be left loose til you set it in the ground then torqued. They are like stock UCAs and need to be preloaded. I bet this is your problem.
  5. Apr 19, 2011 at 8:25 AM
    Fabulous
    Fabian
    Calgary, AB
    I put it on the ground and tightened the bolt, but it was still sitting at 3.5" or higher...think I should loosen them off and let sit, then tighten them up after a few days? I'm going to be out of town all weekend anyway...
  6. Apr 19, 2011 at 9:42 AM
    Fabulous
    Fabian
    Calgary, AB
    Anyone...
  7. Apr 19, 2011 at 9:51 AM
    silver taco
    silver taco Well-Known Member
    Los Angeles
    07 4X access cab
    Icon 2.5 ext travel, Camburg 1.25" uca's, All-pro leafs, Icon 2.5" rear shocks, LR jounce front and back, breather mod, KR Fab rear bumper, Kenwood 2m radio, All-Pro sliders, Front bumper by Surfinferno (Dylan), Glassworks fenders, 4:56 gears, gusseted spindles and coil buckets
    I don't know why that is. It sounds like you tightened them correctly. I wouldn't worry about loosening and tightening them again.
  8. Apr 19, 2011 at 9:55 AM
    Fabulous
    Fabian
    Calgary, AB
    Yeah, it's really weird... Maybe I will loosen them up a bit for shits and giggles and see what it does.
  9. Apr 19, 2011 at 2:44 PM
    silver taco
    Los Angeles
    07 4X access cab
    Also the customer service with the manufacturer is pretty good. It wouldn't hurt to give them a call.
  10. Apr 19, 2011 at 9:44 PM
    S.S.T.
    S.S.T. Well-Known Member
    Torrance, CA
    07 TRD Off Road Access Cab
    Icon 2.5 Extended Travel Coilovers, 5100 rears, Icon Progressive 3 leaf AAL, Hankook Dynapro ATM 265/75R16, 16x8 Renegade 6 wheels, AFE Pro Dry S air filter, BHLM.
    Little off topic, but did you get the UCAs due to not being able to get good alignment specs? I have Eibach/5100s at 0 and want to go to the .85 setting, but don't really want to buy UCAs if possible.
  11. Apr 19, 2011 at 9:46 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Drive it a little bit. It should settle down.
  12. Apr 19, 2011 at 9:50 PM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    How are you measuring, and have you gotten an alignment yet. It could be you are higher up due to the alignment being changed and you riding on a "corner" of your tire, and if you measured from the ground to the truck it could be off.
  13. Apr 20, 2011 at 6:29 AM
    Fabulous
    Fabian
    Calgary, AB
    I got the UCA's to improve my alignment. The alignment is currently at 2.4/2.7 caster, 0.1 camber and 0.01 toe. I have driven it around and filled my tank, etc...makes no difference. My measurement from hub to fender is currently 23" which is 3" higher then stock, and roughly 0.5" higher then before the UCA's?! When I first did the lift 6 months ago it took about 4 days to settle to 2.6 ish inches, but this time it has been a week and a half and no change...
  14. Apr 20, 2011 at 6:32 AM
    Fabulous
    Fabian
    Calgary, AB
    Could it be due to cold weather? It's still below freezing at night, and barely above 3/4 degrees C during the day...
