Weird revving issue
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Alcatraz1015, Apr 9, 2021.
  1. Apr 9, 2021 at 1:45 PM
    Alcatraz1015
    Alcatraz1015 [OP] Well-Known Member
    Matthew
    2018 MT Super White TRD OR DCSB
    Hello,
    I have a weird one. I almost thought it was my automatic transmission slipping, but that's not the case. I want to see if anyone else is having this "issue."
    Example: I'll be cruising at 60mph. I let completely off my accelerator pedal. Coasting. Then I go to lightly reengage the throttle - well any time I do this it's like my '19 Tacoma shifts ever so briefly into 5th and then once it realizes I'm not really trying to accelerate it goes back into 6th. I can make it do that every time no matter my speed or engine load it seems.
    What is the world is going on?
  2. Apr 9, 2021 at 1:46 PM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    Could be your torque converter lockup.
    @Vlady had logged a bunch of data, wonder if he's seen something similar
  3. Apr 9, 2021 at 1:47 PM
    GrundleJuice
    GrundleJuice Well-Known Member
    Michigan
    2016 TRD Bro
    [S]Un-Molested[/S] Lightly Molested
    Not sure, but probably chalk it up to the laughable Toyota transmission control on these trucks. It's so bad it's depressing.
  4. Apr 9, 2021 at 1:49 PM
    tclavell
    Troy
    Phoenix, AZ
    G70
    I'd like to say most people experience gear hunting with the 3rd Gen Tacoma's. I'd also like to say, you may get a response that this is normal. What I can help with is that getting the truck OV/vF Tuned will help drastically with the gear hunting.
    ...but i could also be way off here
    tonered likes this.
  5. Apr 9, 2021 at 1:49 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    The TC is always in Flex Lock (slip lock / partial lock) while coasting. Getting on the throttle will raise the revs a bit until the TC goes back into full Lock.
  6. Apr 9, 2021 at 1:50 PM
    Alcatraz1015
    Matthew
    Cool. So nothing to be concerned with? Thanks, Tonered.
    tonered[QUOTED] likes this.
  7. Apr 9, 2021 at 1:52 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    You're welcome!
    As long as it isn't going for the limiter with gentle throttle, then it is pretty normal. A lot of times, the TC bouncing through the three phases (Unlocked fluid coupling, Flex Locked, and Locked) can feel like a shift.
  8. Apr 9, 2021 at 1:53 PM
    tclavell
    Troy
    Phoenix, AZ
    G70
    ^ what he said :D
    tonered and Alcatraz1015[OP] like this.
  9. Apr 9, 2021 at 2:12 PM
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    Once you let the pedal off, TC unlocks. Then, I assume, the speed drops and the amount of be pedal at that speed calls for the downshift or SLU solenoid turns off in 6 (controls partial locking) for these conditions.
    Try in ECT mode. Should be a different behavior.
    TC locking/unlocking usually robs you off ~200 RPMS.
    Junkhead likes this.
  10. Apr 9, 2021 at 3:18 PM
    gearcruncher
    Canadain bumper technician
    I believe your injectors also turn off when you move your foot off the gas pedal .
    Then , once your foot is back on the gas pedal , the injectors fire up again .
    A lot going on with these newer computer controlled trucks to save fuel and a lot of these fuel saving ideas create drivability issues that can really be felt in the drivers seat .
    Kev250R, tonered and tclavell like this.
  11. Apr 9, 2021 at 4:43 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Yes. Deceleration Fuel CutOff. After a couple seconds over 1,400rpm, the injectors cut out. Coming on, they can really be felt when in 1st or 2nd on the MTs. I imagine it is the same on the ATs.
    Not fun in downhill traffic or off-road, esp in the Taco. I never felt them come on like that in any other EFI vehicle.
    gearcruncher[QUOTED] likes this.
