Weird sound coming from back
Discussion in '1st Gen. Tacomas (1995-2004)' started by asus611, Mar 10, 2017.
  1. Mar 10, 2017 at 3:39 PM
    asus611
    asus611 [OP] Well-Known Member
    CA
    03 Double Cab Prerunner
    So I have about 170k on my beloved, recently there has been a repetitive screeching sounds coming from what seems to be the rear.
    Symptoms:
    1) metallic screeching noise
    2) not constant, rhythmic about every 1 to 1.5 seconds .
    3) only noticeable above 45 mph
    4) all brakes relatively new less than 10k miles
    Ideas ? Please don't say bearings !!
  2. Mar 10, 2017 at 4:29 PM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    Wheel bearings usually sound more like a hum at higher speeds when they're going out.
    Might need to pull the wheels and see if everything looks good. Maybe something caught in or around that area?
  3. Mar 10, 2017 at 5:58 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Put it up on jackstands in the rear and tap the throttle or push it in neutral to see if you can recreate the sound...?
  4. Mar 12, 2017 at 11:10 AM
    asus611
    CA
    As an update, I got the truck on some stands, the rear brake adjuster was somehow wayyyy over tightened, causing the rear shoes to butt up against the drums. Quick adjustment of the adjuster mechanism, she is all good now. Thanks for the advice TW!!
