Weird shifting on cold start
Discussion in '3rd Gen. Tacomas (2016-2023)' started by mjillson, Nov 12, 2024.
  1. Nov 12, 2024 at 12:43 PM
    mjillson
    mjillson [OP] Well-Known Member
    New to me 2020 TRD sport. It seems on a cold start shifting is awful and the truck lacks any power (I know, in general its a pig). It seems to try to shift and its almost like its in neutral and the rpm's go up to 3k and then it shifts. After about 2 minutes of driving all is well. Is this normal?
  2. Nov 12, 2024 at 1:26 PM
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
    Have you checked the transmission fluid level? My truck came from the factory 1 quart low and had your symptoms.
  3. Nov 12, 2024 at 1:33 PM
    atc250r
    atc250r Recovering Ram Owner
    Orange County, NY
    2022 Tacoma SR5 - DC/LB
    LED interior, license plate, and fog lights. More to come.
    Could be low fluid. As the fluid heats up it expands so it might just be low enough to act up when cold then get better as it's warms up. Unfortunately checking the fluid is not as simple as it was in the old days.
  4. Nov 12, 2024 at 1:42 PM
    eurowner
    eurowner Duke Sky
    Scoty
    Cold as in -10*F? My '17 TRDOR is fine at -20*f, though I do not bring up the revs above 3000, I leave it in S2-3 until the coolant temp needle moves.
    Canadian Caber likes this.
  5. Nov 12, 2024 at 1:54 PM
    Stocklocker
    Stocklocker Well-Known Member
    17TRDORDCSBAT
    Most autos don’t work great when cold. You might need to lower your expectations. The 3G tranny has a heater to speed up the process of acting normal. My work F150 clunks like it’s gonna drop the tranny on the pavement if it’s slightly below zero C and it’s a brand new truck.
    Jakerou likes this.
  6. Nov 12, 2024 at 2:25 PM
    mjillson
    Oh no not cold cold, like 45 degrees haha.
  7. Nov 12, 2024 at 2:32 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    For the fun of it, how many miles on the spark plugs
  8. Nov 12, 2024 at 5:16 PM
    mjillson
    It’s new to me but I’m assuming they are original .. 54k miles
    Steves104x4[QUOTED] likes this.
  9. Nov 12, 2024 at 6:52 PM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    54k? Perfect time to do a drain n fill on the transmission, keep that fluid fresh and just keep doing them every 30-40k. 3 quarts is cheap and easy. While you are at it, you'll be checking the fluid level.
    t0p_d0g likes this.
  10. Nov 12, 2024 at 8:29 PM
    2021SR5V64WD
    2021SR5V64WD Well-Known Member
    2021 SR5 V6 4WD ACCESS CAB
    I'd like to quiz the genius who designed this thing so you can't check the fluid level
    with a dipstick. Can anyone suggest a reason why they did away with this? Is it me?
  11. Nov 12, 2024 at 9:06 PM
    betrayus
    betrayus Milk steak connoisseur
    Denver, CO
    2021 SR5 DCSB 4x4 AT (MGM)
    Stock
    Manufacturers have been getting rid of check holes on trannys for like 20+ years. Its not new. The idea is you shouldnt need to check it before service intervals anyways, so no need.
  12. Nov 12, 2024 at 10:05 PM
    2021SR5V64WD
    Ha - just shows you how long I drive my vehicles LOL...
  13. Nov 13, 2024 at 9:49 AM
    Canadian Caber
    Canadian Caber R.I.P Layne Staley 67-2002
    Les
    B.C. Canada, eh
    2020 TRD Sport DCLB 4X4 Super White
    And..... promoting life long ATF.
  14. Nov 13, 2024 at 9:58 AM
    2021SR5V64WD
    I can understand the theory - but it seems it's an item that should be filled to proper levels from the get-go.
  15. Nov 14, 2024 at 6:17 PM
    mjillson
    I am no mechanic so excuse my ignorance... drain and fill or flush?
