Weird Shifting on New Tacoma
Discussion in '3rd Gen. Tacomas (2016-2023)' started by BuffGator, Apr 13, 2023.
  1. Apr 13, 2023 at 9:20 PM
    2021SR5V64WD
    2021SR5V64WD Well-Known Member
    2021 SR5 V6 4WD ACCESS CAB
    Never had an issue with my new 21 SR5. Drives like a dream. Steady as she goes for 2000-3000 miles....
    Stevie17 and zoo truck like this.
  2. Apr 13, 2023 at 11:19 PM
    ktbell444
    ktbell444 One who throws exceptions
    ᚺᛖᛚᚺᛖᛁᛗ
    The learning process only occurs when the engine is at normal operating temperatures. So if you're one of the few that start the truck, immediately drive off, and only drive a mile until you're at your destination, then it will take much longer to settle in. Try allowing the truck to warm up a bit (5-10, minutes) before taking it for a spin to learn.
    Also, the learning process will never "end", it's always learning and adapting while the engine is at temp.
    Stevie17 and BuffGator[OP] like this.
  3. Apr 14, 2023 at 2:57 AM
    Library unicorn
    Library unicorn New Member
    Trying to squeeze every mpg possible by keeping rpms low. Best thing to do, for the first few thousand miles is drive if like you stole it. I mean first few gears on acceleration bring it up to 4k-5k rpms. The computer will learn how you drive and adapt. Then when you go back to driving normal, the transmission will behave like it should. If you already have a lot of miles, you can reset the battery too to reset the computer.
  4. Apr 14, 2023 at 5:57 AM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    there is nothing wrong with it,,, it's just different, thank your big GOV for that.
    The characteristics should have been noticeable enough to realize on a short test drive,,, if there even was one. I know, shortages, strange times.
  5. Apr 14, 2023 at 6:27 AM
    BuffGator
    BuffGator [OP] Active Member
    I did take a test drive. It’s driving similarly now but I was told they would get better with time… just didn’t realize the time frame was longer than a hundred miles. I feel a lot better if it’s just an ECU issue. My primary concern was transmission itself.
    Stevie17 and Chew[QUOTED] like this.
  6. Apr 14, 2023 at 6:35 AM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    With only 200 miles this is the learning stages of your automatic in these gen3 tacomas. Mine did the same. The dealers service manager told me at all costs to try to avoid using the S modes or ECT, and no towing for at least a 1000 miles. Doing so screws up the learning process, where you'll end up with a transmission that doesn't know when to upshift. I did so, and my truck runs perfect. Takes at lest 1200-1500 miles before these trucks run normal. I couldn't be happier with mine how smooth it operates.
  7. Apr 14, 2023 at 6:39 AM
    Devious6
    Devious6 Not your Average College President Emeritus
    Mark
    Northeast Pennsyltuckyvania
    2020 Army Green TRD Pro
    As lots of people have noted, the transmission learns your driving habits and the shift points will change in a 1000 miles or so. Some people still find it quirky. Personally, I have no issues with mine.
    Stevie17, BuffGator[OP] and zoo truck like this.
  8. Apr 14, 2023 at 6:40 AM
    deaps
    deaps Well-Known Member
    2023 TRD OR
    Just drive it.
    When you want it to go faster, hit the gas pedal harder.
    When you want to go slower, let off the gas pedal some.
    If you want to go more slower, hit the brake.
  9. Apr 14, 2023 at 6:51 AM
    zoo truck
    None
    Yep, its called driving your truck.
    Stevie17 likes this.
  10. Apr 14, 2023 at 6:58 AM
    N3FOLMike
    N3FOLMike Well-Known Member
    2021 Tacoma TRD OffRoad
    Brake it in slow. Don't race the engine too much.
  11. Apr 14, 2023 at 7:06 AM
    skidooboy
    skidooboy titanium plate tester
    central lower mich
    2019 Tacoma Sport KDMax Tuned, Cement
    dd light bars, trd cat back exhaust, KDMax tuned, trd skid plate, 2" lift, sema wheels toyo open country at3 tires.
    If you dont want to go the tuned route, use S4 in town, and speeds below 55, then D for above 55. it is the only way, unless you buy a manual transmission, where you choose the appropriate gear, for what you want, need. Ski
    saltybum and 2022mgmtrdsport like this.
  12. Apr 14, 2023 at 7:12 AM
    Canadian Caber
    Canadian Caber R.I.P Layne Staley 67-2002
    Les
    B.C. Canada, eh
    2020 TRD Sport DCLB 4X4 Super White
    Exactly as others have mentioned. I found this video series from TCCN helpful.
