Weird shaking n creaking when turning steering wheel and scrapes when going in driveway HELP!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by killa taco, Jun 18, 2015.
  1. Jun 18, 2015 at 10:32 PM
    killa taco
    killa taco [OP] Killa Taco
    Ricky
    La Puente
    2007 tacoma prerunner double cab short bed
    Toytec blistein adjustable lift kit eibach springs with add a leaf in back 265/75/r16 cooperATP AT
    :annoyed:Hi TW I got a 2wd prerunner 2007 with a blistein adjustable lift kit with eibach coils but my front end when stopped or pulling out of a parking spot turning the steering wheel it shakes and makes a creaking noise also when turning in or going into a driveway it scrapes also help please any info appreciated
  2. Jun 18, 2015 at 10:34 PM
    95 taco
    95 taco Battle Born
    2003 4x4 TRD SR5 auto
    OME 883 front, OMD 3.5" rear, Relentless front bumper, smittybilt 9.5K winch
    Welcome to TW.
    What size tires do you have? It sounds like you have larger than stock tires.
  3. Jun 18, 2015 at 10:46 PM
    killa taco
    Ricky
    La Puente
    There 265/75/16 I thought bout that bt it can't be another thing I.had my wife check for me one time n said it wasn't that and wouldn't my lift help with that issue to
  4. Jun 18, 2015 at 10:49 PM
    95 taco
    95 taco Battle Born
    Huh, that size shouldn't rub stock or lifted.
    not necessarily, the tires get taller and wider as you go up in size (Generally) and when you turn it can cause you to rub the frame.
  5. Jun 18, 2015 at 10:53 PM
    killa taco
    Ricky
    La Puente
    Yeah that's what I'm thinking idk might be sway bar links tie rods you think my lcas seem a little worn out to maybe that..
  6. Jun 18, 2015 at 11:59 PM
    killa taco
    Ricky
    La Puente
  7. Aug 15, 2015 at 11:45 PM
    killa taco
    Ricky
    La Puente
  8. Aug 16, 2015 at 1:15 AM
    TrdSurgie
    TrdSurgie revised
    Oahu
    I have a similar problem. Its alignment related in my case.
  9. Aug 16, 2015 at 9:04 AM
    devkurf
    devkurf Member at Large
    midwest
    Are your brakes good? Wheel bearings, rusted LCA bolts, u-joints, CV axles? Just throwing some thoughts out there.
  10. Aug 21, 2015 at 1:40 PM
    killa taco
    Ricky
    La Puente
    I changed the brakes n barley switched out the LCA'S on both sides haven't gone for alignment bt I think I might have to change tie rods bt not sure tried taking it to mechanic but hard to find a good one they don't really know what there doing :argue::bananadead:
  11. Aug 21, 2015 at 2:09 PM
    fixer5000
    fixer5000 the logical one
    massachusetts
    2018 4runner limited in nautical blue
    is this happening at full lock one side or the other? if so its hitting the steering stops...grease them!!
  12. Aug 21, 2015 at 2:12 PM
    killa taco
    Ricky
    La Puente
    Are those the metal plate by the hub? And when getting close to full lock it does it
