Weird shimmy, Transmission
Discussion in '1st Gen. Tacomas (1995-2004)' started by tacomabrewer, Jun 19, 2013.
  1. Jun 19, 2013 at 2:16 PM
    tacomabrewer
    tacomabrewer [OP] New Member
    chris
    yakima, wa
    95 Tacoma 2.7L 4WD
    bulked up leaf springs
    So my 95 Tacoma has aquired a noisy, semi-clunking shimmy when driving. If I press in the clutch while it is moving it goes away as it also does if sgifted in nuetral and coasting. I think this means that it is something to do with the transmission, and not an out of balance tire which is what it kind of feels like. Any thoughts?
  2. Jun 19, 2013 at 5:48 PM
    vtrguy
    vtrguy Well-Known Member
    Jarrod
    Chico
    '01 Taco TRD xCab SR5
    Deckplate, Full OME kit, Snugtop Camper, Camry ignition ring, TRD Catback
    Grease your zerks and see what happens.
    Does it happen while braking too?
  3. Jun 19, 2013 at 5:52 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    I'm gonna guess driveshaft center bearing and it's just a guess.
  4. Jul 3, 2013 at 9:37 AM
    tacomabrewer
    chris
    yakima, wa
    95 Tacoma 2.7L 4WD
    The U Joint sheared off the yoke on the rear diff. Apparently the guys who I have been taking my rig to for lube stuff hadn't greased that joint, so while I was driving it snapped off. Fun. Luckily it seems like an easy fix..except the yoke on the rear diff is difficult to come by without getting a whole other rear diff. meh.