  13. Apr 14, 2023 at 7:16 AM
    goingplacesanddoingstuff
    goingplacesanddoingstuff Well-Known Member
    2019 TRD Off Road
    2.5” OME lift, Koenig Six Shooter wheels, 275/70r17 Nokian Outpost AT, CMC, Nitro 4.88s, Greenlane aluminum sliders, CBI aluminum skid, Greenlane aluminum front bumper, Out Gear Solutions HC rear bumper, Baja SAE fogs
    Fair warning, it will never be consistent.
    saltybum, Stevie17, usmc2msu and 2 others like this.
  14. Apr 14, 2023 at 7:19 AM
    BuffGator
    Good feedback. I will have to tow before 1000 but not before 500. Truck took forever to deliver and I have to move soon. Boat (16 foot, only 1500 lbs with trailer) is coming with and I’m not going to push past 50 until I hit 1000 miles… worst case, I’ll disconnect the battery cables for 30 minutes and go through the learning process again.
  15. Apr 14, 2023 at 7:21 AM
    #35
    greengs
    greengs Well-Known Member
    AB, Canada
    2022 Tacoma Pro, 2023 Gladiator Mojave, 89 W126
    This is my second 3rd gen and I agree. While it does get a bit better, if it bugs you now, the "learning" will not help it completely. On both of ours, they continued to hunt. Around town the most annoying part is it shifts 1-2-3 back to 2 back to 3 to 4 back to 3. This happnes quickly and it can be annoying.
    usmc2msu likes this.
  16. Apr 14, 2023 at 7:37 AM
    #36
    Wwjvd
    Wwjvd Well-Known Member
    Jimmy
    2022 TRD Off-road 4wd
    All aboard the band wagon!!!!!
    • Drive it, it’s still learning!
    • If your unhappy with it now, you’ll hate it forever!
    • ECT mode, Toyota made it so it only drives right in ECT mode!
    • Tune it! You need the KDOV Bang-shift 3000 tune. My brothers mailman has it and its the only good one.
    Happy Friday.
  17. Apr 14, 2023 at 7:39 AM
    #37
    phdog
    phdog Well-Known Member
    Jim
    Northern Colorado
    2017 TRD Off Road
    w/Super Terrific Happy Hour Mod
    There's no doubt the transmission on these is a bit wonky. However, it's not THAT bad. I live in CO with plenty of mountain driving. It will sometimes want to spend too much time in 5th or 6th so I just put it in S4 and not worry about it. Just because it's an auto trans doesn't mean the driver doesn't have to make decisions from time to time. I rarely use the ECT button. It doesn't really do much. Might help a bit towing or in the mountains but I wouldn't bother trying to use as a fix for daily driving.
    I put about 60K miles on mine and never really had too many issues. It wasn't perfect but overall it really wasn't that bad. However, I did finally get a tune. It was more out of curiosity and it did make a noticeable difference. I think it's worth it.
    I'd suggest giving it a few thousand miles for the truck to break in and for you to get used to it. If you still find it annoying suck it up and get a tune. I did KDMax and now my ECT button actually does something useful.
    usmc2msu and Sinister184 like this.
  18. Apr 14, 2023 at 8:12 AM
    #38
    2019 TRD Off Road
    Everyone has an opinion whether it’s ok or unacceptable. I’m in the unacceptable camp as many know.
    I’m also in CO, running 4.88s and KDMax on 32”s. It’s… still not great. I can understand someone thinking it’s ok with nothing to compare to. But my Pilot also has a 3.5 V6 and 6 speed auto, and it’s SO much more predictable. It really shows how poorly the Tacoma’s transmission works for the application.
  19. Apr 14, 2023 at 8:15 AM
    #39
    Pdog7
    Pdog7 Well-Known Member
    2018 TRD OR DCLB
    OME BP-51 Nitto 285's C4 Low Pro Bumper Mobtown Skids
    Wait as long as you want, it will never get better and always gear hunt. Tuning is the only way to ensure it will drive the way you would expect.
    usmc2msu and slvrtaco11 like this.
  20. Apr 14, 2023 at 8:22 AM
    #40
    phdog
    Jim
    Northern Colorado
    2017 TRD Off Road
    I have a 6 cyl outback so I have something to compare to. The taco doesn't drive even a bit close to the outback. That thing is practically a race car (of course I've never driven a race car so probably not really close at all). It would be nice if the taco drove like my outback but it doesn't. I accept that since they are different and have different uses. If a Ford Ranger drove like my outback I'd still pick the Tacoma. Everything is a compromise somewhere.
    saltybum likes this.
