Weird screeching noise??
Discussion in 'Street Trucks' started by Kavik, Sep 10, 2012.
  1. Sep 10, 2012 at 6:26 PM
    Kavik
    Kavik [OP] Kavik
    Texas, DFW
    Not your everday 5 lug
    Lowered: 3 inch drop blocks (Beefed Taco),Satoshi Grill, Morimoto bi-xenon H1 Retrofitted headlights, Flowmaster exhaust, Blue LED interior and exterior, blue LED dome light, Anzo black LED taillights, Hifonics Brutus 1100w Mono Block, Bazooka 300w Amp, LED license plate lights. Lifited: Fat Bob's rear shocks, Fat Bob's 3" spacer and rear AAL, Nitto Terragrapplers, weldertaco wrap around rear tube bumper, TrailWorx Fab tube front bumper
    Alright, I noticed when I come to a slow steady stop, one or both of my rear wheels start to screech. I don't think anything is rubbing but I need to crawl up under there to really check, you guys have any suggestions what this sound could be caused by?
  2. Sep 10, 2012 at 6:28 PM
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
    Brakes ?
  3. Sep 10, 2012 at 6:34 PM
    07TacoRidah
    07TacoRidah SHHHH, this is interesting
    2007 Base Model Access Cab
    Engine bay: aFe Pro Dry filter Secondary air filter deleted Sokie Tech hood damper kit OReiley battery terminals Big 3 upgrade (0g wiring) 2012 Headlight swap HID kit (headlight 6k/fog light 3k) Sylvania Zevo LED turn signals w/hyper flash resistors Rear back up light GY6 bulb Bullz Audio 0g wire Exterior: Dynamik Retro Projector style headlight housing Depo Euro Black Altezza LED tails 2012 front grill/bumper cover w/ fog light and hood swap Rear bumper swap (to chrome, painted w/bedliner paint) 99 Cents Store tailgate lock Suspension: XR Bilsteins Universal Air Suspension strut bag Custom UCA's DJM 4" rear drop kit 1" spindle spacer kit 4x4 leaf pack swap (middle leaf removed) Air Lift rear helper springs 4 Siria (Asco) 3/8" air valves 3 gallon air tank 1/4' air lines 90's Acura Integra door switches to air valves ViAir 450 air compressor Rims: 18x10 Work VS-KF front w/5" lip 18x11 Work VS-KF rear w/6" lip 225/40/18 tires all around Sick Speed 3 piece spike lug nuts Pepboys valve stem caps 1" wheel spacers all around Interior: Wink Mirror rear view Center console lid fabric Metra Dash kit Kenwood bluetooth headunit Hifonics Zeus ZXi 6410 PB 6 1/2" component speakers up front 10" single Hifonics subwoofer 10" sealed angled box Katana shift knob
    you have 4x4 leafs on? if you do it's those. Make your truck sound like it's all ancient when you hit the brakes or like when you go over bumps and stuff?
  4. Sep 10, 2012 at 6:34 PM
    Kavik
    Kavik [OP] Kavik
    Texas, DFW
    I just replaced the front today, but this sound has happened for awhile, I am just now fed up with it. Anyways, it doesn't make that subtle screech like when you need your brakes replaced, its very loud but I guess I could try replacing the rear brakes also. Could it be anything else?
  5. Sep 10, 2012 at 6:36 PM
    Kavik
    Kavik [OP] Kavik
    Texas, DFW
    nope, stock leafs, 3 inch drop but it also did it with the 2 inch so I know that is not it.
  6. Sep 10, 2012 at 6:38 PM
    07TacoRidah
    I would say have a look at your rears, there could be just dust all up in the drums or just grinding metal period. Either way you can eliminate through that even if it isn't.
  7. Sep 10, 2012 at 6:42 PM
    Kavik
    Kavik [OP] Kavik
    Texas, DFW
    Someone suggested a bad wheel bearing. Is that possible?
  8. Sep 10, 2012 at 6:54 PM
    07TacoRidah
    with these trucks almost anything is possible. #smh.
  9. Sep 10, 2012 at 6:59 PM
    Kavik
    Kavik [OP] Kavik
    Texas, DFW
    Well I guess I will start with new rear brakes and then work from there.
  10. Sep 11, 2012 at 6:49 AM
    pinktaco808
    pinktaco808 Hot Steppa
    Maybe your ebrake stay on.
  11. Sep 11, 2012 at 8:44 AM
    Kavik
    Kavik [OP] Kavik
    Texas, DFW
    Yeah that's it.
  12. Sep 24, 2012 at 11:05 PM
    07TacoRidah
    might be having the same problem as you. for some odd reason when I brake when moving slowly, I get this odd noise form the back. almost sounds like microphone feed back.
  13. Sep 25, 2012 at 2:52 AM
    Kelson
    Kelson Well-Known Member
    Kelson
    Honolulu, Hawaii
    08 5-Lug Reg. Cab SR5
    SR5 Exterior/Interior (Color matched Front Bumper, Chrome Grille Surround and Chrome Rear Bumper/Silver Scoshe Dash Kit, A/C Bezel, A/C Vent Surround) LED license plate and white interior lights, Wet Okole Seat Covers, iPad in-Dash, JL CL-RLC, JL 13TW5 sub, JL 500/1 Slash V1 amp, JL XR 6.5 Components, Rockford Fosgate 6X9s in Boxes Front XRunner Coils, DJM Control Arms and Rear 4X4 Leafs, Custom 2" Angled Streetacos.com Blocks Front XR Bilstien Struts and Rear XR Bilstien Shocks, CravenSpeen Antennae, RX-8 Rims w/ Fronts:235/40-R18 Sumitomo HTR Rears:245/40-R18 Goodyear Eagle GT, 35% Tint front windows, OEM Sliding Privacy Glass w/ 5% Ceramic Tint, Flowmaster Super 44 dumped before the axle, URD Short Throw Shifter, Door Sill Protectors, Door Edge Guards, OEM Sport Pedals,The Retrofit Source Morimoto Mini D2S Stage III 35W 5K HID Headlights, OEM Fog Lights w/ piss yellow bulbs, OEM Cruise Control, Porsche 944 Bucket Seats, BeefedTaco Skid Plate, Whale
    something to do with brake proportioning. i need to deal with this as well...
  14. Sep 25, 2012 at 11:08 AM
    07TacoRidah
    you to???? :mad: I can put up with it for now until the weekend, hope it's a simple fix.
  15. Sep 25, 2012 at 8:31 PM
    Kavik
    Kavik [OP] Kavik
    Texas, DFW
    yeah, that is the exact noise, I wanna know what it is!
  16. Sep 26, 2012 at 6:45 AM
    Who Dat Popcorn
    Who Dat Popcorn Dafuq
    Ricky
    Richmond, VA
    Sold :/
    SOLD
    Yup, every one that I know of that has a lowered second gen has the howling noise when braking. I know of a fix for the first gens, but haven't seen it done on the 2nd's yet.
  17. Sep 26, 2012 at 7:29 AM
    07TacoRidah
    mother .... :mad: I noticed it a lot more when I got my front lowered. What's the first gen fix?
  18. Sep 26, 2012 at 8:48 AM
    weazleburger
    weazleburger Well-Known Member
    Baton Rouge, LA
    07 base reg cab 5-speed
    same noise here. always been told it was break proportioning also
  19. Sep 26, 2012 at 12:44 PM
    Kavik
    Kavik [OP] Kavik
    Texas, DFW
    If someone knows the fix plz post it here asap
  20. Sep 26, 2012 at 9:26 PM
    Who Dat Popcorn
    Ricky
    Richmond, VA
    Sold :/
    SOLD
    Well Brian (beefedtaco) makes a kit for it, I think. Basically it moves the BPV (brake proportioning valve) up a few notches, which in turn stops the noise. I haven't seen it for a second gen, as I said.
